ENGINE problems - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 08-11-2015, 09:49 PM   #1
ENGINE problems
2001 mustang GT. Went to start my car; turns over but won't start when turning over. It's real hard to turn over. It's not the starter; had it check out it. Passed.
Sent from my SAMSUNG-SM-G870A using Tapatalk
richardlab is offline   Reply With Quote
Old 08-12-2015, 12:19 AM   #2
tym_v6's Avatar
Fuel starvation?
Without more details it will be hard for us to give more specific advice. Does this happen all the time? When did it start happening? Any recent mods/repairs to the car?
Old 08-12-2015, 12:56 AM   #3
Check your ground cable for corrosion and make sure that it is securely fastened.
Old 08-12-2015, 05:51 AM   #4
Strange Mud's Avatar
+1 on checking all batt cables and cables to starter/solenoid. w/o insulting have you checked the batt?
2012 V6 with suspension, shifting, stopping and sound mods.
Old 08-12-2015, 07:16 AM   #5
No battery is new cables are clean ground is good it just happened yesterday first time. When I try to start it and give it gas it still doesn't start going to try it again after some coffee going to see if fuel pump is working
Old 08-12-2015, 10:09 AM   #6
Would the starter cause my problem found out that the starter is bad gotta check the fly wheel to see if the starter messed it up
Old 08-12-2015, 12:15 PM   #7
tym_v6's Avatar
Sounds like you found the problem!
Old 08-12-2015, 12:20 PM   #8
Rapinator126's Avatar
It's not the starter had it check out it passed
---------- Post added at 11:20 AM ---------- Previous post was at 11:20 AM ----------
:what:
Old 08-12-2015, 03:32 PM   #9
Now have power to the starter but nothing, replace the starter relay and ignition switch and the starter relay
Old 08-12-2015, 06:24 PM   #10
tym_v6's Avatar
Maybe the motor itself is bad. Can you test the windings with an ohm meter to make sure there is no open circuit?
Old 08-12-2015, 06:28 PM   #11
Ubnbit's Avatar
Is it turning over?
Old 08-12-2015, 06:29 PM   #12
No nothing
Old 08-12-2015, 06:30 PM   #13
How do I do that
Old 08-13-2015, 04:56 AM   #14
bucko's Avatar
Are you able to remove the starter yourself, meaning do you have the tools to remove it, then take it to a good automotive parts store so they can "bench test" it?
What's confusing is that you first state the starter was good, then you stated it failed. This is throwing folks off in trying to help, as it becomes difficult to trust if other tests you've done are correct.
A best option at this point would be to tow the Mustang to a shop to get a proper diagnoses and repair.
Old 08-13-2015, 06:26 AM   #15
It showed passed but when in gaged it would wobble so I brought a new one
Old 08-13-2015, 11:58 AM   #16
Finally fix it had to put engine start button in, some how I burnt the wire to the ceniod planed to put in a push button anyways
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 10:12 AM
Problems with the engine swap Joerir Classic Mustangs 1 09-13-2011 11:06 PM
engine problems chickenplucker2 Pre-2005 V6 Mustang 1 02-10-2011 04:04 PM
Engine problems!?!?!?!? Blackbandit Pre-2005 V6 Mustang 16 07-20-2010 02:53 PM
Battery/engine/oil leakeage problems? blackhawk Pre-2005 V6 Mustang 2 01-09-2010 06:50 AM
07:50 PM
