Steering wheel shake - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 08-17-2015, 02:44 PM   #1
jjrule23's Avatar
I just installed new wheels and tires from AM. They came mounted and balanced. I also installed new struts and shocks. Had alignment done. Before and after there was a slight vibration in steering wheel. So I took car back to shop and had them rebalance wheels. They said they where off slightly. Car is a 2006 GT. Any ideas or suggestions on next step/
jjrule23 is offline   Reply With Quote
Old 08-17-2015, 05:11 PM   #2
tym_v6's Avatar
Did the rebalance improve the steering wheel shake?
Did you (or the shop) take off the little rotor retaining clips before mounting the wheels?
Old 08-17-2015, 08:32 PM   #3
jjrule23's Avatar
Yes it helped slightly. I installed the struts and I re installed everything I took off.
Old 08-17-2015, 09:34 PM   #4
tym_v6's Avatar
^ What about the rotor retaining clips?
Old 08-17-2015, 09:52 PM   #5
jjrule23's Avatar
No I didn't take them off. Should I have?
Old 08-17-2015, 10:48 PM   #6
tym_v6's Avatar
Yes! If your aftermarket wheel doesn't have a countersink on the back to accommodate the clip, then the wheel won't sit flush with the hub, causing a lot of wobble/vibration.
Old 08-18-2015, 06:23 AM   #7
jjrule23's Avatar
Thanks I do that today
Old 08-18-2015, 09:19 AM   #8
tym_v6's Avatar
Let us know how it goes!
Old 08-18-2015, 10:09 AM   #9
Strange Mud's Avatar
The clips are only used when the car is assembled to hold the discs in place...yep remove them and see what happens.
Strange Mud is online now   Reply With Quote
Old 08-18-2015, 10:29 AM   #10
Diehard's Avatar
When American Muscle sells mounted and balanced tires they should include a heads up to remove the retaining clip if the new rims don't include the recess.
(In case one of the AM guys are listening in.)
Old 08-19-2015, 09:45 AM   #11
jjrule23's Avatar
Thanks for the suggestions. Found a clip on the passenger side. Took it off and car drives perfect. Thanks to everyone for your help.
Old 08-19-2015, 10:18 AM   #12
good!
Old 08-19-2015, 06:55 PM   #13
tym_v6's Avatar
Great to hear!
Sometimes I'm right when I give suggestions...LOL.
Old 08-19-2015, 07:08 PM   #14
Bobdole11's Avatar
Wow that was a good solution Props Tym
2013 Grabber Blue MT GT Convertible
Bobdole11 is offline   Reply With Quote
Old 08-19-2015, 11:01 PM   #15
tym_v6's Avatar
Thanks! Just glad it worked for the OP!
Steering wheel shake chase99980 2005-2010 V6 Mustang 15 10-13-2015 01:40 AM
Help! Steering Wheel Shake pony1996 2005-2010 V6 Mustang 11 04-08-2015 06:52 AM
Steering Wheel shake at Highway speeds 515roushtvs5.0 2011-2014 Mustang GT 22 08-06-2014 04:28 PM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
04:09 PM
