Thinking about trading my cobra for... - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 10-10-2015, 12:23 PM   #1
Tplanck's Avatar
This guy wants to trade me a 94 gt body with a 351 roller in it. Says his wife wants a convertible. He says that it makes 400+ hp. I'm not sure if that's true or not. I don't know very much about that motor. Here is the list of mods he says he has :
Mustang GT with a built fuel injected 351 roller motor. 6" Cowl hood 303 roller cam-hits a nice lick Edelbrock Performer RPM upper and lower intakes Trick Flow elbow BBK cold air intake BBK 70mm throttle body 24 lb injectors MSD distributor and coil Trick Flow valve covers Roller rockers Canton high capacity race oil pan and high volume oil pump B&M short throw shifter BBK long tubes into off-road x pipe Magnaflow exhaust-sounds amazing with dumps at rear axle Aluminum driveshaft 3:73 gears Steel motor mounts Welded in frame connectors FR500s 18x9 fronts 18x10 rears with very good tires A/c delete, but could be added back on Hot heat Factory Mach radio works great Nice grey leather with normal wear It only has 115k miles. YES speedo and odometer both works. Mileage is actually less due to rear gears causing it to run faster. actual Mileage is closer to 100. This car was built right, no junk here. It runs VERY STRONG!
Idk if that will make that much power. Let me know what you think!
1997 Cobra
Tplanck is offline   Reply With Quote
Im thinking about trading for this. Supersnake04 General Mustang Discussion 15 11-04-2012 08:31 PM
Thinking about trading up... sixpac SVT Mustang 30 07-12-2012 09:34 AM
Thinking ab trading Fordhartbreaker Pre-2005 V6 Mustang 9 01-24-2012 07:21 AM
Thinking of trading 1quickgt 1979-1995 Mustang GT 32 12-19-2006 08:23 PM
Thinking about trading in the Stang *Help!* Exit_In_Red The Bar 10 01-24-2005 05:45 PM
04:43 PM
