Anyone use the watts link setup? - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 10-19-2015, 07:58 AM   #1
Anyone have any experience with the whiteline watts link setup?
lofty price but from the small amount who have tried it, seems to be one of the most worthwhile suspension mods available
anyone? ty
2013GTpremium is offline   Reply With Quote
Old 10-19-2015, 08:12 AM   #2
Talk to Soccer about Watt's links. I don't have any experience with them but from what I have researched a Watt's on a street car is only marginally better if at all than a well put together PHB setup.
BMR is also taking pre-orders for their Watt's setup now I believe or its already out.
Old 10-19-2015, 08:37 AM   #3
ok, interesting to hear it may not be worth it.
not to branch off too far but same question regarding lower control arms. stiffening up to reduce that wheel hop, good results?
good to know youre not too far in jersey!
Old 10-19-2015, 09:50 AM   #4
tym_v6's Avatar
I had some success reducing wheel hop with aftermarket rear LCAs. They are a pretty easy and inexpensive upgrade, so relatively little downside. BMR makes a couple of varieties. Just be sure to lube the polyurethane bushings liberally to prevent squeaking!
Old 10-19-2015, 10:35 AM   #5
olerodder's Avatar
Region: Oregon
Suspension is always an interesting issue as one persons favorite is another's nightmare. No two people drive the same and no two cars are the same.
With that said the only reason I would consider a watts linkage is for racing...as mentioned on the street an adjustable panhard is just about as good.
One issue with wheel hop is that the rearend moves too much and when I tore my 14 TrakPak Mustang's rear suspension apart with less than 7000 miles I found that the UCA and carrier bushings were already starting to tear and crack....these are rubber bushings and take a tremendous amount of twisting. I replaced the carrier bushing with BMR's poly bushing and replaced the OE UCA with Whiteline adjustable....unfortunately I replaced the LCA's at the same with Whiteline adjustables and didn't get the chance to see if I had just replaced the UCA and carrier bushing if I could have solved most of the hopping. After replacing the complete rear suspension...UCA/carrier bushing/LCA's and adjustable panhard I have no hop....although I have 285/35/20's in the rear and have never put slicks on it...then I was just tired of the clunking so I replaced the two piece driveshaft with a one piece and the car is again smoother and less noise than when it was new....IMHO
Old 10-19-2015, 11:04 AM   #6
Fabman's Avatar
A Watts for street is just jewelry. Not needed. It's complicated, bulky, heavy and expensive.
What actually changes when you put a watts link on is the roll center, this is the difference you feel. You can change the roll center with an adjustable pan hard bar too. No, not the length, but the height. Steeda has a nice little adjustable pan hard bar setup which is PLENTY good but involves some fabricating to get it installed.
Yes, a watts link keeps the rear centered in the car a little better, but it's such a minute difference you would never feel it. Another benefit to the watts is that it has the same action in both directions, but if the pan hard is set up properly it is just as good. I could give you two identical cars, one with a watts link and one with a properly set up pan hard bar with the same roll centers on each and you would never ever be able to tell the difference.
Its the roll center that dictate how the car handles, not the method of linkage attached to it.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 10-20-2015, 05:50 AM   #7
audioAl's Avatar
The new BMR watts link weights 22 lbs. I will change my oe mufflers to offset the weight difference. It's price is $550.00 a little less that Cortex or Whiteline.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 10-20-2015, 07:31 AM   #8
Fabman's Avatar
A pan hard bar weighs 5 pounds and it's free.
Old 10-20-2015, 07:57 AM   #9
i definitley appreciate the feedback, the reviews on it over at AM make it sound like the the car cant live without it
im thinking pan hard bar
Old 10-20-2015, 07:58 AM   #10
somehow my phone didnt pick this up and im just now seeing it. thanks for the info, very helpful
Old 10-20-2015, 09:20 AM   #11
Fabman's Avatar
You could sell a chrome turd on a mustang website and people would rave about the flavor.
Not that this is a turd mind you, just more a referendum on some reviewers.
Tuned by AED
Old 10-20-2015, 09:29 AM   #12
olerodder's Avatar
Region: Oregon
That was hilarious!
Old 10-20-2015, 09:29 AM   #13
Chrome turd, to be installed in rear of vehicle for more weight above rear tires, thus resulting in slightly better weight distribution and marginally better traction. Price: $49.99
Old 10-20-2015, 10:24 AM   #14
CodyC's Avatar
I can see it now:
"WOW BEST MOD I'VE EVER BOUGHT! WORTH EVERY PENNY! BETTER THAN ALL THE CRAPPY CHROME TURDS ON THE MARKET RIGHT NOW! COMPLETELY TRANSFORMED HOW THE CAR HANDLES! 8/8 GR8 M8, 10/10 IGN!"
Time to mosey on over to the AM Product Suggestion thread...
CodyC is offline   Reply With Quote
Old 10-20-2015, 10:50 AM   #15
Fabman's Avatar
Originally Posted by CodyC View Post
I can see it now:
And then....."New lighter billet aluminum turds! Throw away those old heavy outdated steel steel turds and go billet!"
.......Followed 6 months later with New Carbon fiber turds!
Tuned by AED
Old 10-20-2015, 11:37 AM   #16
Fabman's Avatar
Case in point:
New Mid-Pipe Double X
Tuned by AED
Old 10-20-2015, 11:59 AM   #17
The real benefit with the Watts Link over the Panhard Bar is being able to adjust your roll center even more, and its not biased toward one side like a pan hard bar is.... But if you never track the car and don't run real sticky tires then no real need for it. If you do 1-2 events a year or a couple auto crosses i would say go for it.
It all depends on how you plan to use the car.
I like my Panhard bar. But i know i won't be keeping it forever.
Old 10-20-2015, 12:31 PM   #18
lol this post def took an interesting turn haha
Old 10-20-2015, 12:45 PM   #19
Fabman's Avatar
What it comes down to is "The Jacking effect".
The theory here is that pushing on the bar will lift the car in the compression direction.
This is true IF:
1) the bar is pointing down towards the ground towards the outside of the turn
2) The tires generate enough side bite to lift the weight of the car in a corner. (more pounds of lateral bite than the weight of the car)
Answer #1) The pan hard bar SHOULD be mounted level-not at an angle.
answer #2) Unless the car is VERY light and you have VERY wide and STICKY tires with EXCELLENT suspension, you will not be able to generate enough grip for this to have any noticeable effect.
Moral of the story:
A street car with street tires will never ever generate enough side bite to matter. I'm not saying don't buy one or that watts aren't good....just understand the reality's before you make the choice.
And in case you don't believe me, a former professional stock car chassis designer and championship driver, Kenny Brown also uses Pan Hard bars on their full on race cars because the watts simply isn't worth the weight, complexity and cost penalty. It's just more important to have the roll center where you want it than what the linkage looks like. But then hey, what the flock do I know?
Tuned by AED
Old 10-20-2015, 12:50 PM   #20
Fabman's Avatar
Here you go:
Tuned by AED
Old 10-20-2015, 12:55 PM   #21
Fabman's Avatar
amazing what you can find on youtube:
Tuned by AED
Watts Link..... Which one 2014GT 2011-2014 Mustang GT 49 05-09-2014 10:55 AM
Whiteline Watts Link Rear Suspension NewMtang 2011-2014 Mustang GT 5 01-08-2014 01:04 PM
Whiteline Watts Link Rear Suspension NewMtang General Mustang Discussion 17 12-24-2013 07:03 PM
Whiteline watts link group buy? HPFury 2011-2014 Mustang GT 7 10-31-2013 12:27 PM
Watts Link Solomo2 2005-2010 Mustang GT 20 09-20-2012 12:55 PM
06:33 AM
