problems after tune - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 12-27-2015, 09:03 PM   #1
problems after tune
Hi comunity, i have a gt 2007 a/t.
A few weeks i installed CAI BBK and all works perfect, but after i changed the catalytic converters for this PIECES ... and the install 2 flowmasters 50 series..
The check engine light turn on, the error P0171 lean.. bank 1
I run sct x4 programmer, deleted o2 rear sensor, installed intake cai bbk, changed octane to 91 (because in my country only 91 and 95 oct but my options are 89 91 and 93)
The check engine turn on again... P0171..
What else should I change to forget the light? WOT I change the mix?
In x4 increse of 2%, 4%, 6%.... to 14%
Thanks and sorry for my bad english.
JLRM is offline   Reply With Quote
Old 12-29-2015, 05:27 AM   #2
youre getting a code due to lack of 02 sensor
when computer senses its not getting either a good signal or none at all it will always trip a CEL
when i had my 350z and removed cats, we used an extender trick to fool the 02's and keep the engine lights at bay. hope this helped
2013GTpremium is offline   Reply With Quote
Old 12-30-2015, 06:18 AM   #3
I had installed this piece in both substitutes for cats. But turn on the Check Engine Light. Before on the options turn off rear o2 sensors by the programmer sct but the CHECK ENGINE turn on
Old 01-02-2016, 10:51 AM   #4
use the tuner to datalog or view your AFR's maybe youre lean...
Old 01-02-2016, 11:59 AM   #5
natestang07's Avatar
Sounds like you need an actual tune.
Old 01-02-2016, 12:38 PM   #6
ya you likely are running lean, no good. a strong yet safe tune is worth the price of your motor if you ask me. learn how to datalog, go from there
Old 01-03-2016, 09:00 PM   #7
jande063's Avatar
Your downstream O2 sensors are used only to test the catalytic converter's. The upstream O2 sensor is what is used to determine a mixture issue.
jande063 is offline   Reply With Quote
Problems after installing spark plugs Mustangreazon50 2011-2014 Mustang GT 38 10-21-2013 10:17 PM
Problems with tune after install mods (CAI, TB, Plenum, etc) reboot4ever 1996-2004 Mustang GT 9 10-11-2013 01:38 PM
10-14 before and after pics after mods gtstyles2 Mustang Paint, Appearance & Detailing 16 08-27-2013 02:45 PM
Car problems after repairs at dealership 2013Coyote5.0 2011-2014 Mustang GT 4 07-15-2013 08:30 AM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 10:45 AM
10:00 PM
