Jacking points - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 01-04-2016, 12:41 AM   #1
Jacking points
Hi I have a low profile jack. I have a question, where do you jack your mustang? I read online that some people had problem when jacking their car at the pinch weld (They crumble/bend) resulting to damage in the car i.e. car door won close properly. Is this true? If so, any alternative jack poins?
michaelboy2375 is offline   Reply With Quote
Old 01-04-2016, 01:26 PM   #2
Diehard's Avatar
When I must jack, instead of using ramps, I use the pinch weld areas but use an inexpensive (but quite adequate) Walmart jack that happens to have a bit of a slot on the jacking plate.
Then depending on what I'm doing, I may slip my larger low profile jack to under the steel members, as shown in picture with the 2x4's(I don't typically use the 2x4 blocks though). Or I may put stands under the rear axle.
Name:	Jack or Stand Points.jpg
One of these days I will put a slot in a hockey puck that I have, to use for the pinch welds with any jack or jack stand.
I always block the wheels and set parking brake.
If I'm going to work under the car I always have a secondary item to support if not on stands.
Old 01-04-2016, 05:32 PM   #3
Thank you! That was helpful! Can you buy the puck that you put on top of the low profile jack?
Old 01-04-2016, 05:51 PM   #4
dave73's Avatar
Jacking points
What can bend the pinch welds is if you try to lift one side too high first to get a jack stand under. It puts too much force on the side of the pinch weld. I jack one side up and rest on a chunk of railroad tie I have. Then lift other side and place jack stand. Then come back around lift the first side remove the tie and place jack stand.
dave73 is offline   Reply With Quote
Old 01-04-2016, 08:06 PM   #5
Diehard's Avatar
I believe you can buy various types but not very cheap.
Here are some pics to refer to.
https://www.google.com/search?q=hock...UXZO1Y3WSB8%3D
Old 01-06-2016, 12:23 AM   #6
Region: Nevada
A piece of slotted hardwood works just fine as a pinch-weld adapter. You can make one in a couple minutes and its pretty inexpensive.
-Static
Static_LV is offline   Reply With Quote
Old 01-07-2016, 01:44 PM   #7
Diehard's Avatar
-Static
And if not plywood, slot should be made across the grain, to minimize cracking.
Old 02-19-2016, 02:34 PM   #8
Regarding the puck approach, how deep the slot should be? Should it deeper than, same as, or shallower than the pinch-weld edge?
Thanks
alfaromeo is offline   Reply With Quote
Old 02-19-2016, 07:18 PM   #9
Diehard's Avatar
Thanks
I would say, same or slightly deeper.
I'll try that Google link again.
https://www.google.com/search?q=puck...+at+pinch+weld
Jacking up the car Black302Alex 2011-2014 Mustang GT 24 08-09-2014 07:09 PM
Mach 1 jacking Redsvtcobra Pictures and Videos 12 01-14-2014 01:11 PM
Jacking up car Moto111 2011-2014 Mustang GT 38 02-03-2013 01:48 PM
Jacking the back up. GhostStang 2005-2010 Mustang GT 5 08-05-2009 03:46 PM
Differ Ways of Jacking bluemustang Pictures and Videos 25 03-02-2007 08:26 AM
12:34 AM
