Nitrous help ASAP - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 04-21-2016, 01:23 AM   #1
Boosted_3v's Avatar
Nitrous help ASAP
Maybe I can get some answers here?
So i got a NX plate kit installed 07 GT, and took it to get tuned everything worked good. I have a MSD window switch. Nitrous kicked on at 3,000 kicked off at 6,000
Now here's the problem after it came back down to when it was in neutral to 6,000 then the nitrous kicked back on again!
I don't see any wires going to the TPS just to the coil pack. Is that the issue I did not install it, a shop did. Almost cost me my motor...
Luckily my tuner saved the motor and we cranked all the extra nitrous out the motor!
Does the MSD Window Switch connect some how to the TPS so the nitrous activates on WOT?
Or will I have to hook up the WOT box to my MSD then to my TPS so I don't have the same issue with nitrous spraying while the RPM is coming down in neutral?
Boosted_3v is offline   Reply With Quote
Old 04-21-2016, 11:24 AM   #2
Why not just use the wot box for wot switch and window switch? It's capable of both.
You definitely need either a tps switch or old fashion wot switch on pedal.
Sent from my XT1045 using Tapatalk
Old 04-21-2016, 10:29 PM   #3
Boosted_3v's Avatar
So my MSD window switch can operate at WOT?
Old 04-22-2016, 07:57 AM   #4
I saw wot box and thought you had the n2mb unit which controls both. You will need a tps wot switch that will be wired before the window switch.
nitrous
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 02:31 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 01:43 PM
help asap air/fuel ratio gauge install Rstang98 Pre-2005 V6 Mustang 8 03-06-2004 02:17 AM
Need Help with Viruses on my COMPUTER! HELP ASAP!! Autobadges.com The Bar 41 02-05-2004 10:53 PM
Car overheated!!! NEED RADIATOR ASAP HELP!!!! Autobadges.com The Bar 18 11-15-2003 01:36 PM
01:26 AM
