Clutch problems - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 04-28-2016, 06:00 PM   #1
Tplanck's Avatar
Clutch problems
So I think my clutch went out. Just wanting so input from others. I started noticing about two weeks before it "went out" that I was losing some power.. The about a week later it started to squeal when you pushed the clutch in. Also when I would give it gas while in gear the rpms would rise but I really wouldn't go much faster. Finally I heard a clunk and I lost tension in my clutch pedal. I could no longer shift gears. You can push the clutch in with your finger basically but it doesn't let you shift. I bought a complete clutch kit to get put it. My cobra has about 110k miles on it so I'm sure it needed a new clutch. But does this sound like the clutch it's self or something else that has to do with it? Thanks
Tplanck is offline   Reply With Quote
Old 04-28-2016, 11:01 PM   #2
Revvv's Avatar
The clutch is dead.
Old 05-07-2016, 08:52 PM   #3
Tplanck's Avatar
Name:	ImageUploadedByMustang Evolution1462675889.029309.jpg
ID:	200716 any idea if this 8 bolt flywheel will fit my cobra?
Old 05-07-2016, 09:16 PM   #4
I think that flywheel will work, but you can probably just have your existing flywheel resurfaced and it will be as good as new.
It sounds like your clutch cable might have broken. Or the clutch fork possibly popped off of the pivot ball. If you have to replace the clutch cable, use only a genuine Ford factory part, or Ford Racing as a replacement.
Old 05-08-2016, 03:25 PM   #5
Tplanck's Avatar
Any idea how much transmission fluid in gonna need for this?
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 09:12 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
new clutch problems nasty99 1996-2004 Mustang GT 14 03-10-2011 03:04 PM
clutch engagement problems 1996v6stang Pre-2005 V6 Mustang 11 05-19-2010 08:31 AM
2006 Mustang clutch problems brokenford Pre-2005 V6 Mustang 1 03-18-2008 12:48 PM
09:12 PM
