2012 halogen to LED head lights - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 05-04-2016, 05:55 AM   #1
Looking for input on changing out 2012 head light bulbs to higher quality LED s
How's the light output , beam pattern, any negatives about them. Thanks
Andy G is offline   Reply With Quote
Old 05-04-2016, 06:09 AM   #2
Only input I can give you is make sure they are legal in your state, they are not in Florida which is the only reason why I don't have them 😵
Wheela is offline   Reply With Quote
Old 05-04-2016, 06:12 AM   #3
Revvv's Avatar
Is there a reason listed as to why the LEDs are illegal? I'm curious.
Old 05-04-2016, 06:24 AM   #4
It's not that specifically LEDs are illegal in that it's any modification of headlamps from the OEM is illegal, so even HID conversions are illegal too, but we don't have mandatory inspections here so it's more rolling the dice and getting pulled over for a non-moving violation.
Old 05-04-2016, 09:47 AM   #5
MS. Don't have vehicle inspection . My main concern is the beam pattern & light output , I read putting LEDs in some "reflector housing" type headlights even the Low beam will still blind on coming traffic , now that can maybe get you a ticket.
Old 05-04-2016, 09:52 AM   #6
Revvv's Avatar
I'm not sure I would consider LED bulbs to be a modification. That's just my opinion though.
Old 05-04-2016, 09:59 AM   #7
Revvv's Avatar
If the lights are aimed correctly you shouldn't have a problem. The light's reflective surfaces cannot bend light in a way due to a different bulb.
There is a flip side to that coin. If the LED bulb is taller, or if the light sends a beam at the reflector in a different angle than the OEM bulb you may see a different refraction of light.
With an LED bulb you will likely notice a cleaner light output that appears brighter. If the lights are adjusted properly you shouldn't have a problem with oncoming traffic.
Old 05-09-2016, 09:10 PM   #8
Update on the halogen to LED , installed the OPT 7
Flux-beam led's $99.00 pr. 2 year warranty fantastic beam pattern , very bright and white & not blinding anyone on low beam, but the Vertical adjustment is KEY . After pricing high end Halogens bulbs with there short life span it was a no brainer.
Old 05-09-2016, 09:15 PM   #9
Revvv's Avatar
$99 sounds expensive for a set of bulbs, but you get what you pay for most of the time. Also consider the price for high end Sylvania bulbs; they are is a to adding up to the cost of LEDs.
I don't need bulbs at the moment, but when I do I will likely go with LEDs.
2012 V6 Halogen to OEM HID conversion Sakib 2011-2014 V6 Mustang 42 10-19-2014 04:57 PM
2011 Halogen Headlight to 2013 HID conversion... 2010GBGT 2011-2014 Mustang GT 15 04-13-2014 09:21 AM
Hid in halogen housing comporange Pictures and Videos 47 01-01-2014 12:24 PM
578 dome lights to 578 42mm led dome lights? Sluder4 Pre-2005 V6 Mustang 5 03-10-2013 05:51 AM
Halogen to HID Ravnus 2011-2014 Mustang GT 17 04-20-2012 05:47 PM
09:36 AM
