2015 Mustang GT - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 08-25-2016, 07:05 AM   #1
2015 Mustang GT
I purchased a X4 SCT tuner and a JLT CAI from Lightening Force Performance with a preload tune, installed both , car would crank , start and then stop running within a few seconds. Talked for 4 days off and on with the SCT TECH support. I was told that it was a mechanical issue to the JLT that I bought was not built for my 2015.
Has anyone ever experienced this?
Mark Marley is offline   Reply With Quote
Old 08-25-2016, 07:47 AM   #2
jkeaton's Avatar
Take the CAI off and see if that actually is the problem.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 08-25-2016, 09:57 AM   #3
It was not recommended to run the car with the tune installed, without the CAI ,and I know it won't run with the CAI installed and no tune. That is what SSCT tech reps said, so I did not try it with that setup. Do you think it will mess the car up if I trouble shoot it with tune installed and no CAI?
Old 08-25-2016, 10:09 AM   #4
jkeaton's Avatar
I think as a test, starting it up with the factory intake and tune installed for the few seconds it will take to determine if it still shuts off or not would do no harm.
07 V6 Coupe
Old 08-25-2016, 10:26 AM   #5
Strange Mud's Avatar
w/o insulting did you install the air flow sensor correctly and is the plug fully seated. Did it get damaged they are fragile. After checking that I would start again at stock...mayhap corrupted tune?
New England Cruise June 3rd!
see regional forum for details
http://www.mustangevolution.com/foru...post4261510322
Old 08-27-2016, 11:49 AM   #6
You were right, in the JLT CAI you can install the MAF in either direction, reinstalled the correct way and car works AWSOME !!!
Old 08-27-2016, 11:53 AM   #7
Another question, in the SCT tuner you can change the settings for the transmission, I have an 6 speed Automatic, what do the negative percentages mean and do, and at what percent, positive or negative gives the car the best performace on the street as far as shifting? I really want the car to bark gears when putting my foot down. Thanks for the info
Old 08-29-2016, 05:20 AM   #8
I don't know about the tuner settings..are they LFP tunes or are they SCT? If so see how they are with customer questions.
Old 09-03-2016, 10:04 AM   #9
stanggtcs's Avatar
Glad to hear you were able to find the issue. Now get out there and lay down some rubber, safety first
2014 GT/CS 6spd. with total FR suspension upgrades.
stanggtcs is offline   Reply With Quote
2015 mustang
2015 Mustang GT PP vs 2015 Camaro 1LE Ish416 2015 Mustang GT 111 06-12-2015 04:52 PM
2015 3.7 Vs 2015 2.3 ecoboost 2011 Kona Blue 2015+ Mustang Ecoboost (and V6) 114 01-05-2015 05:16 AM
Ford rumors of SVO mustang to be produced for 2015 mustang Kyle94GT302 General Mustang Discussion 3 10-19-2011 10:02 AM
04:42 AM
