Mustang 2004 - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 08-25-2016, 12:29 PM   #1
Angry Mustang 2004
Changed starter got a new battery car will crank but not start the gates on the dashboard will move like all the way to one side and then the other never did befor what. Luke be the problem
Tonyas is offline   Reply With Quote
Old 08-25-2016, 12:33 PM   #2
check all your grounds on the battery. does your theft light flash?
dcarr is offline   Reply With Quote
Old 08-25-2016, 12:50 PM   #3
Cleaned battery cables and post tried again same thing yes when I turn the key the theft light flashes after I try starting it no it dosent checked ground wires they are all ok
Old 08-25-2016, 12:59 PM   #4
check your ground wire condition. not just at the battery but at the radiator support. also make sure the ground wires at the battery connector aren't broken or corroded. I had the same issue and it was a smaller wire not making a good ground and tripping the theft system
Old 08-25-2016, 01:26 PM   #5
Where is the radiator support
Old 08-25-2016, 01:34 PM   #6
just in front of your battery. its the piece of metal that runs across the front of your car above your radiator
Old 08-25-2016, 01:44 PM   #7
here is a video of what it does
Old 08-25-2016, 02:05 PM   #8
Did that it is doing still what I posted in the video
Old 08-25-2016, 02:20 PM   #9
Revvv's Avatar
Did you try to hook the battery up backwards at first? It almost sounds like a computer problem.
Old 08-25-2016, 02:25 PM   #10
No it was hooked up right
Old 08-25-2016, 02:37 PM   #11
This is what it's doing I hope this one plays
Old 08-25-2016, 07:34 PM   #12
Do you have the wires on the starter hooked up properly?
Old 08-26-2016, 05:44 AM   #13
jkeaton's Avatar
I don't hear it cranking in the video. IIRC, the theft light along with all the other dash lights will come on when you first turn the key to run as a bulb check. I don't see it flashing, just coming on and turning off. I think the gauges do that whenever the battery is disconnected as a "calibration", I remember mine did that the first time I started t after I had disconnected the battery. I tend to believe it is not theft light related. What preempted the replacement of the battery and starter? Was it running fine before the replacement of both items?
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 08-26-2016, 06:09 AM   #14
No the starter went out it would turn over but not start the starter was just spunning
Old 08-26-2016, 07:28 AM   #15
jkeaton's Avatar
ok, I'm sorry for the basic questioning, but I need to know more info. Who did the install? A shop? Yourself? At any rate, assuming the new battery and starter were installed correctly and the car does turn over (crank) when you try to start it (as I currently understand), get back to basics, are you getting spark and fuel? Trying to eliminate the obvious before returning to the security issue (if there is one).
07 V6 Coupe
Old 08-26-2016, 07:32 AM   #16
Revvv's Avatar
I hope he doesn't have a security issue. I despise the PATS these cars have.
Old 08-26-2016, 07:58 AM   #17
jkeaton's Avatar
I don't either, but not sure how changing the battery and starter would all the sudden trigger an anti-theft problem.
07 V6 Coupe
Old 08-26-2016, 08:36 AM   #18
Everything is hooked up right we changed it ourselves and besides the Gage's when we tried to start it the positive wire on the battery started smoking and got real hot
Old 08-26-2016, 09:12 AM   #19
Revvv's Avatar
Something is grounding at some point. You may have a bare wire that has yet to be noticed.
Old 08-26-2016, 09:13 AM   #20
jkeaton's Avatar
Yep. That new info definitely points to something shorting out. Start tracing wires between the battery, alternator and starter.
07 V6 Coupe
Old 08-26-2016, 09:42 AM   #21
the theft issue I had was because of a bad ground contact on the battery (stupid universal replacement battery terminals). the theft light would blink really fast while trying to start the car this one is different. there is definitely an issue though. the positive cable shouldn't get hot. I would say trace all your wires and make sure they are on the correct spots on the starter. maybe go as far as to take the starter out and get it tested. was it new or reman?
Old 08-26-2016, 09:54 AM   #22
Starter was brand new so was the battery
Old 08-26-2016, 12:51 PM   #23
jkeaton's Avatar
This is a tough one to diagnose over the internet. You definitely have something shorting out. You need to start tracing wires. Double check to make sure something didn't get pinched somewhere.
07 V6 Coupe
Old 09-02-2016, 05:07 PM   #24
32VALVR's Avatar
Generally when the gauges sweep like that its an indication of a battery beginning to die. You are not getting full power be that for a mis wire, as you stated something smoke, a starter pulling to much power or maybe even a bad new battery. I would take the starter and battery back out, and have them checked at Auotzone or whatever parts house is in your neck of the woods.
03 Mach 1
Kenne Bell 2.1 Stock block, built 4r70w w/ Fairbanks, Accufab, SLP, Moser, 3.73, welded tubes, Trick Flow, Magnapack, Megabite Jrs, AFS
1/4 11.57@119.6, 1/8 7.4@95 on NTO5r dr's.
32VALVR is offline   Reply With Quote
2004 Mustang GT :: 2004 Ford Mustang GT Landspeedracer Member Garages 0 09-01-2015 04:03 AM
2004 mach 1 vs. 2004 svt cobra Michaelgranlund 1996-2004 Mustang GT 32 03-08-2013 07:19 PM
What is the differnce between a 2004 mustang svt and a 2004 mustang gt? skeet General Mustang Discussion 3 12-13-2011 09:53 AM
05:07 AM
