rough idle after jumping battery - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 09-15-2016, 05:28 PM   #1
My battery died in my 14 GT. I jumped it off only for it to idle crazy. Fuel air ratio gauge was to the max and the gas pedal would only rev engine up just a bit... help! Any suggestions
Hankhill205 is offline   Reply With Quote
Old 09-15-2016, 11:09 PM   #2
Get your charging system tested immediately.
Old 10-13-2016, 06:29 PM   #3
Mustang gt
Ok everybody I have a 1995 mustang gt. 5.0 recently I have noticed a studder, problems accelerating. Also rough idling, and rpms having problems gettin passed 2000. I have changed the coil pack, spark plugs, fuel filter. Still no luck. Anybody that knows the issue help me out please..
Jaret is offline   Reply With Quote
Old 10-13-2016, 06:50 PM   #4
jkeaton's Avatar
Throttle position sensor?
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is online now   Reply With Quote
Old 10-13-2016, 08:38 PM   #5
Do a fuel pressure test.
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 10-13-2016, 08:50 PM   #6
And the fuel pressure should read what??
Old 10-13-2016, 08:51 PM   #7
I'll try it thanks
Old 10-13-2016, 09:19 PM   #8
The fuel pressure should be 30-45 psi with the vacuum hose attached to the fuel pressure regulator. It should be 40-50 psi with the vacuum hose detached from the regulator.
The fuel system should hold pressure for five minutes, with a loss of less than 5 psi from the indicated operating pressure.
My rpms are jumping in idle andregayola Pre-2005 V6 Mustang 7 04-05-2013 09:44 PM
Stalling/rough idle after start up? brianw64 2011-2014 Mustang GT 11 12-18-2012 07:53 PM
Battery ran low now all of a sudden rough idle and no AC. Help! Spiney SVT Mustang 3 07-07-2012 08:12 PM
2006 GT Jumping forward after startup? ghst 2005-2010 Mustang GT 7 06-22-2012 10:53 PM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
03:46 PM
