Oil burn 2012 GT - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 09-23-2016, 11:43 PM   #1
Oil burn 2012 GT
My 2012 GT has 49000 miles. I bought it in Jan 2016 with 38000 miles from the original owner with the original tires which had even wear all around. The car did not appear to be abused. I changed the oil after a few thousand miles with a conventional Mobil high mileage which the lube shop said was recommended by Ford I now know the min is a synthetic blend. The car went through About 5 additional qts over 4000 miles. I changed the oil myself at 46000 miles with Mobil 1 full syn 15000 mile oil and it seemed to be better but I just added the last of the two 5 qt jugs over 3000 miles. This seems like excessive oil burn and I was planning to do another change in 2000 miles. Is there a better oil to use or is this normal?
I am going to start keeping records of exact mileage and oil added from now on.
2012 GT Bremo is offline   Reply With Quote
Old 10-03-2016, 11:28 PM   #2
tym_v6's Avatar
That is way too much oil consumption. Any signs of leakage? Cracked pan, leaky drain plug, anything?
My 2013 V6 has about 68k miles and it goes through maybe half a quart between oil changes (I'll bet a bunch of the "consumption" is blowby through the PCV system).
Old 10-03-2016, 11:37 PM   #3
I have catch cans which accumulate minimal oil like a few table spoons at most. It has no leaks what so ever
Old 10-03-2016, 11:50 PM   #4
tym_v6's Avatar
Has your car had a compression test?
2012 gt
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 12:37 PM
burn oil? austinknoll Pre-2005 V6 Mustang 6 01-29-2012 09:21 PM
Why does my 1979 Mustang burn oil in high rpms? kinsella 2.3 Mustang 4 12-24-2011 02:04 AM
Let it Burn Brent The Bar 31 06-10-2004 05:07 PM
what would be the funnest thing to watch burn down? mexor The Bar 11 11-03-2003 11:57 AM
12:35 PM
