2014 mustang v6 possible radiator leak - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 10-08-2016, 01:19 PM   #1
So I recently checked my coolant level and it was below the cold fill line, so I added some 50/50 coolant. Later that same day I check the coolant and it's basically back down to where I first added coolant in. There's no overheating and the coolant light isn't on, it doesn't even go below the point where I first added but I'm wondering if this is normal. How should I check for leaks? With more coolant or could I use water?
Thanks
Xero is offline   Reply With Quote
Old 10-08-2016, 02:52 PM   #2
iguanaman3's Avatar
Look for evidence of leaks from the waterpump located on the front of the engine. There have been many that have leaked prematurely.
iguanaman3 is offline   Reply With Quote
Old 10-08-2016, 02:56 PM   #3
That's my plan, could I just use distilled water? Don't want to waste coolant if I have a leak.
Old 10-08-2016, 03:16 PM   #4
wmschoonover's Avatar
Yes you can add water but if you get the mixture off too much then you will have overheating issues in the summer and freezing in the winter so make sure you have a coolant tester.
wmschoonover is offline   Reply With Quote
Old 10-08-2016, 03:16 PM   #5
Yea, just get it fixed and then a full flush and filled with coolant before the weather gets cold. Don't want it to freeze.
2013 SGM 3.7 | MPT Tune | JBA Titanium Ceramic Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | BBK TB | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 10-08-2016, 03:17 PM   #6
iguanaman3's Avatar
Yes. Water wont hurt anything while you find your leak. As long as you don't freeze of course.
Old 10-08-2016, 03:28 PM   #7
o
You won't have to flush and refill unless there is something in the coolant. Just get non diluted coolant and you can use a tester and get it back to range.
Old 10-08-2016, 04:34 PM   #8
Strange Mud's Avatar
if it is the water pump there is a history of them leaking from the degas hose NOT having a check valve. search for updated degas hose or just look in the V6 forum there are threads about it.
most folks have had luck getting it replaced (pump) under wtty 5/60 I did my hose a preventive
Mud
Old 10-08-2016, 04:51 PM   #9
David Young's Avatar
Take it to your dealer. They will check it out and replace it for free on your 2014 Mustang Post back and tell us what they (your Ford dealer) tell you.
David Young is offline   Reply With Quote
Old 10-08-2016, 04:59 PM   #10
jande063's Avatar
It will not overheat in the summer, but could freeze in the winter. We don't run ANY coolant in my car because I can't be dumping coolant on track if I have a problem, since it will cause a yellow flag for cleanup, where water wont.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 10-10-2016, 11:27 AM   #11
DrDave's Avatar
Ford TSB 14-0212 addresses this issue
Steeda CAI, 73mm TB, BBK Shorty Ceramic Headers, DynoTech 3.5" Aluminum DS, Ford Racing 3.55 Gears, Steeda Pro-Action Struts & Shocks, Steeda Adjustable Sway Bars, Steeda, Upper Strut Mounts, Hotchkis Adjustable Rear Upper Control Arm, J&M Extreme Joint Lower Control Arms, J&M Adjustable Steel Panhard Bar, Tune by MPT
DrDave is offline   Reply With Quote
Old 10-10-2016, 12:35 PM   #12
Antifreeze/Coolant raises the temperature at which water boils, so it does help prevent overheating in hot temperatures.
I hope that you are strictly using only distilled water in your cooling system.
Old 10-17-2016, 02:54 PM   #13
Diehard's Avatar
Thanks
What ever became of this possible problem?
Hopefully it's been diagnosed by now.
Old 10-19-2016, 07:34 PM   #14
I actually got some of the cheap coolant repair liquid from amazon, like $4, topped it off and havent had an issue yet. its been a few weeks. I recommend that first if you think you might have a minor leak.
Old 10-20-2016, 03:14 PM   #15
Diehard's Avatar
Hmmm...not a fan of stop leak products.
If there was, in fact, a leak(?) and it wasn't external, hopefully it wasn't internal.
Thanks for the follow up response.
2014 mustang
Radiator leak Sprague199 1979-1995 Mustang GT 10 07-11-2012 08:34 PM
Fluidyne Radiator leak bobsurvives 1996-2004 Mustang GT 12 05-10-2011 01:35 AM
2000 v6 possible clogged radiator? HELP! 200v6 New Member Introductions & Greetings 7 01-27-2011 05:26 AM
Is it possible to turn my p71 crown vic into a muscle car possible? Woodruff General Mustang Discussion 6 04-11-2010 09:30 PM
Is it possible to still possible for something to go wrong with the car? pueblo70 1996-2004 Mustang GT 4 08-26-2009 08:47 AM
06:05 PM
