Check engine light came on a few months ago,dealer replaced 1 plug,said it probably fouled from sitting too much? Didn't want to wait 3 days for appointment,figured why not do what I can do at home,engine was idling rough,check engine light flashing on once in a while.That seems to have stopped,steady idle,no missing after replacing all 6 plugs,just figured "age" of plugs? Hey,thanks for taking the time to reply
Sometimes you have to clear the check engine lights to see if the light comes back on for same issue or new issue. If it's still misfiring it could be the coil pack
Not sure about the Mustangs but I know on my 2006 Kia the key had to be turned 25 times before the code would clear, unless you cleared it with a code reader.
I had a misfire so I replaced all plugs, then the wires, then the coil pack and could not get rid of the code. I called Kia and they stated that's what it was so in reality I could have replaced one plug and be done, but instead I put a good amount of money into it.
I don't know how and where to find code, I disconnected the battery for about thirty minutes today and after re-connecting everything seems fine,so far.Thanks for the assist
You plug a reader into the OBD port under the dash. Any auto parts store will read the code for you for free. Also consider getting yourself a code reader. Best tool you can have in your toolbox. You can get them for less that $20 these days.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
