can the 5.8L 392 stroker block take parts from 5.0's? - Mustang Evolution
Old 07-23-2003, 09:29 AM   #1
fast64's Avatar
I am thinking of saving up and getting ones of these stroker short blocks, but I have never seen parts for them (except for some Edelbrock heads). So I was wondering if they use 5.0 parts.
GO BRAVES
Old 07-23-2003, 11:28 AM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
which parts, and what exactly are you planning?. That stroker kit would probably go on a 5.0 and you would stroke it to 5.8
Rellik is offline   Reply With Quote
Old 07-23-2003, 12:01 PM   #3
fast64's Avatar
well, I was gonna buy a whole stroker short block from Mustangs Unlimited. But, I am trying to figure out if when I buy parts for the 5.8 if I just buy 5.0 parts.
GO BRAVES
Old 11-30-2003, 01:20 PM   #4
302 and 351W share some common attributes, some are not common. We've done 2 V8 strokers. One was a 302/327 stroker, the other a 351W/392. We used the AFR heads, cam, and short style timing cover/water pump from the 327 on the 392. Even then the heads and cam which were ideal on the 327 and which fit on the 351W stroker, were "too small".
Anyway, some items from the 302 that fit on the 351W:
Heads, cam (may need to do a roller cam conversion depending on 351W vintage), oil pump, upper intake (fits but may be "too small"), bellhousing, tranny, headers (fits but may be "too small"), accessory brackets if SN-95, dipstick, valve covers, certain rocker arms, motor mounts, most bolts.
What doesn't fit and must be 351W specific:
Lower intake, distributor, oil pump drive shaft, oil pan, pan rails, oil pickup, balancer, flywheel/flexplate, EFI fuel rails.
SuperSixMotorsports.com
Dyno-proven track tested hard-core performance products for the 3.8L V6
Tom Y is offline   Reply With Quote
Old 11-30-2003, 02:21 PM   #5
fast64's Avatar
thanks, but i learned that stuff a long time ago (like in July when I posted this thread)
also, It would be carbed and it would go in my 64.5, i dont have an sn-95 stang
GO BRAVES
DSS stroker block pictures silverstangboy 1979-1995 Mustang GT 58 05-25-2007 08:03 AM
Ford Racing 392 Crate motor... Fast93Coupe 1979-1995 Mustang GT 2 04-22-2006 09:54 PM
Now i know why 5.0's are loved timpryor The Bar 27 05-09-2005 06:57 PM
Wassup guys new guy from NW AL representing the 94-95 5.0's Yellow5.0 New Member Introductions & Greetings 38 04-28-2005 09:54 PM
Things to look out for when looking at 5.0's Requiem The Bar 16 11-01-2003 01:28 PM
03:23 AM
