When should my second two barrels on my carb open up? - Mustang Evolution
Old 07-26-2003, 07:15 PM   #1
fast64's Avatar
When should my second two barrels open up to maximize performance?
GO BRAVES
Old 07-26-2003, 10:25 PM   #2
Send a message via AIM to el cheapo
is it vacuum or is it conected to the throtle linkage?
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 07-27-2003, 01:41 PM   #3
fast64's Avatar
connected to throttle linkage
GO BRAVES
Old 07-28-2003, 09:02 AM   #4
then it should open as soon as you floor it. You dont really want it to open before that, but if the linkage isnt opening it all the way at wot then you should adjust it.
Old 07-28-2003, 09:14 AM   #5
fast64's Avatar
I think its opening way earlier than that b/c I am getting ****ty gas mileage....but it is also running rich. I will mess with it today when she comes back from the shop.
GO BRAVES
Old 07-28-2003, 09:21 AM   #6
yeah, running rich will kill your mileage. you can dial that in though with the screws. . well you know how to do that. If it opens too early it can also run rich. Where do you have the timing set?
Old 07-28-2003, 10:12 AM   #7
fast64's Avatar
I timed it by ear (the timing mark on my block is missing AND our timing light is busted). But it is pretty damn near perfect (10 BTDC)
GO BRAVES
Old 07-28-2003, 01:26 PM   #8
yeah, 10d advance sounds pretty good. you might even try bumping it up a little more, just to see if it helps. im talking about 1 or 2 degrees tho.
as far as gas milage goes though. . you gotta remember that thing is as heavy as hell, so no matter what, if you go fast gas milage is gunna suck.
Old 07-28-2003, 02:15 PM   #9
hey fast you got 302 posts to go with your 302 block
Old 07-28-2003, 02:28 PM   #10
fast64's Avatar
They are actually extremely light, like 2600-2700 lbs. Like a civic w/ a v8 and RWD
Awesome! I ruined it now though.
GO BRAVES
Old 07-28-2003, 02:30 PM   #11
are you serious??? thats awesome!! i want one!!!
Old 10-02-2003, 08:56 AM   #12
Rick0636's Avatar
Get a holley Carb, but until then, get a good Carb man to adjust the fuel air screws on that thing, then don't touch them man!
Old 10-02-2003, 09:00 AM   #13
Rick0636's Avatar
Oh, and on the secondaries coming in with progressive linkage, yes they should come in right about or right before WOT, you should actually be able to feel like a click in the throttle when they click in.
Old 10-12-2003, 10:47 AM   #14
fast64's Avatar
holley?? carter is the way to go
GO BRAVES
Old 10-12-2003, 10:59 AM   #15
Rick0636's Avatar
Excuse me????? What Mopar man told you that?? It is even questionable among mopar people whether Carter is any good as a Carb, a lot of Chrysler people ran Holley as did Chevy people, but Holley has always been a standard among Ford people for Carbs, even the Autolite (Ford) carbs were just a poor copy of a Holley man! They Holley dual line double pump 600-750 cfm is THE carb for a small block ford, there is no question, ask anyone who knows carbed Fords.
Old 10-12-2003, 11:05 AM   #16
fast64's Avatar
you arent gonna make TONS of horsepower difference in different brands of carbs, so its no big deal. besides, its period correct.
GO BRAVES
Old 10-12-2003, 11:42 AM   #17
Rick0636's Avatar
Period correct? Yeah, maybe on a Roadrunner, or a Barracuda, just not on a Mustang or any Ford product, its totally out of place there, but there have always been people who insisted on putting things where they didn't belong, lol. No, you won't make a ton of horsepower difference, you might get it to run better though.
Old 10-12-2003, 12:19 PM   #18
fast64's Avatar
you bastard, lol
GO BRAVES
Old 10-13-2003, 03:47 AM   #19
2bbl carb.....manual linkage......opens at same time.......adjust fuel air mixture to slightly lean........when you jump on it the accelerator pump(operated by vacume) shoots some extra in to the carbs so you don't starve your engine. If you go to a 4bbl then you have to cam it and **** with the valves and fuel delivery system...but you can get a few more ponies.....like i did on my camero in the 70's. went from 250 hp to 375 hp.
OldManNewHotrod
http://images.cardomain.com/installs.../266659_16.jpg
Mods Made Thusfar:
17x9" Black Bullet rims w/Khumo ASX's 275/40/17
GT Take Off Dual Exhaust w/Dynomax Turbo's
K&N Performance Intake (FIPK)
ASP UDP
Flex's Phenolic Intake Spacer
So Cal Diablo Chip
373 Gears with Tlock
crabmeat is offline   Reply With Quote
Old 10-13-2003, 05:11 AM   #20
Danger Dude's Avatar
Get a Holley or a Demon Carb
http://www.barrygrant.com/demon/default.aspx
Old 11-11-2004, 06:30 PM   #21
Send a message via Yahoo to plstktnkr2
carter carbs
Hey Rick what do you mean Carters never came on Fords? My 66 Lincoln 'vert has an AFB on it , and it works fine
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 11-11-2004, 07:24 PM   #22
Dom
Dom's Avatar
Send a message via AIM to Dom
Hey, my dad's gotta Carter on his old 327. 11.7:1 compression ratio, Mallory Ignition, wild cam. It had 350HP before he started playing around with it. No telling what it has now.
Old 11-11-2004, 08:28 PM   #23
fast64's Avatar
someone lock this over-a-year old thread! besides, I am into fuel injection now
GO BRAVES
What size Carb saleenman 1979-1995 Mustang GT 4 10-11-2009 12:45 PM
carb size prive 1979-1995 Mustang GT 5 12-29-2008 07:22 PM
86 5.0 e.f.i. to carb need help ttyree1983 1979-1995 Mustang GT 1 05-25-2008 03:20 PM
carb help nmarlow Classic Mustangs 0 11-22-2006 07:01 PM
Carb Xvanced 1979-1995 Mustang GT 6 08-25-2004 09:35 PM
05:54 AM
