2007 Cobra SVT - Insider Info - Mustang Evolution
Old 12-10-2004, 06:25 PM   #1
KrazyPony's Avatar
http://www.muscle-mustangs.com/forum...4476#post14476
From an extremely reliable inside source at SVT (who is best friends with my sister's husband), this is supposedly the gospel of a lot of what we will see in the new Cobra. This car is already scheduled to debut at the Detroit Auto Show in January of 2006 with delivery available in mid (May/June) 2006 as a MY2007. Prototypes that are on the streets today are almost indistinguishable from other SN197's other than tires and exhaust note. There are a couple using unorthodox hood arrangements but these are supposedly not the cars with the drivetrains we will see. Here is what I was told will be the heart and soul of the next Cobra. Time will tell...
Motor: 5.4 Supercharged, 3 valve heads (with HUGE valves), forged internals similar to the 4.6 (Crank, rods, etc), modestly rated (under rated actually) ~465 HP/495 lb ft Torque, using a twin screw S/C similar to that on the Ford GT but pullied differently, hence the lower HP. This motor was supposedly made official (in house only) just in the last few days. It will NOT be rated the equal or even close HP-wise as the Ford GT exotic for exclusivity reasons. It will have more restrictive intake/exhaust systems than the Ford GT which is partly to blame for the lower performance numbers. Also, a cold air induction system will purportedly being looked at as an option but may be standard if it can get past the bean counters.
Transmissions: 6 speed manuals standard with a heavy duty 5 speed auto (the tranny used on the Ford Superduty but programmed/geared differently) as an option in late '07 or the '08 M/Y.
Suspensions: A re-engineered, heavy duty IRS will be an option with a modified 3 link/panhard bar-live axle setup as the standard rear axle. SVT will be going for the Road Race buyer as well as the straight line racer with both axles optional. However, the Axle options are not set in stone as of the moment but look highly likely to be approved. The Cobra will be lowered about 1.5" from a stock GT.
Bodywork: The retro theme will continue with a serious nod to the '67 Shelby. The fenders may be flared more than the standard '05 but that is not for certain as of now. The ducktail will be factory installed. Also, no convertible is planned for now but no reason was given other than concerns over chassis reliability due to the torque volume.
According to "John Doe" (he does not want to get 'relieved' of his assignment), only 3 of the Cobra protos built so far have the S/C'd 5.4 in them. There are actually 6 or 7 on the streets now, not all at the same time but there are similarly painted versions of different cars. There are also supposed to be three Protos with 6+ liter motors in them, 2 with blowers, one that is N/A but these will not be used in the next generation Cobra.
Supposedly, the 6+ Liter motors (he does not know the precise specs on them) are a Hurricane based engine with radical camming and a "first for Ford style of fuel delivery." I have no idea what he means by that and he would not elaborate to my sister either - apparently he was only repeating what he was told.
Tires: Alledgedly, the 5.4 S/C'd cars are running 315's on the rears, 275's on the fronts using 18" rims. Similar setups are on the other Protos. However, the 315's may only be optional with 295's being the standard fare.
Performance: The 5.4 S/C'd cars have been clocked in the very low 12's (12.10-12.25) in the quarter at nearly 120 mph and have been traction limited, according to "John". They are also supposedly able to pull over 1 G in handling.
Per "John", SVT is also adding enormous brakes and will be using an air cooled Intercooler, opting away from the water cooled version used previously due to reliability concerns (?). Other touches will possibly include some form of active/adjustable suspension as an option but he did not know much about it.
Supposedly, we should expect a price to be in the very high $30k range (base price - 6 speed, live axle, base tire/wheel combos) according to his sources in the know.
Also - prototype Mach 1's are also on the streets. These are supposedly running N/A'd 5.4's, tuned for 370hp with the 6 speed transmissions for now and debate still ongoing about which auto to use. None of the proto Mach's are running the Shaker hood to keep them cloaked to spying eyes. This car is supposed to appear for the '06 M/Y with some final tweaking to be set in stone by Jan/Feb 2005.
"John Doe" is considered to be an extremely reliable source. He said that Ford will rely heavily on already built/designed components rather than exotic pieces.
He also said that Ford is hoping to stymie the rumored F-body's comeback sales numbers with more powerful engines in the V6/GT Mustang in M/Y 2007 cars, perhaps as high as 20% increases in HP/Torque with 10-12% increases in fuel economy. If true, we could be seeing 320/325 HP GT's in 2007! Purportedly, GM is planning to use detuned LS2's in the F-bodies and Ford wants to head them off early with upgraded 3v motors.
I believe this info to be highly accurate based upon the source.
To me a v6 sounds like it might have the HPWR of the current GT's at that rate...
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 12-10-2004, 06:48 PM   #2
sweet
Old 12-10-2004, 07:00 PM   #3
Old 12-10-2004, 07:15 PM   #4
ahhh High 30's... talk about the z06 being overpriced... and fugly
Old 12-10-2004, 07:16 PM   #5
Wow...that is a perfect copy paste from what I read on SVTPerformance today. That news is making tracks. And it is great news. :drive:
Old 12-10-2004, 08:28 PM   #6
fast64's Avatar
:wstupid:
GO BRAVES
Old 12-10-2004, 09:17 PM   #7
Seph's Avatar
lame :-/
SOMEONE told me it would be 551HP.............. from this site.
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 12-10-2004, 09:22 PM   #8
lol 465 hp at less than 40k is far from lame
Old 12-10-2004, 10:19 PM   #9
Seph's Avatar
551 man! That's what I've been telling people! Now they'll say I don't know my **** and I'll look like a moron :cussing:
-Patrick
Old 12-10-2004, 10:59 PM   #10
wtf were you telling people that for to begin with... no one even knew when/if the car was going to be made before today (and it isnt confirmed)
Old 12-11-2004, 02:16 AM   #11
Seph's Avatar
I remember people sayin they ditched the Ford Lightning and started that team with the Cobra and it'd be 551 HP. Since I believe the stuff you guys say... which might be a problem.. I was tellin the guys
-Patrick
Old 12-11-2004, 08:52 AM   #12
KrazyPony's Avatar
551, you are nutz...especially from factory and once people get there hands on this one, you would see street cars up around 700hpwr streetable. Because it doesnt take much mods to make these beast get the #'s up there...
I mean right now you can take a pulley/exhaust/CAI and nice tune and you have reached the 500 mark right there with hardly any mods!
Old 12-11-2004, 09:58 AM   #13
Who said 551?
Old 12-11-2004, 10:25 AM   #14
Zim
You want to **** me?
Zim's Avatar
By the sound of it, you could probably reach 500 with just a less restrictive intake and exhaust. Then with a new pulley and a nice tune i wouldnt be suprised if these things were seen hittin the 600 mark.
I like toys
Old 12-11-2004, 10:41 AM   #15
I believe I stated 551 at one point on here somewhere. That was the rumor floating around, and I was just regurgitating the rumor. It was rumored that they were going to offer an Iced Air blast that comes from the AC unit for up to 15 second burts. It was going to come stock with 500, and the option AC blast was going to add ~50 more.
They plan to use the same engine as the GT, only detuned so that the GT remains special. From the sounds of it, it will be just like the 03/04 models in that Intake, exhaust, and chip and people are going to gain 50-75 RWHP. And then with the pulley swaps.... I think if the 450 hp model does come out, you are going to be seeing a lot of 600-650 hp mustangs out there like they were stock.
Old 12-11-2004, 10:53 AM   #16
steedav6builder's Avatar
Send a message via AIM to steedav6builder
I was tellin ppl that too. oh well.
this is where we got it from
Update on the Ford Lightening and got a little extra on the 07 Cobra!
-Gary Pics of my car
'99 Electric Green Cobra, #2517 of 4040 Built on 5/12/99
'00 Lazer Red V6-Gone but not forgotten
Central Jersey Mustangs and Fords Member #4121
Mid -Atlantic Cobra Association Member #207
steedav6builder is offline   Reply With Quote
Old 12-11-2004, 12:14 PM   #17
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
at least youll be more on that off?
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 12-11-2004, 01:10 PM   #18
I hope alot of that is correct, but to me it sounds like the planning stage where they put in all their hopes and wishes and see what ford will ACTUALLY let them get away with... the final product may be EXTREMLY different....
Old 12-11-2004, 01:58 PM   #19
Send a message via AIM to StangGt804 Send a message via Yahoo to StangGt804
I cant wait to see the price tag for this cobra!!!! Good Luck on buying one of those!!!
0H3GT
StangGt804 is offline   Reply With Quote
Old 12-11-2004, 02:34 PM   #20
I liek gramer
WhiteStang99's Avatar
I think I'm in love.
Old 12-11-2004, 02:39 PM   #21
Old 12-11-2004, 03:36 PM   #22
Seph's Avatar
Laaaaaaaaaaaaaaaaaaaaaaaame :p
SEE? I wasn't crazy, the voices in my head didn't tell me to do that. They were telling me to buy a Skyline body kit for my car and paint it bright yellow with japanese vinyl on the side. Those voices I don't listen to
-Patrick
Old 12-12-2004, 12:36 PM   #23
I liek gramer
good seph.
svt
12:41 PM
