Rear mounted Turbos.......? - Mustang Evolution
Old 12-22-2004, 02:02 AM   #1
Seph's Avatar
http://www.ststurbo.com/home
I was reading my dad's Chevy magazine and I saw this :
http://i.b5z.net/i/u/1473169/f/Press/STSCHP.pdf
They put a turbo system.. where the muffler goes....... 2: I know a lot of you guys know a crap load more about cars than I do, so please PLEASE explain how they are getting the numbers and such with the turbo mounted in the back? Check out the vids too, they are pretty sweet.
Curious if they could still put a super charger in the front, and turbo charge the back? 2:
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 12-22-2004, 03:09 AM   #2
Thomas91169's Avatar
theres 2 downsides to this setup.
turbo has lots of lag cause of the area between the turbo and engine.
the turbo takes longer to spool up cause of the length between the turbo and intake. thus it takes longer to pressurize fully.
most people look for "short route" piping when doing performance, shorter length of pipes less air needs to be moved and pressurized. especially when adding a IC because of the pressure drops associated with them.
these rear mount turbos do work though. on of the moderators over at the tccoa.com(thunderbird club of america) is doing the project right now. on a stock 4.6 V8 theyre prolly going to get a good 75hp out of 9psi. now if that engine was built and he was tuned expect to double stock numbers, possibly 400hp@14psi. and thats not even scratching the surface of the turbos abilities.
-Thomas-
Old 12-22-2004, 10:56 AM   #3
Seph's Avatar
they said the turbo will produce full boost below 3000 RPM
Could someone explain how this whole setup works though?
-Patrick
Old 12-22-2004, 11:00 AM   #4
Seph's Avatar
Aaaaaaaaaaaaaaah it makes sense now.
http://www.ststurbo.com/sts_demo
I'm going to fly an email to them and ask if they maybe do anything for Mustangs
-Patrick
Old 12-23-2004, 01:26 AM   #5
its really a DIY kit.
all you need is alotta piping, some welding, and a turbo.
-Thomas-
Old 12-23-2004, 01:31 AM   #6
i personally drag my exhaust all the time, i do not want to worry about the turbo also too easy access for honest people. everyone will find out its there. however im a little curious what the blow off valve would sound like from back there :buckteeth
cjd10 is offline   Reply With Quote
Old 12-23-2004, 02:04 AM   #7
its hard enough to install that thing with the car in the air, i dont know how long it would take someone to steal it when it was parked.
-Thomas-
Old 12-23-2004, 05:05 AM   #8
Seph's Avatar
True, but wouldn't the muffler area be the LAST place they'd look for a turbo?
-Patrick
Old 12-23-2004, 11:27 AM   #9
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
that seems sweet, do they make any thing for the stang/ can u make one yourself?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 12-23-2004, 12:49 PM   #10
Seph's Avatar
I e-mailed them about it and they said they would contact me when they start to do that
-Patrick
Old 12-23-2004, 12:52 PM   #11
Dom
Dom's Avatar
Send a message via AIM to Dom
Here's a problem. How did they get the oil lines back there?
Old 12-23-2004, 01:00 PM   #12
Seph's Avatar
watch the demo? I think it explains how it gets lubed up
-Patrick
Old 12-23-2004, 04:47 PM   #13
its odd to look at the set up...but it can be done like that if you wish....
Old 12-23-2004, 04:52 PM   #14
fast64's Avatar
i would be worried about sucking water into the engine with the air filter sitting under the back of the car
GO BRAVES
Old 12-23-2004, 05:43 PM   #15
that is a good point.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 12-24-2004, 01:57 AM   #16
Seph's Avatar
that's what I would worry about too, it has this "filter" thing you put on over the filter, but I'm not sure how well it takes care of water.
-Patrick
Old 12-24-2004, 02:13 AM   #17
nah, the setup i saw they put the fulter up through the body and into the trunk, it had its own little vent for air that came from the rear fenderwells, and its own enclsure seperate from the trunk.
plus thats the kind of setup you wouldnt drive on a rainy day anyways, prolly more of a weekend monster or a track queen.
-Thomas-
Old 12-24-2004, 04:08 PM   #18
thats too bad it sounds like i good set up, turbos are so sweet
Delta Sigma Phi
www.DeltaArmsCo.com
Got My New Turbos bluemustang Pictures and Videos 10 06-18-2007 09:28 AM
rock lights mounted up SrATEX Pictures and Videos 7 03-29-2006 08:28 PM
Rear mounted turbo? HotRod.riguez Pre-2005 V6 Mustang 9 03-14-2006 09:06 PM
New stud mounted roller rockers GT-Eater Pictures and Videos 2 09-07-2005 07:41 PM
FS OR TRADE: 18x9 replica bullit wheels *new* never mounted Suprman Mustang Parts for Sale and Wanted 8 02-01-2005 11:11 AM
07:00 PM
