4.2 kits - Mustang Evolution
Old 01-21-2005, 08:01 PM   #1
97Stallion's Avatar
4.2 kits
If I was to put together to sell brand new 4.2 V6 stroker kits which would come with a 4.2L crankshaft, 6 connecting rods, 6 pistons, and maybe a pulley depending on the year of your car. What would be a fair price for all of that. Keep in mind this would be BRAND new parts!!! BRAND new!!! I was think somewhere around $800+ shipping If you didn't want a pulley, make it $700 plus shipping. If you bought these items BRAND new from ford, this their prices:
4.2 Crank...... $259.05
4.2 Piston...... $33.66 for 1, for 6 - $201.96
4.2 C. Rod..... $65.63 for 1, for 6 - $393.78
4.2 Pulley ..... $107.63
Total - $962.42
Living one day at a time!
Old 01-21-2005, 08:05 PM   #2
01mineralgrey6's Avatar
:chin: im gonna have to think about it
-Tony
'99 cobra 'vert
Old 01-21-2005, 08:33 PM   #3
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
How hard is it to do?
Is it just bolt off and bolt back on (basicly)? or is there other things too?
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 01-21-2005, 08:44 PM   #4
97Stallion's Avatar
It's easy if you know how to rebuild engines. Nothing fancy, just pull out your engine, pull out the old pistons and crank and put the new ones in. it's that simple.
Old 01-21-2005, 08:53 PM   #5
Hmm, I can do that, not 100% about how to do the timing yet though.
Wonder how much it will cost to ship it over here :chin:
Old 01-21-2005, 08:56 PM   #6
97Stallion's Avatar
the timing is pretty much idiot proof. Your timing chain has two sprockets. And on each one there is a little dot. All you have to do it have them point at each other and your timing is set. And to make it even more idiot proof, the crankshaft and camshaft have little "keys" that the sprockets slide on, only one way might I add. So as long as you have the dots pointing at each other, you're all set.
Old 01-21-2005, 09:53 PM   #7
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
that sounds pretty cool, about how much power is gained by making it a 4.2L?
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 01-21-2005, 09:56 PM   #8
Just look at robs numbers, thats where abouts you would be i think
Old 01-21-2005, 09:57 PM   #9
timpryor's Avatar
you should have an option for forged internals
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 01-21-2005, 10:13 PM   #10
Eh the only thing I could use would be the crankshaft
I need forged pistons for a .60 overboard and forged connecting rods
Old 01-21-2005, 10:44 PM   #11
97Stallion's Avatar
I think I might be able to pull something off like have the option to buy each piece seperate at a certain cost or the whole kit for a cheaper price.
Old 01-21-2005, 10:48 PM   #12
97Stallion's Avatar
Oh ya, you could expect ~5 hp and ~30tq
Old 01-21-2005, 11:09 PM   #13
chips's Avatar
Send a message via AIM to chips
according to Ford's website, the 4.2 stroker puts out 202 horsepower and 350 foot pounds of torque.
the guys at v6f150 usually run about 160 hp to the wheels and 240-250 to the wheels on the dyno...
the only reason Dr. Dre produced "The Chronic" because the bible tells you to smoke lots of pot, and Oedipus used to blaze with the makers of Aqua Fresh tooth paste.
chips is offline   Reply With Quote
Old 01-21-2005, 11:22 PM   #14
yeah, ford likes to tell everyone BHP numbers at the Flywheel i guess
-Tony
'99 cobra 'vert
Old 01-22-2005, 12:02 AM   #15
97Stallion's Avatar
I think the 350 is WAY wrong, so you're telling me a stock 4.2 has more tq than me now? Here's what I found. You're about 100tq too high.
Engine liters 4.2
Cylinder configuration V-6
Horsepower 202-hp @ 4,800 rpm
Torque 252 lbs.-ft. @ 3,400 rpm
# of valves 12
Sequential MPI
Fuel type unleaded
Aluminum cylinder head
Ignition type electronic
Engine orientation longitudinal
Fuel economy city 17 mpg
Fuel economy highway 20 mpg
Fuel tank capacity 25 gal.
Old 01-22-2005, 12:06 AM   #16
chips's Avatar
Engine liters 4.2
the 252 is what it it gets to the wheels - not what the engine itself produces.
Old 01-22-2005, 12:08 AM   #17
so if i stroke my motor its 5hp and 30lbs tq. alota work for that.. as long as previous problems arent there i dont have to bore at all right?? boring just aint worth it to me
oh and thats not high comp pistons is it?
cjd10 is offline   Reply With Quote
Old 01-22-2005, 12:19 AM   #18
97Stallion's Avatar
Nope, that's what the engine makes. How can a 3.8 make 210-220tq stock and a 4.2 make 350tq. It's not possible. The 252 is right.
Also you don't need to bore as long as everything is fine. I didn't bore my block when I did my swap. Everything runs like a champ. The pistons are stock, I believe the compression ratio is 9.2 or 9.3:1
Old 01-22-2005, 12:22 AM   #19
chips's Avatar
why don't you read my above post...
there's a difference between how much power an engine makes, and how much it makes at the wheels.
Old 01-22-2005, 12:25 AM   #20
97Stallion's Avatar
I did read it and it still is not correct. A Stock 4.2L F-150 makes ~160rwhp and ~215rwtq. The 202 is BRAKE horsepower and the 252 is BRAKE torque which means at the flywheel, i.e what the engine makes.
Old 01-22-2005, 12:26 AM   #21
so then all you need is the crank??? or you have stock pistons from a 4.2??
Old 01-22-2005, 12:28 AM   #22
97Stallion's Avatar
You need the crank, pistons, and rods. I have all stock 4.2 stuff in my engine.
Old 01-22-2005, 12:31 AM   #23
i believe its always you im talking to when it comes to b.s. i dont know about
thank you for your help...
im taking engine repair at school now. id like to get a hold of this project(4.2) i have another car to grive. would you recomend it or say i should wait on it??
Old 01-22-2005, 12:36 AM   #24
97Stallion's Avatar
I think it's a fantastic mod to do to our 3.8's. It helps considerably close the gap on the GT's TQ wise and it also makes the engine bigger Liter wise so now you can suck in more air and use it more efficiently thus creating the 30+ tq. HP wise if you add BV heads, you will see about another 20hp gain. Finally I'm glad I can help you in anyway, shape or form.
Old 01-22-2005, 12:42 AM   #25
well tax time is here and im selling a car ontop of this so if your kits come through give me a ring. oh and my student loans wow gd jump here lol..
cjd512@yahoo.com oh and a price for p&p on uppers and lowers please
Old 01-22-2005, 12:44 AM   #26
chips's Avatar
i'll be back when i find the dyno charts...
Old 01-22-2005, 01:15 AM   #27
chips's Avatar
**** me, this may take a while... i can only find one dyno chart for a 4.2 and it's heavily modified - plus, ford no longer has the older f-150's listed on their site where i remember seeing the engine specs while looking for info on gear ratios.
oh well, i'll try again tommorow. ineed to sleep now - i gotta be at work in 5 hours
Old 01-22-2005, 02:29 AM   #28
97Stallion's Avatar
Just trust me, I'm write. As soon as you realize it, we'll both be in our happy place!!
Old 01-22-2005, 02:30 AM   #29
97Stallion's Avatar
I will keep everybody in the loop, also what year is your car?
Old 01-22-2005, 03:22 AM   #30
Ponycarman's Avatar
You are going to need new rings AND the cylinders honed at the very least.
Not to mention a gasket set.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 01-22-2005, 12:40 PM   #31
its a 00
Old 01-22-2005, 12:59 PM   #32
97Stallion's Avatar
Steve
Ya, you'll need this stuff as well, and new bearings too. I'm right now just gauging interest to offer the "hard to get stuff" the rings and bearing and all that can be gotten at any auto parts store.
Old 01-22-2005, 01:13 PM   #33
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
sounds sweet
if i may ask a "dumb" question....
what is "stroking" as pertaining to car engines? if i'm understanding right, it adjusts the cam rotation and piston position to allow more a/f into the cylinder per cycle?? or am i way off on my thought?
someone enlighten me
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 01-22-2005, 01:17 PM   #34
close stroking reffers to the stroke of the crank wich while stroking your crank will push the piston higher and draw it lower which allows more fuel and air plus changes your compression some to the higher side
Old 01-22-2005, 03:22 PM   #35
RGR
Send a message via AIM to RGR
SWEEET!!!
We need to talk Rob, if they do all this it is a great time to change the cam and get
mondo HP Tq and HP gains at the same time! Especially on a 99^ engine.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Turbo Kits? fasternu_674 Pre-2005 V6 Mustang 7 01-18-2008 01:36 PM
Black Out Kits 00BlackStang Mustang Audio & Video 5 01-14-2006 07:40 AM
99+ shift kits thirstymate Pre-2005 V6 Mustang 2 08-25-2004 11:32 AM
body kits and more*** gtstanger86 Mustang Parts for Sale and Wanted 3 06-29-2004 06:34 PM
Body Kits, Body Kits, Body Kits! *DUW* *WW* Dom Mustang Audio & Video 75 02-01-2004 07:11 PM
09:56 PM
