**** - Mustang Evolution
Old 02-14-2005, 11:57 AM   #1
wiarumas's Avatar
The mustang is at garage...needs front brakes ...the emissions did not pass. the No. 6 valve is not firing. ...so far.. $400.00..
Old 02-14-2005, 12:05 PM   #2
red herring's Avatar
Send a message via AIM to red herring
What part of emissions did you fail? If it's hydrocarbons you just need cats right? Maybe you have some unburned fuel.
red herring is offline   Reply With Quote
Old 02-14-2005, 12:07 PM   #3
Danger Dude's Avatar
do you mean #6 cylinder because if you have a valve firing I would definately be worried
Old 02-14-2005, 12:10 PM   #4
wiarumas's Avatar
haha no.. its my valves.. i special ordered them jk
the guy said he doesnt know where im not passing emissions at.. he'll get back to me tonight around 5 oclock.
Old 02-14-2005, 12:44 PM   #5
wiarumas's Avatar
this sucks.. i am seriously thinking about trading it in this summer.
Old 02-14-2005, 12:51 PM   #6
Zim
You want to **** me?
Zim's Avatar
if its gonna cost you 400 for new brakes, go get some bullitt calipers
I like toys
Old 02-14-2005, 01:30 PM   #7
But then he'll need new wheels...the costs just compile. What's wrong with your brakes? Rotors warped, pads gone..
Old 02-14-2005, 03:06 PM   #8
wiarumas's Avatar
just pads. the rest is to fix the valve/cylinder... or whatever is wrong with it. ill find out more soon.
Old 02-14-2005, 03:55 PM   #9
Kiljosh's Avatar
Is it wierd that I have to get my rotors recut almost every time I go to the shop? ( Every 8 months or so..)
Old 02-14-2005, 04:23 PM   #10
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
yes
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 02-14-2005, 04:51 PM   #11
Kiljosh's Avatar
Maybe I should chill on the braking....
Old 02-14-2005, 05:22 PM   #12
the front brakes are very easy to change
Old 02-14-2005, 05:56 PM   #13
MonteCitan's Avatar
rotors really should not be cut more than once (depending on thickness)... and when they are should be cut using an on car brake lathe to machine in hub runout...
if the mechanic is telling you the rotors need to be cut every 6 months but you don't feel any pulsation then he's full of ****..
I brake hard all the time and I'm still on original rotors with 26k miles..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-14-2005, 06:27 PM   #14
wiarumas's Avatar
ok i found out whats wrong. everything was fixed. the 6th cylinder is now operational haha, front breaks are on, new spark plugs (old ones were REALLY charred), new fuel filter (it was embarrassingly bad) and some new rear tires (i told him too because the old ones were pretty bad).
however, the emisssions are still failing. he told my dad (im still at college) that he needs to reconfigure the electronics or something? he gave my dad this huge list of things he needs to do such as.. let the car idle for 4 minutes, accelerate to 45 mph, stay above 40 mph for 6 minutes, stop and go 5 times, etc.. and he has to do this full process 6 times or something with full 6 hours breaks inbetween each run. he says this can't even guarantee it passing emissions for my next appointment in 4 days, but he won't put a sticker on it til it does.
Old 02-14-2005, 07:36 PM   #15
good luck man, i hope it all works out for you.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 02-14-2005, 07:37 PM   #16
what does you exhaust smell like?
Delta Sigma Phi
www.DeltaArmsCo.com
Old 02-14-2005, 08:09 PM   #17
wiarumas's Avatar
i think it smells normal?
Old 02-14-2005, 08:14 PM   #18
no like rotten egg smell?
Delta Sigma Phi
www.DeltaArmsCo.com
Old 02-14-2005, 08:52 PM   #19
wiarumas's Avatar
no i dont think so
Old 02-14-2005, 09:47 PM   #20
Thomas91169's Avatar
drive really hard for at least a half hour before the test. do NOT turn off the vehicle before they test it, if need be stay inside the car till its your turn to test.
-Thomas-
Old 02-14-2005, 09:51 PM   #21
wiarumas's Avatar
what does that do?
Old 02-14-2005, 10:23 PM   #22
heats up the catalytics and allows them to burn more cleanly. also gets everthing running optimum running temp.
the first time my freind smogged his car he drive it for 2 minutes around the corner to the smog station and failed. the next day i told him we should drive around for a while and take it when its fully warmed up, went and smogged and passed with flying colors.
-Thomas-
Old 02-14-2005, 11:04 PM   #23
wiarumas's Avatar
hmm.. that is probably what happened...
Old 02-14-2005, 11:05 PM   #24
Sucks for you guys that have emmissions I would be pissed off and I couldn't do what I wanted to my car because some damn tree huggin hippy
Old 02-14-2005, 11:07 PM   #25
Old 02-14-2005, 11:08 PM   #26
Hey watch it or I'll steal your dad
Old 02-14-2005, 11:44 PM   #27
Yeah, I gotta pass smog right now but ever company has trouble cause their machines suck and they can't get anything to work properly. Last time I went they read my rpm's at 8000 at idle . And they have so much trouble cause my battery is in the back. You think they'd go through this daily and have some remedy.
Old 02-15-2005, 05:24 PM   #28
I liek gramer
WhiteStang99's Avatar
or steal your story.
**** emissions.
10:17 AM
