Did Anybody's? - Mustang Evolution
Old 02-16-2005, 11:48 AM   #1
Question Did Anybody's?
car idle all wierd when they put on a upgraded mass air. When I install my custom tune & it doesn't make it better, I am sendin it back to pro-m. I heard sometimes pro-m makes defective mass-air meters.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 02-16-2005, 11:49 AM   #2
Danger Dude's Avatar
If you buy one from Pete or a actual tuner it usually comes out good
Old 02-16-2005, 12:01 PM   #3
wiarumas's Avatar
my car.. im not sure if it still does it.. but it idled real rough. it would dip and bounce up and then go back down and all kinds of crazy stuff. i think it was one of the reasons i failed my inspection.. they fixed it though.. i think.
Old 02-16-2005, 12:03 PM   #4
I know but do you think it should take care of the idle problem? When I first installed it, it seemed to run finr for a couple of months. Then as I started adding more airflow (t. body, intake plenium) the problem started getting worse, so I took it off. Now that I am gettin my custom tune downloaded, I am gonna fiddle with fuel/spark curves.
Old 02-16-2005, 12:05 PM   #5
What was it? Was your car stock or did you add parts?
Old 02-16-2005, 12:11 PM   #6
wiarumas's Avatar
it was just exhaust at the time.
i thought maybe it was because more air was LEAVING the engine than entering causing it to dip because of the bottleneck. not sure though. i think that it had something to do with the fuel filter being clogged beyond belief. once again.. not sure.
Old 02-16-2005, 01:15 PM   #7
MonteCitan's Avatar
my C&L kit didn't hurt it at all.. then again that's just a larger housing, using the same element
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-16-2005, 01:29 PM   #8
Ya C&L is way better than pro-m.
Old 02-16-2005, 01:38 PM   #9
It all depends who is programming Both C&L and pro M have their strengths and weaknesses.
Personally I would go with a Lightning or Cobra MAF and get a tune and be done with it.
Old 02-16-2005, 01:45 PM   #10
Your right, how much can you get a lightning maf for?
Old 02-16-2005, 01:56 PM   #11
Mikael at RPM has them for $180 either the 80mm or 90mm
http://www.rpm-mustangs.com/ocat/fuel.html
04:04 AM
