Help me write a scanner (of a compiler) in c++ - Mustang Evolution
Old 02-16-2005, 05:43 PM   #1
i cant get a stupid getline string class function to work... its got a but in it from MS imagine that.....
is there another way to read an entire line or XX items and store htem into a string wiht out worrying about the extra garbage you get from the mess up with the get line function.
i try :
getline(inputsource, string);
and inputsource.getline(character array, size to read in)
neither work right....
Old 02-16-2005, 06:04 PM   #2
meteorachick's Avatar
my really good friend knows c++ and I showed him that...he said he would prolly know the answer if he knew what OS and compiler ur using....
so let me know and i'll relay the info to him
Modified 2004 V6
Old 02-16-2005, 06:07 PM   #3
oh he said to try cin.getline (variable,256); name and byte length are whatever u need
Modified 2004 V6
Old 02-16-2005, 06:39 PM   #4
i tried that, its still doing the same problem, im using Microsoft visual 6.0 professional c++
what i am having issues with is the following....
I am getting an entire line from a text file, I am thing breaking the string up letter by letter with...
string.substr(start position, end position)
// end pos is 1 in this case to just get a single letter.
im storing this letter into a buffer or what not and adding each new character to this buffer as well, so i am building a word.
then when i find a given letter such as a ; or a : or a = sign i stop building my word and i will have a complete word in my buffer.
the problem is when i read the very last word on a line when there is NOTHING after the last letter it will take that word i just built and not treat it properly.
every time i find a complete word i print it to a file with the line it was found on, the last word in a line wiht nothing after the word shows up as comming from the next line.... i increment my line counter at the very bottom of my loop so it has no link to this... its just an issue with getline i belive.
if i add a space or a ; or a : or any of my special characters after the last letter in the word it works perfectly, its only when there is Nothing after the last letter in the last word on the line i have issues.
Old 02-16-2005, 06:47 PM   #5
okay this is what he said:
him: MSVC++ 6 has an issue with the getline function
him: he could set his character to check for to be the newline character
him: beyond that
him: i hate C++
so sorry if this doesn't help, but i did my best (well rather, my friend did his best, i know nothing about c++)
Modified 2004 V6
Old 02-16-2005, 10:33 PM   #6
lol I have done assembly, ada, fortran, pascal, java, javascripe, etc... they all suck in their own way...
I just added a space to the end to fix the issue...... this would have never happend in a non MS compiler... i have no choice it has to compile in ms and run...
Matco Pro Scan plus, scanner Otlaw80 Mustang Parts for Sale and Wanted 8 07-23-2009 10:19 AM
How to write good n8r The Bar 7 12-23-2006 10:38 PM
Need A Write-Up MyStangStanks Pre-2005 V6 Mustang 10 11-20-2006 12:06 PM
What is the best Virus Scanner? Kiljosh The Bar 22 05-18-2006 09:10 AM
NYC Police scanner n8r The Bar 5 06-20-2004 09:28 PM
04:28 AM
