mod plans for summer - Mustang Evolution
Old 02-24-2005, 06:36 PM   #1
Tbird232ci's Avatar
i was sitting back and thinking about what id like to get done to my cars this summer, wondering what everyone else was planning on doing also
with my TC:
-get a garrett T3 on it (friend has one for me)
-front mount intercooler
-22psi
-a better BOV, probably be better off running a BPV with a front mount since its a metered system
-a proper cold air intake (routed in front of the radiator support)
-full 3" exhaust
-adjustable fuel presure regulator (can be done very cheap, using factory parts)
-walbro 225lpm high pressure fuel pump
for my red one:
-gather 5.0 parts
-clean it inside and out
-cover it
Old 02-24-2005, 06:37 PM   #2
fast64's Avatar
paint, interior, rims, tires, and brakes. and anything else i break
GO BRAVES
Old 02-24-2005, 06:50 PM   #3
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
well im thinking about keeping the car, so first would deff be a t-lok, 4.10, and chip after that i would *wish* about putting in a t-5
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 02-24-2005, 06:58 PM   #4
Fishers Stang's Avatar
read sig
Charles
Old 02-24-2005, 08:36 PM   #5
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
Hopefully a 8.8" with 4.10 since I'm broke
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 02-24-2005, 08:40 PM   #6
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I'm working on getting a MM coil over kit for my steed.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 02-24-2005, 08:54 PM   #7
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
I need to get that darn supercharger in and throw 400 ponies to the ground
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 02-25-2005, 01:22 AM   #8
Thomas91169's Avatar
this month - get the fmic in, weld up the pipes and get them powdercoated red
next month - get the eco3 ported exhaust mannifold, get prothane motor mounts, and hopefully a 3" downpipe and cat delete.
before summer - start a whole new back seat box(again) that will be a little different, but will be stronger(dads getting some resin from work, he works for locheed) and will have some metal bars going through it so it doesnt warp on me when its NOT in the car getting worked on.
also before summer - eibach lowering springs and tokico shocks.
-Thomas-
Old 02-25-2005, 09:49 AM   #9
Kiljosh's Avatar
Switch to 4.10s
Get tires and put my rims on
Kit
Paint
Maybe new exhaust
Old 02-25-2005, 09:58 AM   #10
Ford C-springs
Mach 1 chin spoiler
Grill delete
Get my freaking stereo finished
Old 02-25-2005, 10:02 AM   #11
BlackStang99's Avatar
Send a message via AIM to BlackStang99
Windows tinted
Rims, hopefully (depending on if and when i get a job...) or
New headlights
http://www.mustangevolution.com/gall...ang99-sig3.jpg
Originally Posted by n8r
jack, jhack, it sounds the same, because the H is silent!
BlackStang99 is offline   Reply With Quote
Old 02-25-2005, 10:28 AM   #12
Bane-'s Avatar
new interior from carpet up
minor bolt ons for now (exhaust, underdrive pullies, cai, etc)
Old 02-25-2005, 10:31 AM   #13
Kiljosh's Avatar
That reminds me, I have to make a box for my sub too...
What does everyone think of a Single port box, covered in like Black vinyl or Black/Grey carpet with brushed aluminum pieces that look like L's that I'm going to screw in on the sides? Red neon in the box witha plexiglass front?
Old 02-25-2005, 10:32 AM   #14
Hm...It'll work...
I got a friend building me a custom fiberglass box to my specs for my trunk..gonna tuck a sub on each side and build an amp rack directly below my rear deck.
Old 02-25-2005, 02:12 PM   #15
wiarumas's Avatar
*points to sig*
after that im done. then i start saving for a cobra when i graduate.
Old 02-25-2005, 04:01 PM   #16
timpryor's Avatar
save for next car
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 02-25-2005, 04:07 PM   #17
timpryor's Avatar
Save for next car will be were most of my money goes but the rest will be getting a predator
Old 02-25-2005, 04:17 PM   #18
Hoover's Avatar
Send a message via AIM to Hoover
Bought a 5.4 liter,
Been bored over .20
still undecided on the rest, but thinkin about blowin it.
Hoover is offline   Reply With Quote
Old 02-25-2005, 04:20 PM   #19
1997grnstang's Avatar
Send a message via AIM to 1997grnstang
gears
tlok
springs maybe?
i need to save up some money
http://www.mustangevolution.com/gall...oveoneclub.jpg
My Car
1997 Pacific Green Mustang
5-speed
1997grnstang is offline   Reply With Quote
Old 02-25-2005, 04:37 PM   #20
Originally Posted by Hoover
Bought a 5.4 liter,
Been bored over .20
Blow it definitely...you'll always wonder what it would be like blown...just run around 10PSI and you'll have more power than you'll ever need...
Old 02-25-2005, 04:44 PM   #21
Hoover's Avatar
I really want to, believe me. Since this is doubling as my daily driver I am still up in th air.
Old 02-25-2005, 04:47 PM   #22
My roommate's uncle did the 5.4 swap to his 01 GT and supercharged it and had it for his daily driver for a whiile before someone offered him double what he had in it...
Old 02-25-2005, 04:54 PM   #23
Hoover's Avatar
Well that didnt take a lot of convincing, looks like I am going to blow it. What kind of blower did he go with?
Sorry, I didnt mean to hi-jack the thread.
Old 02-25-2005, 05:01 PM   #24
My roommate said he'll ask hiim next time they talk...it was twin screw, I can tell you that much.
Old 02-25-2005, 06:17 PM   #25
Hoover's Avatar
That is what I was looking to go with. I want an Eaton, I think they look the best too.
Old 02-25-2005, 09:28 PM   #26
timpryor's Avatar
hoover kiss traction goodbye
*cough*KenneBell*cough*
Old 02-25-2005, 09:43 PM   #27
I am hoping this summer is going to be badass. Get my engine in and running smooth and me and some friends hit the beach in July for a week and just chill
Old 02-26-2005, 08:51 AM   #28
Hoover's Avatar
Yeah that's what my friend who works at a local speed shop told me.
I read an article in this Mag I got, about the difference between KenneBell and Eaton and some other Supercharger, I forgot the name. There was not much of a difference in performance, except the non-twin screw produced a little more power. So if there is little to no difference in performance, what are the advantages of a KenneBell vs. an Eaton????
Anyone with summer mod plans? PureVenom General Mustang Discussion 36 06-21-2010 06:44 AM
New Plans nyalsdgt General Mustang Discussion 9 01-25-2010 03:43 PM
Plans for the 85... Bane- 1979-1995 Mustang GT 0 10-26-2007 10:07 AM
got some plans! whipster24 Pictures and Videos 7 09-22-2004 04:58 PM
hello....summer? Rellik The Bar 18 08-04-2003 04:48 PM
12:49 AM
