Potato Gun - Mustang Evolution
Old 02-27-2005, 04:20 PM   #1
red herring's Avatar
Send a message via AIM to red herring
Potato Gun
Well, everybody has made them right? So my friends and I decided we wanted to make a really nice one with some major power. Here's what we did: we began on our journey by making the gun out of steel, not pvc. We put it together and decided that if we wanted a good boom, we should use something better than a flint. Subsequently we made our potato gun have a spark plug to ignite our fuel. So what's next, fuel itself. We didn't want to use hairspray cause we wanted something more powerful; therefore we decided to use gasoline. Now, we need to get power to our spark plug to ignite the gasoline...a car battery we decided on just because we were using everything else from a car. What a powerful spark we got. However, now we need the fuel to atomize because the gas is saturating the spark plug. Anybody have any ideas on how I can utilize an injector for this thing? As it is right now it's still mobile, but even if it wasn't that's ok...it's more of a potato cannon now anyway. But even then if I want all of this to work properly I may need a distributor. Think I'll be done after that? I wont need anything to charge the battery nor will I need anything similar to a fuel pump cause I have other ideas for that. I think I should have just taken the heads off of the maxima in my backyard and stuck a tube down the combustion chamber and called it a potato gun...
red herring is offline   Reply With Quote
Old 02-27-2005, 04:31 PM   #2
Kiljosh's Avatar
Just get a taser and put it in the gun, you cant beat a spark that is 2 inches long.
As for gasoline, I don't know about that. I mean it's powerful but if it's all for a tater gun than I think it'll just be a headache. Get a propane tank, regulator, and 1 way valve. Just turn it on for like 5 seconds, then close it and hit the taser.
Me and my friends have launched potatoes across a lake about a 1/2 mile wide and hit houses with the thing. Just a 2 inch barrel, 5 inch combustion chamber, and a cap. Cheap and fun.
Old 02-27-2005, 04:37 PM   #3
Thomas91169's Avatar
^^^exactly. its almost impossible to get the right mixture with gas in a potato gun. propane would be your best bet. get some valves and fittings and make a bracket that holds the little propane bottles to the side.
i have some 2.5" steel piping leftover. i think i might either make a really cool bong or a potato gun.
-Thomas-
Old 02-27-2005, 04:48 PM   #4
Kiljosh's Avatar
Hehe, yea...
If you search around online they have plans to build a gun that'll launch a FULL potatoe up to a mile. Cost about 200 bucks to make the whole system.
Old 02-27-2005, 05:01 PM   #5
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
Hmm, never tried to make one, guess I got to
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 02-27-2005, 05:05 PM   #6
those things are fun
Old 02-27-2005, 05:41 PM   #7
Stangthang's Avatar
Forget the propane.
Get a cutting torch, and give it 5 sec of Acetylene then 2 shots from the oxygen .
You better have a good sealed beefy *** potato canon because this is highly dangerous.
Believe me I know.
Stangthang is offline   Reply With Quote
Old 02-27-2005, 07:19 PM   #8
Originally Posted by Stangthang
Forget the propane.
Believe me I know.
I imagine yours blew up? How can I make mine better? Shooting a 1/2 mile to a mile would keep me satisfied. Perhaps I'll take a look at what you guys are talking about.
Old 02-27-2005, 07:40 PM   #9
fast64's Avatar
the physics class at school is building a twin-chambered compressed air powered gun, all i have to say is wow.
GO BRAVES
Old 02-27-2005, 09:13 PM   #10
Hoover's Avatar
Send a message via AIM to Hoover
I know this may not be much help, or produce the desired spark. What my friends and I used to use were those igniters from gas grills, drill a hole glue or screw that puppy in there and just press the button. Not sure if it will work for your particular application, but it could be a cheap fix.
Hoover is offline   Reply With Quote
Old 02-27-2005, 09:32 PM   #11
bluemustang's Avatar
I had that type of results by using Axe Body spray. just using two metal screws and a grill lighter. Works real nice and alot better wit the propane
But ours is like a good 5 ft in stance. its more along the lines of a spun cannon
Old 02-28-2005, 02:24 PM   #12
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
We need potato gun videos
Rellik is offline   Reply With Quote
Old 02-28-2005, 02:37 PM   #13
steedav6builder's Avatar
Send a message via AIM to steedav6builder
what i did when i made one was to drill a hole in it and pull a tire valve stem through the hole. Then you can put the gas in it and compress the air with a compressor like a car engine and BOOOOOOM! I did the spark plug thing too, I just hooked the spark plug up to the wire on a weed wacker and pulled the rope to get spark.
-Gary Pics of my car
'99 Electric Green Cobra, #2517 of 4040 Built on 5/12/99
'00 Lazer Red V6-Gone but not forgotten
Central Jersey Mustangs and Fords Member #4121
Mid -Atlantic Cobra Association Member #207
steedav6builder is offline   Reply With Quote
Old 02-28-2005, 02:42 PM   #14
Remember, a BBQ spark igniter is an easy screw on,push button instant spark that will suffice to ignite a volotile liquid or gas.
Old 02-28-2005, 04:52 PM   #15
I liek gramer
WhiteStang99's Avatar
BBQ lighters are also fun with friends!
Old 02-28-2005, 06:14 PM   #16
Kiljosh's Avatar
Shock em in the back of the neck or behind the ears with em Whitestang lol.
The gril lighters work but I think they fail after awhile from all the gnk that gets built up on em. I tried the two screws thing and that stopped two because of gunk.
You just gotta find the perfect mix of power and non-gunkiness and you'll have your fuel.
Propane is awesome seriously, I'm gonna get a pic of my gun tomorrow or the next day and then maybe a vid of it shooting. Despending on this weather...
Old 02-28-2005, 06:21 PM   #17
yeah videos would be awesome
there are some pretty good ideas on here that I'm going to have to look in to. Thanks for the responses guys.
Old 02-28-2005, 06:22 PM   #18
i like this idea, haha
Old 02-28-2005, 06:41 PM   #19
http://www.albinoblacksheep.com/flash/taters.php
Old 02-28-2005, 06:45 PM   #20
You couldn't get it to pull up on the site nate? You suck
Old 02-28-2005, 06:47 PM   #21
Originally Posted by n8r
I wish I could see that, albinoblacksheep never loads correctly for me
Old 02-28-2005, 06:50 PM   #22
If it's what I think it is it's dude off of Lord of the Rings saying Po TA To
Old 02-28-2005, 06:57 PM   #23
I thought it was going to be some crazy video of some indestructable potato gun that launches em off like no other...that sucks if it's only some guy saying potato
Old 02-28-2005, 07:19 PM   #24
its a tecno flash of the potatos, i couldnt find just the freakin gif
Old 03-02-2005, 12:57 AM   #25
silverstangboy's Avatar
didn't read all of these, but a particularly good propellant is PCV glue
just have to let it set for a while
hair spray is defininetly more powerful than gasoline... just look at the ingredients
93 mustang notch
~450hp 331 stroker - Sold
Brent's Got A Gun Brent Pictures and Videos 34 07-14-2008 03:13 PM
What I want my gun collection to look like Brent Pictures and Videos 22 03-27-2008 05:14 PM
Paint Gun steedav6builder The Bar 7 02-08-2005 09:37 PM
potato cannon STEVE The Bar 18 07-05-2004 10:48 PM
07:15 PM
