03-16-2005, 08:30 PM
#1 | | Senior Member
| my car rocks now!
after all this *****ing and complaining about my wastegate needing changing, i decided to go out and try to change it with the turbo still in the car
all went well, other than this stupid as E clip i couldnt see, and could barely touch
i swapped wastegates, bypassed my boost controll selenoid, and took it for a test drive
i roll up into 3rd gear, i floor it, the gauge reads 3-4psi, then slams down to 17psi
the car is badass now, it pulls like never before, the car screams, the exhaust note is more aggressive, it burns the tires off through first and second gear from a slow roll, its just a night and day difference
tomorrow im getting a K&N filter that mounts right on my VAM and eliminating the airbox
03-16-2005, 08:33 PM
#2 | | Registered User
#3 | | Legacy Member
Nice |
03-16-2005, 08:34 PM
#4 | | I liek gramer
awesome.
#5 | | Registered User
sounds awesome
__________________ |
03-16-2005, 08:35 PM
#6 | | Legacy Member
next step... spinners.
03-16-2005, 09:14 PM
#7 | | Senior Member
i want a spinner air filter, that when the air comes in, the rim on the top of it spins
BLANG BLANG!
03-16-2005, 10:09 PM
#8 | | You want to **** me?
what numbers do the turbo birds put down?
__________________ I like toys |
03-17-2005, 02:24 AM
#9 | | Registered User
so is a turbo bird shorthand TTBird? and a twin turbo bird a TTTBird?
93 mustang notch
~450hp 331 stroker - Sold
03-17-2005, 03:26 AM
#10 | | Legacy Member
sweeeeeeeeet.
-Thomas-
03-17-2005, 05:05 AM
#11 | | Legacy Member
wahhoooo
about time you got it fixed, you slacker
__________________ 2012 IS F Blue IS F Sport 2006 Mustang V6 wannabe
03-17-2005, 07:31 AM
#12 | | Registered User
cool to hear that it worked out!!
-Tony
'99 cobra 'vert
03-17-2005, 08:18 AM
#13 | | Legacy Member
yay now i have some competition
'04 Roush F150 ( totalled while parked  )
03-17-2005, 10:21 AM
#14 | | Senior Member
stock, theyre supposed to put down 190 at the flywheel in a 5-speed car (auto's got detuned), in 87, motortrend said they got a 16.3 out of one at the track, but my friend had a low mile one, bone stock, and got a 15.88 out of it
as of tonight, with my open downpipe, added boost, and eliminated airbox (thing looks like a kitchen utensil), i should have 190-200 at the wheels
not bad for free mods other than the K&N, which im getting for 15 bucks
03-17-2005, 11:17 AM
#15 | | Registered User
nice man.
__________________  1989 5.0 - Mustang Brandy the NOW It can Barely Idle B**ch   1999 Jeep Cherokee Sport 4.0 - Yeah Its Gotta Baby Dick Lift |
03-17-2005, 11:31 AM
#16 | | Terminator Owner
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
03-17-2005, 09:26 PM
#17 | | Senior Member
the K&N is on the car...that is another amazing difference all in its own, the turbo spools up so fast now
next is a BOV and exhaust, if the turbo spools fast now, i imagine that a 3" exhaust will be crazy
03-17-2005, 09:47 PM
#18 | | Registered User
| Quote: |
Originally Posted by Tbird232ci the K&N is on the car...that is another amazing difference all in its own, the turbo spools up so fast now
next is a BOV and exhaust, if the turbo spools fast now, i imagine that a 3" exhaust will be crazy | that hawt :yup:
Go for the exhuast :yup:
03-18-2005, 09:37 AM
#19 | | Senior Member
i gotta start saving for that, its not too expensive, a downpipe is 100 bucks or so, i need two 45* bends, a muffler, and ill use a 2.5" tailpipe untill i get a 3" fabbed, shouldnt be more than 350 bucks, but its more than i have
in first gear, at light throttle, the thing already makes 2-3psi, i gotta relearn how to drive this thing, from a roll in first, it goes sideways, and stays sideways untill i grab third
03-18-2005, 10:07 AM
#20 | | Registered User
That reminds me of a porting job I did for a friend of mine,
had a decent looking 2.3 OHC head, I ported it for him
and he was getting it re-built, and the mag'ed it and it was cracked!
All that work for nothing...
Get the head checked before you get any porting done TBird man!
__________________ Originally Posted by Flex:
You are the true cam master dude... |
03-18-2005, 04:53 PM
#21 | | Senior Member
funny you mention that
i was talking with a buddy of mine, he pulled his head, had it mag'd, and it showed a crack, since it didnt leak, didnt have any problems, he had it ported anyways, he ran that untill he parted the car out
apparantly these heads crack in "non-fatal" area's, and dont show any problems
if i have one ported, id grab an N/A head, since theyre similar castings, and work with that, since they have less cylinder pressure, and heat to deal with, having a turbo bolted to the head adds much more heat to it
03-19-2005, 05:28 AM
#22 | | Registered User
Hmmm, maybe this would be OK too, but I forget where the crack was.
It was off an NA car though, odd that it would be cracked!
03-19-2005, 08:52 PM
#23 | | Senior Member
its in the castings with these heads, they just get weak in area's and crack, same thing with the exhaust manifolds, but guys dont have any leaking issues
guess it depends on the severity and location of the crack
03-20-2005, 10:11 PM
#24 | | Registered User
I think 2.3's do that alot or something, mine did the same thing, n/a useless 88 hp
93 mustang notch
03-21-2005, 06:05 AM
#25 | | Registered User
I'm sure there are better years, the mini stock guys run them up over 200 BHP
and race them pretty hard.
