Update on project "Big Block Six" - Mustang Evolution
Old 08-04-2003, 09:16 PM   #1
Send a message via Yahoo to plstktnkr2
engine block is done and with 4.2 kit and .030 overbore it works it out to a 4.3 and 257 cid +or _ a couple. tech helping me thinks its ironic that my stang is almost the same displacement as his '64 1/2 289
LOL
rick
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 08-04-2003, 09:18 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Sweet, did u take any pics of the project??
Id love to see iam doing something similar.
I want to make my block 4.2l with a overbore.
Any info and pics and anything would be awesome
Rellik is offline   Reply With Quote
Old 08-05-2003, 07:03 AM   #3
I will be taking pictures and making notes as soon as assembly takes place. All parts notes will be detailed as to what parts need to be changed ,and where I found them . Also, with this i'm doing an AOD trans with fresh rebuild and B&M shift kit with B&M converter (mild not a high stall. 500RPM's over stock stall speed. with an 8.8 equiped with 3.27 gears and posi when done.
[SIGPIC][/SIGP
Old 08-05-2003, 07:13 AM   #4
Ken
Ken's Avatar
Region: New Hampshire
why sticking with a 3.27?
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
Old 08-05-2003, 08:44 AM   #5
tire's Avatar
Send a message via AIM to tire
i'm curious about why'd you stick with 3.27's as well.
is the 4.2L without the .030" bore and that makes the .1L difference?
tire is offline   Reply With Quote
Old 08-05-2003, 08:34 PM   #6
bb6
ok 'vert your first... I'm sticking with 3.27's because this car will see lots of highway use hence the AOD with 3.27's . gas milage is an issue.
powerstang... yes the overbore gains about a tenth of 1 liter over six barrels. crazy huh?
[SIGPIC][/SIGP
Old 08-05-2003, 08:49 PM   #7
Ken
Ken's Avatar
I get the gas mileage arugment... kinda...
Before my 4.10's I was getting 20-21mpg now I get about 18mpg.. but have seen 20 if I go easy...
the difference between the 3.27's and 4.10's is worth the extra $1 per tank to me!
Old 08-05-2003, 10:12 PM   #8
tire's Avatar
is it a mustang block or supercoupe? what year?
eventually i'll take a supercoupe block and built up from there. i'll probably have to bore it as well but i'd like to get away with not doing it. i'd be scared stroking it more than 4.2L because of the high boost at low rpms that i'll be seeing. i'm trying to build a torque monster. hopefully a good starting point for a badass autox car.
i'd like to hear waaay more info if just for good reading.
Old 08-05-2003, 10:17 PM   #9
I would love to hear adn read about your boring out process.
Old 08-05-2003, 11:21 PM   #10
tire's Avatar
hjahahha when you said "boring" i thought you were being a sarcastic #### to him about how dull it was.
Old 08-06-2003, 06:02 AM   #11
Ok power stang your first: The engine I'm using is a 1987 unit out of a standard T-Bird, due to the more efficient design of the '84 head using the "heart-shaped" combustion chamber, and since my car is pre-FI, the standard or a higher volume fuel pump is a bolt-on no brainer. Also with this configuration I can use the same belt system as came with my car ('83 stang conv). The internals will be a bolt in process(also no "oil -slinger" on crank). My block has been mag-fluxed,align-honed with all new cam bearings, and deck has been machined and all gasket faces trued and had the oil and grease cooked out. The reason the block was bored was due to a faulty head gasket letting water lay in the chambers on a couple of cylinders so to clean it out it was machined out.
[SIGPIC][/SIGP
Old 08-06-2003, 06:11 AM   #12
99 vert: This car will be "used" not a garage princess, and will be used on a daily basis to go wherever I go. This also means driving it on lots of interstates due to the rural nature of where I live. (and based on wear and tear of engine parts) Another consideration is that my lady and I spend $80.00 just on going to work each week just in fuel alone for 2 cars. Coupled with maintenance(oil changes,fluids,filters,tires) you get the Idea. With all the "young" dudes on here the words "mortgage,kids,health care costs and things of this nature", don't mean much yet. LOL
rick
peace
[SIGPIC][/SIGP
Old 03-16-2006, 01:20 PM   #13
RGR
Send a message via AIM to RGR
Re: Update on project "Big Block Six"
Updates Rick???
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-18-2006, 09:49 AM   #14
Bane-'s Avatar
nice lets see some pics
but hows a 257 the same as a 289 haha, the 289's are 4.7L i believe.
Old 03-20-2006, 08:54 AM   #15
RGR
When I built Jose's I calculated it to be exactly 260 cubes...
30 over w/4.2 crank.
Old 03-21-2006, 05:12 AM   #16
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
holy moses, welcome to 3 years ago.. lol
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Old 03-21-2006, 08:18 AM   #17
RGR
The point is he's not finished!
Part of the "Big News" is complete Brent The Bar 30 12-04-2006 11:27 AM
My HCI swap for "Project TONY" RGR Pre-2005 V6 Mustang 13 03-27-2006 09:35 AM
Radio talk show host calls Condi a "big coon" WhiteStang99 The Bar 14 03-23-2006 12:20 PM
latest little "project" Tbird232ci Pictures and Videos 10 03-21-2006 07:27 PM
8sec 89 Big Block Coupe 10.5" tire class car Jayber Mustangs for Sale and Wanted 5 08-05-2004 03:20 PM
12:58 AM
