anyone know anything about small engines (as in lawnmowers, not hondas) - Mustang Evolution
Old 05-08-2005, 03:51 PM   #1
fast64's Avatar
my mclane reel mower has a little B&S 3.5hp motor on it that isn't getting fuel. I am pretty sure of this b/c it will only run when i spray starting fluid into the carb and have the carb completely choked. even then it will only run until all the starting fluid is burnt up. anyone have any suggestions?
GO BRAVES
Old 05-08-2005, 05:28 PM   #2
Kiljosh's Avatar
Clean the lines? Get a new high flow carb? :p
Old 05-08-2005, 05:33 PM   #3
Ponycarman's Avatar
Either the lines, the filter (if it has 0ne) or the bowl is clogged.
I would unscrew the bowl from the bottom of the carb and dump out whatever is int here. Sometimes water will get into your gas and it, being heavier that gas, will fill the bowl and the engine will not run.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 05-09-2005, 04:56 PM   #4
Thomas91169's Avatar
you mean theres a difference in lawnmowers and honda engines?
sure? cause they both sound the same.
-Thomas-
Old 05-09-2005, 05:11 PM   #5
steedav6builder's Avatar
Send a message via AIM to steedav6builder
this is what i do all day, sad i know. I'd say the jet is prob cloged int the carb or the float is stuck in the carb. Take the bolt out of the bottom of the carb being careful not to ruin the bowl gasket and pull it down. Make sure there is no water in it and that the little holes in the bolt/jet are clear. If they are then pull the pin that holds the float out and pull the float and needle down out of it. Spray throught everything with carb cleaner and put it back together and you should be set.
-Gary Pics of my car
'99 Electric Green Cobra, #2517 of 4040 Built on 5/12/99
'00 Lazer Red V6-Gone but not forgotten
Central Jersey Mustangs and Fords Member #4121
Mid -Atlantic Cobra Association Member #207
steedav6builder is offline   Reply With Quote
Old 05-09-2005, 07:06 PM   #6
fast64's Avatar
thanks, i will try that next time i have some time to work on it.
GO BRAVES
Old 05-10-2005, 08:46 AM   #7
You should be able to get a carb rebuild kit for next to nothing that will have all new parts and once cleaned that should fix it.
AlmostN8 is offline   Reply With Quote
Old 05-10-2005, 08:56 AM   #8
Danger Dude's Avatar
Actually if it has sat up over the winter with fuel in it Varnish and gunk have formed in the float bowl. take the float bowl off clean it and spray carb cleaner into the carb. Reassemble and put on a new spark plug and get it cutting grass BY GOD
Old 05-10-2005, 12:42 PM   #9
fast64's Avatar
mowed the lawn last week. winter rye owns me.
GO BRAVES
HONDAS 00STANG00 The Bar 20 10-28-2009 07:51 AM
Engines... Firewolf Pre-2005 V6 Mustang 12 10-09-2009 11:07 PM
Silly Hondas Bane- Pre-2005 V6 Mustang 58 01-25-2005 08:06 PM
Fast Hondas? Dom The Bar 16 10-25-2004 06:48 AM
Funny vid(makes fun of hondas) 01mineralgrey6 The Bar 2 10-25-2003 09:46 PM
09:08 PM
