My clutch works again. WOOT!!! - Mustang Evolution
Old 05-11-2005, 09:07 AM   #1
Well, the new clutch is finally installed. Talk about night and day difference. I don't know how many of you have used the clutch in an 03 cobra, but that sucker was very stiff and it took nearly full to the floor to completely disengage. Well, the new SPEC Stage 3 with UPR quadrant, adjustable cable, and firewall adjuster is not even close to that. Pedal effort is rediculously light, it takes about 1.5 inches of travel to completely disengage, and it doesn't slip.
Now to see if I can make it the 450 break in miles required by SPEC without hammering on it. Only 60 so far...but I Think around 300 or so, I am going to get antsy.
I will post pics of my old flywheel and pressure plate later. You have to see these things. Talk about roasted.
Ok, carry on.
Old 05-11-2005, 09:55 AM   #2
I just put a 5spd in my car with a spec stage 2....learning to drive stick on a stage 2 is interesting...
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 05-11-2005, 10:44 AM   #3
did you use the POS spec throwout bearing... did you at least CHANGE the bearing lol?
Old 05-11-2005, 10:49 AM   #4
The only thing that is stock is the location bewteen the engine and tranny. Everything inside the clutch has been replaced. The TOB, the flywheel, the clutch, the pressure plate, everything. No half assing on this car.
And stangin99, yeah, learning to drive with the state 3 is rather interesting as well...specially with the steel flywheel that takes a little more rpm than the aluminum one would have.
EDIT, and before you reply SpectorV, the stock TOB on the cobra is a POS. There is even an TSB for it that it will **** the bed. THe spec one is 100% better than the stock one in the cobra.
Old 05-11-2005, 10:51 AM   #5
what brand TB did you use? the spec ones are known to go bad VERY quick... im very paranoid about TB's Ive went though ... this will be 5... and I DONT abuse my clutch or anything...
Old 05-11-2005, 11:13 AM   #6
The 100% better than stock Spec one....the stock one on teh cobra sucks. The spec one is better. So, I moved up. If it goes, then I will replace it with something better. But, since it is better than the stock one, I used it.
Old 05-11-2005, 12:39 PM   #7
Spector, are you talking about the old palstic TOB that Spec used to use or the new metal ones?
AFAIK Spec started using OEM metal TOB's with their mustang kits because their cheapo plastic ones were such crap.
New Hottness
1999 V6 5-speed
Wrecked
Old 05-11-2005, 12:40 PM   #8
I liek gramer
WhiteStang99's Avatar
sweet. see you on the way to FL then.
Old 05-12-2005, 03:38 PM   #9
Ok, carry on.
awesome, now that your car is back, time to bring it to state capital for a few passes down the 1/4
i'll probably be going back within the next month or so
Kyle is offline   Reply With Quote
So who here works out? Brent The Bar 37 12-08-2005 08:03 PM
woot woot tires STEVE Pictures and Videos 18 07-12-2005 08:49 PM
woot woot GT rear bumper is IN jimmy_beaner The Bar 18 06-03-2005 08:31 PM
woot woot for photography class fast64 The Bar 17 11-05-2003 06:53 PM
How ######### Works tire The Bar 2 08-07-2003 11:11 PM
07:11 PM
