gear poll... - Mustang Evolution
View Poll Results: what gears should I get in my new rear end?
STOCK: 3.27 ratio 0 0%
MACH 1: 3.55 ratio 1 9.09%
impressive: 3.73 ratio 8 72.73%
stfu noob 2 18.18%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Old 05-13-2005, 11:22 PM   #1
jimmy_beaner's Avatar
Region: Iowa
gear poll...
this is for the rear end I'm hopefully ordering TOMORROW.... do I stay stock 3.27.... go Mach 1 gearing at 3.55.... go 3.73..... or just stfu noob, lol. Keep in mind, yes, I have an auto.... yes, I also do A LOT of highway driving. Although, it would be nice to get some nicer gears. I'm leaning 3.55
Old 05-13-2005, 11:23 PM   #2
3.73's wouldnt be bad on the highway. i would go 3.73's w/ t-loc
Kyle is offline   Reply With Quote
Old 05-13-2005, 11:25 PM   #3
Region: Iowa
it has t-lok... it's an 8.8"
Old 05-13-2005, 11:25 PM   #4
Kiljosh's Avatar
3.73's with the tlok or else your a noob.
so stfu noob lol
jk
Old 05-13-2005, 11:25 PM   #5
.but i really wanted to put stfu noob.
Old 05-13-2005, 11:27 PM   #6
Region: Iowa
you can vote for more than one.... now who's the noob (is that an owned?)
also, I do A LOT of highway driving... so while everyone votes 3.73, I still may get what I want
Old 05-13-2005, 11:27 PM   #7
well then............................3.73's. its gonna be a little higher obiviously than stock, but not so to where it'll kill you w/ gas.
in the end, 3.73's
Old 05-13-2005, 11:29 PM   #8
Region: Iowa
in the end, 3.73's
in the rear.... in the rear . I don't know... anyone on here have an auto with 3.73's? I will not get 4.10's. What kind of gas mileage you guys have with 3.73?
Old 05-13-2005, 11:31 PM   #9
at 70mph on stock 3.27's your pushing like 2100rpms.
now only a rough estimate w/ 3.73's you'll be pushing approximately 2400 or so at 70mph.
Old 05-13-2005, 11:49 PM   #10
here, this will help:
3.27(7.5,8.8)-stock 99+ gear. better acceleration
3.45(7.5)-3.55(8.8)-decent increase in acceleration while conserving top end drivability.
3.73(7.5,8.8)-best all around gear for acceleration and highways use
4.10(7.5,8.8)-great acceleration gear for drag racing, limits top end
-Installing a set of numerically higher gears will do two things to your gas mileage:
1)Decrease gas mileage during highway travel, because you will be driving at a higher rpm then stock.
2)Increase gas mileage around town because you can find yourself driving the same mph, but one gear higher(ie, 40mph in the low end of 4th, instead of 40mph in the higher end of 3rd.)
-Depending on how steep of a gear ratio you buy, you can expect up to a half second reduction in elapsed times at the drag strip.
-All v6 mustangs come with 7.5 rear ends with an open carrier differential. They can roughly handle 300hp. Using sticky tires, such as slicks, and launching at high rpms can cause breaking even if you do not have 300hp.
-A 8.8 is a much stronger rear end than a 7.5. The actual rear end itself is larger, which allows the parts inside to be bigger(carrier, differential, gears), thus making them stronger. Many people swap to 8.8 rear ends because it can be more economical to buy a whole 8.8, or a used 8.8 than replacing, and installing parts on a 7.5. The axles and brakes are interchangeable between the 7.5 and 8.8 axles as well providing the differential in the 8.8 is not made for 31spline or larger axles(stock 7.5 and 8.8 is 28spline).
hope this helps.
Old 05-13-2005, 11:52 PM   #11
Region: Iowa
I'm getting a 33 spline I think. But it's a complete set-up. Moser. Buying it tomorrow.. then I will replace mine, which happens to be ****ed right now. Hmmm, that says it's best for highway driving, but what about interstate driving... now I don't know. 3.55 or 3.73 .... such hard decisions I have
Old 05-13-2005, 11:58 PM   #12
Region: Iowa
that does help a lot, thank you
Old 05-14-2005, 12:27 AM   #13
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
highway driving = interstate driving
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 05-14-2005, 02:54 AM   #14
Thomas91169's Avatar
wheres the 4.1 option? if i had a stang i wouldnt do anything less.
-Thomas-
Old 05-14-2005, 07:15 AM   #15
no, when i said "in the end" i was meaning "when its all said and done"
maybe i should have said "when its all said and done, i would have 3.73's"
i was wondering why you posted this
Old 05-14-2005, 10:38 AM   #16
Region: Iowa
I knew what you meant... I was being funny because end and rear can mean the same thing.... also, I don't want 4.10's because I don't want to throw my gas right down the drain. 3.73 would be as high of ratio as I would go. This is my daily driver, not my project car.
Poll for u guys... meteorachick The Bar 52 12-12-2005 09:02 PM
a poll about the 86... redrum The Bar 7 07-12-2005 04:56 PM
New Engine Poll drummerstang98 The Bar 21 09-25-2004 09:23 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
10:43 AM
