My latest "Experiment", saving fuel $$$ - Mustang Evolution
Old 06-01-2005, 07:58 PM   #1
RGR
Send a message via AIM to RGR
My main "car" is a 95 ch*vy Tahoe 4x4 with towing package.
It was getting around 10-12 MPG around town lately when I
saw a newly available fuel around here called "E-85"
which is 85% ethyl alcohol and 15% gas for a net octane rating
of 105 So I started the inner wheels churning and came up
with a plan, I would try about 10 gallons and see what happened.
I knew the 105 octane could tolerate a good bit more timing but
would it need more timing? I believed it would need more and I was right.
Stock timing is 0* (TDC) because of the heavy truck and 87 octane,
I have not had a timing light on it yet but I think I have added 10*
or more timing total. Now I think it needs more idle speed, sometimes
it dies but overall I believe it is getting better mileage (!) and
feels like it has better torque. I can accelerate w/o downshifting more often.
More later!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 06-01-2005, 11:21 PM   #2
Seph's Avatar
O_o?
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 06-02-2005, 07:52 AM   #3
Ponycarman's Avatar
Dunno if a 95 GM product still has it but the older ones had a provision to adjust the idle air bleed, essentially it was a screw that adjusted the butterfly's closed position. Open it up more for more idle speed.
If it doesn't have that provision you can drill a small hole in the butterfly to allow more air in. Start small and work up.
In a truck aerodynamics will help more. My 2005 Ram gets about 18 mpg highway and 14 city if you drive like grandma. Don;t forget tire pressure.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 06-02-2005, 09:29 AM   #4
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
You should only use that fuel on a vehicle that is set up for it. It is not suppose to be good for most vehicles.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 06-02-2005, 03:08 PM   #5
thats what i've heard. my friend has a 2000ish sentra and used that gas while we had it b/c it was cheaper and it clogged up his injectors and the car also idled rough and sometimes killed, as well as having trouble starting---problems he never had while using real gas.
personally, i wouldnt put that in my car, but if it helps you then and i hope you dont run into any problems
Kyle is offline   Reply With Quote
Old 06-02-2005, 05:22 PM   #6
Ponycarman's Avatar
The ethanol in the E85 fuel is a very aggressive cleaner. If you have any gunk in there is will end up in your filter if you are lucky and it may plug up your injectors with it.
Steve
1996 Mustang
1965 Barracuda
"Where in the World is Osama bin Laden?" - latest doc film by Morgan Spurlock SilentNoise The Bar 0 12-17-2007 06:23 AM
MTI RACING "Extreme Velocity" 454 "Southern Stingray" C6/Z = Awesome JROC Pictures and Videos 10 10-26-2007 03:33 AM
1995 Cobra "Fuel or Exhaust Issue" one95cobra 1979-1995 Mustang GT 9 11-05-2006 12:20 AM
latest little "project" Tbird232ci Pictures and Videos 10 03-21-2006 07:27 PM
w0000ttt!!!!! got something today (starts with "s" ends with "upercharger") fast64 Pictures and Videos 37 02-22-2005 05:52 PM
» Members Mustangs
07 v6
rons07
Vida
Tomb1987
Add your Mustang
12:09 AM
