2005 Steeda V6 Cold Air Kit - Mustang Evolution
Old 06-01-2005, 09:54 PM   #1
00vertstang's Avatar
http://www.steeda.com/PR/Newsletters...5/555-3124.htm
The kit is supplied with a stainless steel air box with built-in velocity stack and CNC billet aluminum mass air meter. It mounts in the factory location with the supplied rubber trim to seal it against the hood & fender to keep the hot air out. Our tests showed inlet temps a mere 10 degrees above ambient temperature. The Steeda Lifetime Filter can easily be cleaned and re-oiled, making maintenance a snap. All hardware required for installation is included in the kit.
We've found between 16 -20 more rear wheel horsepower with this kit. Is this true? Has the 2005 v6 changed that much from our 3.8 v6
00vertstang is offline   Reply With Quote
Old 06-01-2005, 09:59 PM   #2
Tbird232ci's Avatar
holy hell!!
300 dollars, for a filter, a tube, and a heat shield....i could make that **** at home, for probably around 100 bucks
Old 06-01-2005, 10:00 PM   #3
chips's Avatar
Send a message via AIM to chips
i think i'd have to see some dyno charts before i believed it...
the only reason Dr. Dre produced "The Chronic" because the bible tells you to smoke lots of pot, and Oedipus used to blaze with the makers of Aqua Fresh tooth paste.
chips is offline   Reply With Quote
Old 06-01-2005, 10:26 PM   #4
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
16-20more hp with 1 hell of a tune is more like it, not bolt on and go
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 06-01-2005, 11:16 PM   #5
Kiljosh's Avatar
NO FKING WAY. The only gains you will get from a cold air are minimal from the filter. Most will come from replacing the rubber, ribbed tubing with smooth metal tubing. Less resistance on top end.
It doesn't even replace the ghey stock rubber thing.
Old 06-01-2005, 11:17 PM   #6
the answer to your question is .......... **** no its not possible.
Old 06-01-2005, 11:20 PM   #7
Seph's Avatar
SERIOUSLY! What a ****in rip. If I had an 05 GT I'd just supercharge it and skip the $300 "air filter that has a heat shield on it"
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 06-01-2005, 11:31 PM   #8
3-6rwhp and tq lol no more ... those claims are horendus
Old 06-02-2005, 06:10 AM   #9
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
:bs:
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-02-2005, 06:50 AM   #10
sonic04edge's Avatar
Send a message via AIM to sonic04edge
Just so you guys know I believe they were seeing the 16-20hp gain fron the intake as well as the sct tuner that they talked about in the ad for it. I highly doubt steeda would say just an intake gives that kind of power.
Originally Posted by steeda
but the big news here is that we've streamlined the airflow in the 05 Mustang to the point that a computer re-flash isn't just an option, it's required! Check out the SCT Xcalibrator - the perfect tool for the job!
Looking for a mustang
2001 Ford Explorer 4x4
2003 Ford F150 Lariat Screw
1998 Ford Ranger-The DD
sonic04edge is offline   Reply With Quote
Old 06-02-2005, 08:21 AM   #11
Fishers Stang's Avatar
Talk to RGR, we played around with my stock rubber intake hose, and it really didnt have that much res to airflow, its all for looks...
Charles
Old 06-02-2005, 08:42 AM   #12
jimmy_beaner's Avatar
Region: Iowa
yeah, I didn't really notice much of a difference when I put my CAI on.... just a slight whistle when I really get on it, which I LOVE...... but as for power........ not really. I know it's faster, just not something you feel.
Old 06-02-2005, 08:44 AM   #13
Tbird232ci's Avatar
the only way it could make that much power, is if the original airbox was THAT restrictive, when i took the airbox out of my turbo coupe, without actually setting up a cold air, i picked up about 5-7rwhp (i havnt dyno tested that, but others have, and got roughly the same amounts, give or take 1 or 2), and it sure seemed like it
im doubting that the stock airbox in the '05 is seriously that restrictive
Old 06-02-2005, 09:17 AM   #14
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Dont believe it. Those numbers are exhadurated.... just like any retailer would do.
Rellik is offline   Reply With Quote
Old 06-02-2005, 09:19 AM   #15
Region: Iowa
well, I know what they did.... if you put their decal on your car, the hp increase is automatically doubled.... your car knows you put the decal on it, and realizing this, says "hey guys..... we gotta put out 10 more hp"
Old 06-02-2005, 09:25 AM   #16
But if you put a NOS sticker on, it quadruples
Old 06-02-2005, 09:27 AM   #17
Region: Iowa
lol.... NOZZZZZZ, hahaha.... my friend got a sticker that says "X-racing" on his Cavalier, and he thought that would give him the edge up on my car ... I'm not even kidding you.... so then he decided that didn't give him enough.... (I wasn't even past 3/4 throttle and still owning him) so he went and got the MATCHING STEERING WHEEL COVER....... hahahaha
Old 06-02-2005, 09:50 AM   #18
dark's Avatar
^lol, please tell me you're kidding
your friend is a chevy ricer
Old 06-02-2005, 12:33 PM   #19
Kiljosh's Avatar
God I hate ricers...
Old 06-02-2005, 02:58 PM   #20
no. but there is something that is after the filter that you can remove and it gives less restriction on your intake. but for $300 you dont even get the tubing that goes to the throttle body thats lame
the stock intake and exhaust on an 05 V6 is corked from what i understand, therefore, "uncorking" it with a less restrictive intake and exhaust will give better gains than a 3.8/3.9, but not that much that is being claimed.
Kyle is offline   Reply With Quote
Old 06-02-2005, 03:25 PM   #21
the bend that most cai's take that puts the fender in the fender well arc the air comming in so the meter reads it a little diff. it adjusts the a/f and this can raise hp/tq a tad also.
07:40 PM
