00 cobra R specs needed - Mustang Evolution
Old 06-21-2005, 09:52 PM   #1
i need the motor size in cubic inches, sohc or dohc, motor hp/tq numbers and WHAT rpm they peak... ty ty
Old 06-21-2005, 09:56 PM   #2
Monkey's Avatar
price $54 000 USD
engine Cas Iron, Triton V8
position Front Longitudinal
aspiration Natural
valvetrain Chain Driven DOHC, 4 Valves per Cyl
fuel feed Electronic Injection
displacement 5408 cc / 330 cu in
bore 90.2 mm / 3.55 in
stroke 105.8 mm / 4.17 in
compression 9.60:1
power 287.1 kw / 385.0 bhp @ 5700 rpm
hp per litre 71.19 bhp per litre
bhp/weight 235.76 bhp per weight
torque 521.99 nm / 385 ft lbs @ 4500 rpm
redline 6600
drive wheels RWD w/Gerodisc Differential
body / frame Unit Steel
front brakes Brembro Vented Discs w/Vacuum Assist, ABS, 4-Pot Calipers
f brake size 330 mm / 13.0 in
rear brakes Brembro Vented Discs w/Vacuum Assist, ABS, 4-Pot Calipers
r brake size 297 mm / 11.7 in
front wheels F 45.7 x 24.1 cm / 18.0 x 9.5 in
rear wheels R 45.7 x 24.1 cm / 18.0 x 9.5 in
front tire size F 265/40ZR-18
rear tire size R 265/40ZR-18
steering Rack & Pinion w/Power Assist
f suspension MacPherson Struts w/Lower Control Arms, Bilstein Shocks, Eibach Coil Springs, 26mm Anti-Roll Bar
r suspension Double Wishbones w/Lower Control Arms, Bilstein Shocks, Eibach Springs, 26mm Anti-Roll Bar
weight 1633 kg / 3600 lbs
wheelbase 2573 mm / 101.3 in
front track 1518 mm / 59.8 in
rear track 1518 mm / 59.8 in
length 4661 mm / 183.5 in
width 1857 mm / 73.1 in
height 1326 mm / 52.2 in
transmission Tremec 6-Speed Manual
gear ratios 2.97:1, 2.07:1, 1.43:1, 1.00:1, 0.80:1, 0.62:1
final drive 3.55:1
top speed 281.6 kph / 175.0 mph
0 - 60 mph 4.6 seconds
0 - 100 mph 11.0 seconds
0 - 1/4 mile 13.2 seconds
epa city/hwy 16 / 25 mpg
production 300
www.supercars.net
little more than you wanted, but that should shut ya up for a while
2003-2004 Cobra Specs SaleenFiend SVT Mustang 13 03-07-2011 12:02 PM
04' Cobra intake and supercharger PICS. needed if anyone can help!!! pan 1996-2004 Mustang GT 24 02-10-2009 03:33 PM
79 Mustang Cobra Wiring Diagram needed! xsystemx 1979-1995 Mustang GT 4 12-28-2008 01:55 PM
Need specs, please help! AnthonyS281 General Mustang Discussion 0 01-24-2008 02:55 PM
cobra calipers install tq specs? breakin? tips? SpectorV Pre-2005 V6 Mustang 11 06-04-2004 06:29 PM
12:12 PM
