I need HP/TQ specs!!!!! - Mustang Evolution
Old 06-22-2005, 01:28 PM   #1
I need the following HP/TQ specs for the following: (p.s. I need the rpm info as well!!!!)
94-98 mustang needs:
94 cobra
95 cobra
95 cobra R
96 cobra
97 cobra
98 cobra
99-04 mustang needs:
99 cobra
00 cobra R
01 cobra
03 cobra
03 Mach 1
04 cobra
04 Mach 1
2005:
05 v6
05 gt
Old 06-22-2005, 01:40 PM   #2
Bane-'s Avatar
see dark02ponys reply
Old 06-22-2005, 01:42 PM   #3
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
94 cobra : 240hp @ 4200rpm - 285ftlbs @ 3400rpm
95 cobra : 240hp @ 4800rpm - 285ftlbs @ 4000rpm
95 cobra R : 300hp @ 4800rpm - 365ftlbs @ 3750rpm
96 cobra : 305hp @ 5800rpm - 300ftlbs @ 4800rpm
97 cobra : 305hp @ 5800rpm - 300ftlbs @ 4800rpm
98 cobra : 305hp @ 5800rpm - 300ftlbs @ 4800rpm
99 cobra : 320hp @ 6000rpm - 317ftlbs @ 4750rpm
00 cobra R : 385hp @ 6250rpm - 385ftlbs @ 4250rpm
01 cobra : 320hp @ 6000rpm - 317ftlbs @ 4750rpm
03 cobra : 390hp @ 6000rpm - 390ftlbs @ 3500rpm
04 cobra : 390hp @ 6000rpm - 390ftlbs @ 3500rpm
2005:
05 v6 : 210hp @ 5300rpm - 240ftlbs @ 3500rpm
05 gt : 300hp @ 5750rpm - 320ftlbs @ 4500rpm
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 06-22-2005, 01:43 PM   #4
Bane-'s Avatar
Old 06-22-2005, 01:43 PM   #5
Bane-'s Avatar
or u can do it, bored at work, need to keep occupied lol
Old 06-22-2005, 01:44 PM   #6
Dark02Pony's Avatar
just finished up the list thanks for the info on the cobra Rs to finish that off i couldnt find the specs anywhere
Old 06-22-2005, 01:50 PM   #7
Bane-'s Avatar
there edited my other replies so we dont confuse spector lol.
but no fox motor specs?!? cmon spector...ur all driving fox based chasis cars!
Old 06-22-2005, 06:47 PM   #8
I need to confirm 94-04 GT and 03-04 mach 1 info also please
Old 06-22-2005, 07:57 PM   #9
Dark02Pony's Avatar
99 GT : 260hp @ 5250rpm - 302ftlbs @ 4000rpm
00 GT : 260hp @ 5250rpm - 302ftlbs @ 4000rpm
01 GT : 260hp @ 5250rpm - 302ftlbs @ 4000rpm
02 GT : 260hp @ 5250rpm - 302ftlbs @ 4000rpm
03 GT : 260hp @ 5250rpm - 302ftlbs @ 4000rpm
04 GT : 260hp @ 5250rpm - 302ftlbs @ 4000rpm
03 MACH1 : 310hp @ 6000rpm - 335ftlbs @ 4200rpm
04 MACH1 : 310hp @ 6000rpm - 335ftlbs @ 4200rpm
Old 06-22-2005, 08:00 PM   #10
Monkey's Avatar
www.supercars.net
did you not see my post last night?
Old 06-24-2005, 12:58 AM   #11
I need hp/tq and at what rpm specs for EVERY 87 to 93 model engine available lol!
Old 06-24-2005, 01:18 AM   #12
Send a message via AIM to tedness
aren't we picky
tedness is offline   Reply With Quote
Old 06-24-2005, 07:43 AM   #13
Bane-'s Avatar
um... 87-92 5.0s were 225hp @ 4800rpms and 300 ft lbs @ ???
86 was lower cuz of crappy heads and 93 they detuned it a lil to make the cobra look better... i think they both had around 205hp
the 87-93 4bangers had i think 85hp...rpms were horrible and torque was like 10 ft lbs @ sometime tommorow
Old 06-24-2005, 08:06 AM   #14
Danger Dude's Avatar
Here is the Fox Body years from 79-93
years.....disp......fuel sys.....HP
1979......5.0.........2 bbl......140
.............2.3I4...................88
.............3.3 L6.................85
1980-81..4.2........2 bbl.......120
.............2.3I4..................88
.............3.3 L6.................94
1982......5.0.........2 bbl.......157
............4.2 (w/auto)2 bbl...120
.............2.3 I4..................88
.............3.3 L6..................94
1983......5.0..........4 bbl.......175
.............2.3.......................88
.............3.8 V6..................112
1984......5.0.........4 bbl.......175 Throttle body FI (w/auto0.....165hp
.............2.3......................88
.............2.3 Turbo .............175
.............3.8.......................120
1985......5.0.........4 bbl ......210 Throttle body FI (w/auto)......180hp
.............3.8......................120
.............2.3 turbo..............205
1986......5.0.......SEFI SD.....200
.............2.3 Turbo..............205
1987......5.0.......SEFI SD.....225
1988......5.0.......SEFI(Calif)..225
1989-92..5.0.......SEFI MAF...225
88-90.....2.3.......................88
91-92.....2.3.......................105
1993......5.0........SEFI MAF..205
1993......5.0 Cobra SEFI MAF.235
.............2.3......................105
Old 06-24-2005, 09:49 AM   #15
I need 4 baner info hp/tq and when they peak now
Old 06-24-2005, 10:55 AM   #16
Updated
Old 06-24-2005, 05:04 PM   #17
ty, thats great but I need tq numbers and I need to know at what RPM the hp/tq peaks for each year, i found the 5.0l now i need the 4 banger
Old 06-24-2005, 06:10 PM   #18
You really need to know the torque numbers on a car that made 88 HP ????
SPECS underestimateme Pre-2005 V6 Mustang 6 07-19-2008 01:57 PM
Need specs, please help! AnthonyS281 General Mustang Discussion 0 01-24-2008 02:55 PM
05 shinoda specs Dark02Pony The Bar 2 08-31-2005 08:41 AM
speaker specs coolstang Mustang Audio & Video 7 07-05-2005 02:27 PM
If you would please...specs StreetRacer4371 1979-1995 Mustang GT 3 12-31-2004 05:47 PM
02:38 PM
