cleanin engine bay.... - Mustang Evolution
Old 06-24-2005, 01:14 AM   #1
Send a message via AIM to tedness
im probly gonna clean it up tomorrow fer the helluvit...
i was gonna spray simple green on it and:
a) scrub by hand and wipe/rinse down w/ rags
or
b) pressure wash it, covering alternator, battery, other lil electrical pieces.
which works better to get the stuff off (grease and cleaner) and what other components should be watched?
tedness is offline   Reply With Quote
Old 06-24-2005, 07:26 AM   #2
slvr2000stang's Avatar
[Corey] Use Greased Lightning [/Corey]
That stuff works great.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-24-2005, 07:35 AM   #3
Danger Dude's Avatar
GREASED LIGHTNING > everything else
Old 06-24-2005, 09:28 AM   #4
Tbird232ci's Avatar
ive been using simple green and purple power for years, actually srubbing will work great, and to follow with a power washer would definatly be good
Old 06-24-2005, 09:47 AM   #5
i dont like putting water on the motor... can be fine and it can mess stuff up... de-greasing it works good also but just the same....
i try to clean mine every couple months or so, this keeps the problem from getting bad enough to require pressure washing or degreesing.
Old 06-24-2005, 09:50 AM   #6
Tbird232ci's Avatar
i clean mine regularly
the way i do it, i spray a cleaner on, let it sit, spray more on, to keep it from drying, then start scrubbing, ill add more cleaner to the engine bay as needed, scrub as needed, then just flood the engine compartment with water to rinse it
when i got my car, i think it had some assembly line grease under the hood, so it took a lot of cleaning to get it looking decent
Old 06-24-2005, 11:33 AM   #7
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
I give it a quick rinse just to get things wet, then I'll spray it down with some simple green and let it sit while I clean the rest of the car. I'll rinse the engine off before rinsing the car.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 06-24-2005, 11:38 AM   #8
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
i use simple green i love that stuff speaking of which i need to pick up some more of it but also have to use mothers billitt metal polish since i polished most of my motor like so(not finished)
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 06-24-2005, 12:20 PM   #9
Seph's Avatar
^ wow nice
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 06-24-2005, 12:23 PM   #10
That is just it you dont have to scrub Greased Lightning. Kirk use to use simple green till he saw the light.
Old 06-24-2005, 12:25 PM   #11
Yes I followed Brother Corey towards the light of Greased Lightning.
2000 Vert 4R70W
Old 06-24-2005, 02:39 PM   #12
hmmm i'll try teh lightning
Old 06-24-2005, 10:50 PM   #13
Tbird232ci's Avatar
if you saw my engine compartment...youd think otherwise...
basically, as i cleaned off grease, the grease was pulling the paint off a spot on my inner fenders
Old 06-27-2005, 11:28 AM   #14
im gonna use up the simple green i have today. get some nice before and after shots.
anything else i need to cover beside battery and radiator?
Old 06-27-2005, 03:14 PM   #15
Tbird232ci's Avatar
just cover up your coil packs, and your alternator
battery and radiator dont matter
Old 06-27-2005, 04:03 PM   #16
This thread inspired me to start cleaning on mine, got the major stuff off, time for detail now.
Old 06-27-2005, 04:11 PM   #17
pics son, pics
Old 06-27-2005, 04:13 PM   #18
Still not near pic worthy at the moment...just got the major junk off. It's all stock under the hood, so who cares lol
Old 07-02-2005, 12:41 PM   #19
Send a message via AIM to CCstang2004 Send a message via Yahoo to CCstang2004
Well i like to just spray my motor down really good at the goo-goo car wash with there tire cleaner crap and it works good, i just spary it down beore i start washing the car and let it sit and then i will clean the outise of the car and then i will clean the outside of the car and and then when i get it all nice and soapy and ready to spray off, then i pop the hood and clean the engine bay while the car is started of course, and then i will let the motor dry and then i take some tire shine and i will use the good tire shine on a good terry cloth and spary it in good and then rub the stuff togther then clean the black stuff and get the tubes and stuff good and clean. But i would like too know how dark pony did his polishing ( i know the mothers biullet polish ) but what did you do just put it on a clean it off?
CCstang2004 is offline   Reply With Quote
Old 07-02-2005, 12:48 PM   #20
he just PMed me about it. i wondered the same thing.
Originally Posted by Dark02Pony
haha that took me forever , when i purchased my upper intake manifold from RPM before installing it i started to sand it down i started with a rough 40grit then slowly worked up to 60 grit 80 grit 120 grit ect ect all the way up to 400 then 400wet. once i got it to where i wanted it i put on about 10 coats of Mothers Billett Polish. it took me about 2 and 1/2 months to do my alternator , manifold and heatercore the way they look now
Old 07-02-2005, 01:49 PM   #21
Man nvm i think i will pass on that, too much time too do all that, maybe when i go to get my turbo put on my car i will take the time and let sumone else dand it down with theose powersnaders, lol.
Old 07-02-2005, 03:42 PM   #22
Kiljosh's Avatar
Are you drunk?
Old 07-02-2005, 05:38 PM   #23
gotta love them powersnaders
Waxin the engine bay?? SVTCOBRA General Mustang Discussion 19 06-22-2009 12:06 AM
Engine Cleanin kack85 Pre-2005 V6 Mustang 0 04-13-2009 10:38 PM
First pictures of my engine bay? MonteCitan Pictures and Videos 18 09-20-2006 09:06 PM
Engine Bay Cleaning bluemustang Mustang Audio & Video 17 04-28-2005 05:53 PM
Engine bay or interior? Dom Mustang Audio & Video 8 08-27-2004 03:07 PM
12:39 PM
