can anyone explain a burnout? - Mustang Evolution
Old 06-29-2005, 11:44 PM   #1
Send a message via AIM to tedness
ok in slow people's terms how is it done? all my website searches on google bring up that damned video game and automatic burnouts/brakestands
yes i realize for now i can only do a 1-wheel but by jax trip i'll have the 2-wheel.
tedness is offline   Reply With Quote
Old 06-29-2005, 11:46 PM   #2
hold the brake as you gradually let off the clutch and push in the gas.
Old 06-29-2005, 11:58 PM   #3
Kiljosh's Avatar
Friend of mine had a 5 speed 92 4 banger.
He used to rev up and pop the clutch then catch the car with the brake like 3 feet later and just stand on it for like 30 seconds.
All this going on next to the highway at the gas station I worked at.
Why I got fired you ask??
Old 06-30-2005, 12:24 AM   #4
MonteCitan's Avatar
yeah... launch the car hard enough to spin then hold on the brakes.. works best with wet tires...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-30-2005, 12:47 AM   #5
Thomas91169's Avatar
i just rev mine and pop the clutch at around 3500 and just let loose gobs of smoke. i can just sit there for a few seconds before the drivers side starts to catch and pull me along, but if i want i can hit the ebrake(since im fwd) and sit in one spot and roast them. but i havent done that in a while(got good tires now that cost).
my buddy had a 89 5.0. he would heel toe it. have his right foot heel on the brake and his toes on the gas, and his left foot just the clutch. hed hold the brake and gas down just a little bit, then ease out on the clutch, then hit the gas, pop the clutch and put the left foot on the brake and the right on the gas and let slip the dogs of war.
on a automatic you can just hold the brake with the left and hit the gas with the right, then let off on the brake just till the car barely wants to move, then go full throttle and use the brake to control if you want to move forward a bit or just sit there and roast them.
-Thomas-
Old 06-30-2005, 01:30 AM   #6
03redfire cobra's Avatar
Send a message via AIM to 03redfire cobra
put it in 2nd gear and rev it, drop the clutch and immediately put that foot on the brake.
~Evan~ This smiley was named after me-->:evan:
2008 Cadillac Escalade ESV
2006 Chrysler 300c SRT8
03redfire cobra is offline   Reply With Quote
Old 06-30-2005, 01:42 AM   #7
dam one day i want to have enough power to be able to light them up from a stop in 2nd gear. actually im gonna go try that tomorrow on my way to work.
-Thomas-
Old 06-30-2005, 02:07 AM   #8
bbunt302's Avatar
Yup, easy as it gets.
Scary stuff.
Old 06-30-2005, 04:21 AM   #9
electricstang99's Avatar
Send a message via AIM to electricstang99
what can you do to make your car have both wheels burnout instead of just one?
I heard your engine is blown... Are you gonna fix it or get another car?
....and i was in a heated race with a civic the other day... he was turbocharged. He only won because I tripped on a rock :uhh:
http://mustangunderground.com/uploads/pictures/ME.JPG
electricstang99 is offline   Reply With Quote
Old 06-30-2005, 05:34 AM   #10
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
limited slip differential.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 06-30-2005, 06:26 AM   #11
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
not true
a burnout is simply pealing rubber as you launch
a brakestand is when you hit the brake after letting off the clutch and gas it
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-30-2005, 06:46 AM   #12
Bane-'s Avatar
hold the brake against the floor and press the gas tires start spinning around 2k
if its not against the floor my trans will pull me along. tbird can vouch for me on that,can start off in 1st and idle around and up steep hills thanks to the beefy trans but behind a stock motor
Old 06-30-2005, 11:49 AM   #13
Tbird232ci's Avatar
explain how to burnout...
first, you go find a dealer, then buy a baggie form him, then you get some rolling paper, from a store, or even from a "donor" ciggarette... :smoke:
Old 06-30-2005, 12:11 PM   #14
red herring's Avatar
Send a message via AIM to red herring
it seems like everyone wants to hold down the brake hard. Just to clarify, I usually don't have to push the brakes down very far at all. Maybe it works both ways.
red herring is offline   Reply With Quote
Old 06-30-2005, 12:43 PM   #15
Bane-'s Avatar
I have to or the trans pulls the car...Ive sat in my uncles driveway (steeper then 45*) in 1st and let off the brake and the car wont roll backwards, wants to try to push the car up the hill
Old 06-30-2005, 01:44 PM   #16
Send a message via AIM to CCstang2004 Send a message via Yahoo to CCstang2004
lol in my opinion that powerbraking where you drop the clutch and just sit there and burn rubber is pretty cool but can ruin a clutch really really quick, trust me i blew my clutch all to hell and back doing it but that didnt change my mind about doing it again, since then ive only done this once but in my mustang normally all i will do just rev the car as high as i can go and just drop the clutch then gradually keep tapping the brake and walla a good burnout and a cheap one at that no new tires like ever couple months, lol. Oh yeah and a good question in my mustang i knowi dont have a red line chip but when it gets to like 5200rpm the car will just sit there and just ( room room room room room ) it sounds cool but why in the hell does it do this, cause i know my buddies 2004 mustang doesnt do this and it was manufactured the same month mine was and he has the 3.9 aswell??????
CCstang2004 is offline   Reply With Quote
Old 06-30-2005, 01:49 PM   #17
maybe i'd get traction at the track if i burned out in the pit... lol
i'm always the only one who doesn't do that.
Old 06-30-2005, 01:54 PM   #18
if you have an auto you hold the brake and push the gas, the rear brakes are not as strong as the front so they will spin and the front will hold. You can also just floor it and do one if you have enough power. For a manual car... its not nearly as easy.
you have to hold the brake and clutch, get on the gas fast and come off the clutch also, hold the brake and gas and do the deed... then get back on the clutch when you let off fast.
Old 06-30-2005, 02:01 PM   #19
MarkuzLS1's Avatar
I drive around the waterbox, pull into the staging lanes, put the brake to the floor, mash the gas just enough to make them chip a little bit, stage, then cut a 2.0 60'. Every time. I need some ET Streets.
I like turtles.
Old 06-30-2005, 02:21 PM   #20
Hey mark what kinda ET streets do you need and what size cause i can talk to my dad and he might be able to get them for ya at a descent price bro.
Old 06-30-2005, 02:24 PM   #21
oooh go slicks.
Old 06-30-2005, 02:26 PM   #22
MarkuzLS1's Avatar
I'd need 2 for a 16x8 wheel. Let me know.
I like turtles.
Old 06-30-2005, 09:27 PM   #23
Gee whoda thunk it?
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 07-01-2005, 03:56 PM   #24
in my opinion, on our street tires and such, i'd suggest driving around the pit
Old 07-01-2005, 06:00 PM   #25
A burnout happens when two tires, that love each other very much, get together and put a dime under a cabbage leaf, then the smoke happends.
Old 07-01-2005, 06:16 PM   #26
with street tires youre not supposed to do a burn out, but since its the track, its prolly the only place you can do one and get away with it.
street tires dont generally get stickier the hotter they are. they are designed to grip their maximum how they are. roasting them wont make a difference.
slicks, on the other hand.......
-Thomas-
Old 07-03-2005, 06:55 PM   #27
01mineralgrey6's Avatar
I do that, or just "heel/toe" the brake and clutch pedal
-Tony
'99 cobra 'vert
Old 07-03-2005, 07:13 PM   #28
all rubber gets softer as it heats up...it just that street tires won't get "sticky" like drags do so there is no point.
if you're runnon street tires, just do a quick 1-2 sec burnout to clean the dirt/water off o fthem and you are good to go. Not doing any burnout is dumb, and doing a massive one is even more so.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 07-03-2005, 08:31 PM   #29
all the guys here usually drive a bit to heat up their tires before they do any racing. at least the high horsepower guys. civics...nah.
Old 07-05-2005, 08:07 PM   #30
One thing to remember about doing a brakestand, your rear brakes are still being applied, and you are spinning through them. This will cause your rear brake pads to wear alot faster and lead to a rear rotor warp. If you do brakestands alot invest in a line lock which will lock your front brakes and not your rears, keeps you from messing up the rear rotors.
Old 07-05-2005, 08:29 PM   #31
Monkey's Avatar
I wish I could do a burnout
Old 07-05-2005, 08:32 PM   #32
evo's make some good donuts tho.
Old 07-06-2005, 06:59 PM   #33
Dude...I have a friend who did an awd donut, it was freakin sweet, spins like a top.
Old 07-06-2005, 09:44 PM   #34
ya its crazy. im thinkin my next car will be awd.
Old 07-06-2005, 09:45 PM   #35
I liek gramer
WhiteStang99's Avatar
^ An AWD Mustang? You are crazy!
Someone PLEASE EXPLAIN THIS Brent The Bar 8 03-10-2009 12:28 PM
I don't know how to explain this so just look Brent The Bar 9 11-24-2006 01:59 PM
Please someone explain this before I go insane Brent The Bar 6 12-05-2005 12:39 AM
explain your name WhiteStang99 The Bar 68 08-12-2004 04:27 PM
02:08 PM
