got sct x-cal2 in the stang today *VID* - Mustang Evolution
Old 06-30-2005, 04:24 PM   #1
Talking got sct x-cal2 in the stang today *VID*
i just got the x-cal2 in my car a few hrs ago, and the diff is very cool. its set on the "aggressive" mode right now which is supposed to be the highest performance mode. what the guy said he did was get the tunes from sct and adjust it a little for a little more performance over the tunes sct sent. i have noticed a few things on the way home:
better pull throughout powerband (very noticeable)
higher redline (1st spins to 6k)
harder/faster shifts (in 90degree weather w/ full tank, i can bark the tires into 2nd)
way better throttle response
alot more "jumpier" from a dead stop (not including WOT)
as of right now, overall i am very pleased with this mod and hope to stay that way, the only setback is that i have to put 93 octane in this mode. i can switch it to 87 mode, but i wont have as much power. so we'll have to see what kinda mileage i get with this mode.
attached it a 0-90 accel vid. full tank of gas, stock interior, and my fat ***
Kyle is offline   Reply With Quote
Old 06-30-2005, 04:25 PM   #2
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
that is pretty damn quick compared to your other 0-90 run..nice vid
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 06-30-2005, 04:26 PM   #3
Kiljosh's Avatar
Yea, I love chirping!!!
Yea, your car is quick now.
Old 06-30-2005, 04:28 PM   #4
Send a message via AIM to tedness
so flashing it just plugs into your diagnostic port? cuz i was checking that out...
might save me a dynotrip for a quick fix. especially once the gears go in.
tedness is offline   Reply With Quote
Old 06-30-2005, 04:33 PM   #5
yeah, you dont have to replace the stock computer, just plug the programmer in, follow the instructions, and youre good to go.
Old 06-30-2005, 04:38 PM   #6
Sweet...I had a feeling you would have the total "seat of the pants-o-meter" approval. Sounds like Cody did some other tweaks for you? Did he do this for free? Guess it is a good thing I sent you his way???
Bet you can't wait for the dyno now to see what that says for improvements.
Old 06-30-2005, 04:59 PM   #7
yeah i can def feel a difference with the sct now. he said he "had a few tricks up his sleeve" and tweaked the "aggressive" tune a little more. yes he tweaked it and programmed it for free, i paid $400 for the programmer and that was it. i had another shop that said they could do it for me for the same price, but they might have not tweaked it more and just gave me the tunes sct programmed. cody sure sounds like he knows what he is talking about and i will most definately get my exhaust system from him too.
thanks for referring me to him
i will probably dyno it in a few weeks, it all depends on the weather, i'm gonna try and find a somewhat cooler day than today to run it, then i will run it again in the fall or winter when it cools off
and in regards to the track tommorrow. i have to work till 6 and dont know what juston has to work. pending your work schedule and convience, if you just wanna go next friday, it would probably be better for me b/c i get off at 2 next friday. but just let me know.
Old 06-30-2005, 05:03 PM   #8
Next week is much better. I still haven't found a helmet yet, so I couldn't run tomorrow anyhow. We will just plan on it for next week. Besides, from the sounds of it outside, rain might actually occur tomorrow like they predict.
Old 06-30-2005, 05:05 PM   #9
remember when I told you not to raise your rev limiter... well its VERY bad to do it... there is absolutly NO point in going over 5.5 K in your car, your simply wasting your time and hurting the car, alter it back to 5.5k.... you risk damaging yoru engine.
Old 06-30-2005, 05:08 PM   #10
i know you told me that, but i didnt personally raise it or ask for it to be raised, thats the way it came. i asked the guy if it will do anything bad to the engine spinning that high and he said as long as i dont do it all the time, then i wont have a problem. but i'll see about getting it pushed back to 5.5 if its gonna hurt something.
Old 06-30-2005, 05:28 PM   #11
get it back down, ive seen more than a couple mustangs come into the local ford dealer... they stuck in a chip/programmer and raised the rev limiter and spun a rod bearing going to high... going over 5500 rpms is just going to slow your car down. you will also want to make sure your car shifts at 5500rpms.
Old 06-30-2005, 11:35 PM   #12
Thomas91169's Avatar
dam 5500 limiter, that would suck for me, id only have full boost for about 1500 rpm before id have to shift.
but yeah id bring it down. theres no power up past 4.5 anyways unless you got some goodies(heads n cams).
and you should be putting in 93 anyways. i wish i had 93, in cali, the best we get is 91 pisswater. i found a gas station on the way home from LA once with 100octane and ran that for a full tank, and oh my god, you wanna talk about "*** dyno pulls" i crapped my pants getting back onto the freeway and driving back home doing 3rd gear pulls.
-Thomas-
Old 06-30-2005, 11:38 PM   #13
I liek gramer
WhiteStang99's Avatar
our engines are set to run on regular. any higher for a stock engine is bad. I know he has a chip or w/e now, but you said he should be running 93 anyways, and that's false.
Old 07-01-2005, 12:00 AM   #14
why would higher be a bad thing? higher octane allows more timing advance due to being able to ward off knock better.
-Thomas-
Old 07-01-2005, 12:03 AM   #15
Because without a tune and change in timing, the higher octane will change the combustion characteristics that the car was programmed for. With the tunner changing the timing, then you up the octane as the tune is changing the timing to be right for the higher octane. Without the tune, running higher octane is just a waste of money and potentially harmfull to your engine and/or performance.
Old 07-01-2005, 12:29 AM   #16
and the only way to get that advanced timing is to tune for it....
Old 07-01-2005, 12:53 AM   #17
hrm learn something new about mustangs every day.
-Thomas-
Old 07-01-2005, 01:09 AM   #18
No car stock benifits performance wise from Premium gas.
Old 07-01-2005, 01:11 AM   #19
I liek gramer
^ That's what I was thinking, but I wasn't going to comment without knowing for sure.
Old 07-01-2005, 01:18 AM   #20
eh possibly, i know ive seen timing charts from people with dsm's, you can tell those that run 91 pisswater from those running 95, theres a 5 point increase. but then again, it could be cause theres forced induction involved. usually cali people who post up charts are always a few behind on timing, thus we have to add more fuel than others from the nation up high, cause ours sucks.
case in point: me and my buddy with a 97 spyder at one time had the same exact mods. he found a pump that has 95 octane. we were both running 20psi on stock sidemount IC's, same fuel setup(550, 190lph and safc). my max timing was 17 degrees with 91 octane. he hit 21 degrees. then he went up to 25psi and richened out his safc a few points to account for the added air, and got 25 max timing advance.
i always knew to put the highest grade octane in when youre gonna be towing or doing any racing. i filled up the tahoe with 93 up at yosemite last weekend since i knew i was gonna be gunning it through the hills at higher altitudes.
-Thomas-
Old 07-01-2005, 11:48 AM   #21
the 99-00 peak at 5250 and the 01 up peak at 5500 not 4800 as the older ones.
Old 07-01-2005, 11:52 AM   #22
the stock specs are tunned for the cheap crap, I always run 89 for only one reason, cuz I dont like cheap gas... and its a safe gaurd
running higher octane when you dont need it can hurt milage along with performance, when you have a power adder this of coruse changes the equation.
Old 07-01-2005, 11:56 AM   #23
Kiljosh's Avatar
I ran 89 pre-chipped, now I run 93 post-chipped. It's not that hard to just follow the instructions on the gas door...
Dressed up the stang today mike05gt Mustang Audio & Video 7 04-30-2007 06:53 AM
x-cal2 question Kyle Pre-2005 V6 Mustang 15 01-16-2007 07:17 PM
dynoed the stang *VID* Kyle The Bar 13 09-22-2005 08:23 AM
worked on the stang today tire The Bar 2 03-18-2004 06:54 PM
New SCT chip burned by Dennis Reinhart arrived today!! Rick0636 Pre-2005 V6 Mustang 5 02-17-2004 09:52 PM
01:00 PM
