Figured out the Integra troublecode - Mustang Evolution
Old 07-10-2005, 12:22 PM   #1
Send a message via AIM to 232SCstang
On most hondas and acuras, there is an LED right on the ecu. This LED tells you the code. I put the key in, turned the ignition on, but engine off, and the LED starts blinking in correspondance to the number of the code. Here is what I came up with:
4 - Crank Angle Sensor or circuit
Do you think that a sensor like that could cause the engine to run so horribly or not at all? Does that code make sense in relation to the problem I am having?
1988 Ford Mustang LX
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
All vehicles in color of text k:
232SCstang is offline   Reply With Quote
Old 07-10-2005, 01:49 PM   #2
Ponycarman's Avatar
Yes. It's what tells the computer where the crank is. That's how it knows when to fire the plugs and injectors, well it also uses the cam sensor too. They have a limp home mode that will allow you to drive the car with that failure mode. However, as you have found out, it drives poorly.
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 07-10-2005, 02:04 PM   #3
hahahaha thats for sure. It barely starts now. So what has to be done to correct this problem? Replace the sensor? Or is it more complicated then that?
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
Old 07-11-2005, 02:56 AM   #4
Thomas91169's Avatar
yeah who told you about the ecu led........................
glad you know it now.
replace the sensor. when my buddy did the MPFI swap on his 89 crx(from tbi to mpfi) we had the same exact code. we went through all the wiring and couldnt figure it out. so he sold it to a guy who fixed it by buying a new distributor. but i believe in yours the CAS should be external from the dist.
wait nm i thought it said cam angle sensor.
anyways, replace the crank sensor and see.
-Thomas-
Old 07-11-2005, 01:19 PM   #5
I liek gramer
WhiteStang99's Avatar
hmmm.
Don't think I'll be buyin that teg from ya. You know, from one of the two other threads about it, the one where you mention it's for sale but not the problems from the other threads.
Old 07-12-2005, 02:05 AM   #6
hmmm so dont buy it. No big deal. Once its fixed, its gonna run fine. Its a mechanical piece of equipment. Things will break on it. It won't last 2,000,000 miles.
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
Old 07-12-2005, 02:06 AM   #7
yeah and a sensor going bad on a car is by far the worst thing in the world too
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
I figured we can help a sponsor out.... Brent The Bar 11 06-21-2006 12:23 PM
Finally figured out the deal with my car. Zim 1979-1995 Mustang GT 14 09-19-2005 08:49 AM
Check out the pics now figured it out Matt'sredbeauty The Bar 19 01-19-2005 10:26 PM
Figured my setup out... Tbird232ci The Bar 1 12-11-2003 09:43 AM
12:07 AM
