Great deal on a 8.8 Rear w/ 4.10 gears! - Mustang Evolution
Old 08-10-2005, 12:03 PM   #1
http://cgi.ebay.com/ebaymotors/1998-...92509632QQrdZ1
Someone needs to get on this!
Old 08-10-2005, 12:18 PM   #2
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
Re: Great deal on a 8.8 Rear w/ 4.10 gears!
if it wasnt 6 days till closing i might, if its at that low at the end its mine.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 08-10-2005, 12:42 PM   #3
slvr2000stang's Avatar
That is a good buy
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-10-2005, 12:57 PM   #4
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
why does it have to be for 98-
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 08-10-2005, 01:00 PM   #5
you can use it all you need is some wheel spacers.
Old 08-10-2005, 01:21 PM   #6
I would not recommend that though
Old 08-10-2005, 01:23 PM   #7
why? is it a ***** to put on?
Old 08-10-2005, 01:29 PM   #8
^ No just like doing things right myself and wouldn't trust wheel spacers.....
Plus if I was him I would work on the engine first then do the swap..... only reason I did mine in reverse is because I got a 8.8 out of a fox that had 4.10's in it already for 275 bucks local... couldnt pass that up and my axles swapped over easily.. you couldnt use the 99+ axles in the pre 99 one...
You could do it that way but I wouldnt go the spacer route
Old 08-10-2005, 02:21 PM   #9
wheel spacers are safe as long as they are the hub centrics. i do not see a problem with wheel spacers. he wont need to swap axels if he gets spacers.
Rear Gears sledgehammer Pre-2005 V6 Mustang 16 12-06-2007 07:19 AM
I found a great deal on a 2004 GT if anyone wants it Brent The Bar 10 08-13-2006 12:53 AM
Jeep folks, heres a great deal PureVenom The Bar 8 08-05-2005 09:11 AM
Got a good deal on gears... Sublime782 Pre-2005 V6 Mustang 5 05-17-2005 10:47 PM
Good deal for gears ERICK Pre-2005 V6 Mustang 3 12-23-2003 06:19 PM
01:10 AM
