just did the 3g alt conversion - Mustang Evolution
Old 09-12-2005, 09:11 PM   #1
Tbird232ci's Avatar
i know most of you later model stang guys already have the good, 130amp alternator, but some of us (fox guys) wernt so fortunate
me having a Turbo Coupe, which has the programmed ride control, twin electric fans, ABS with Hydrobooster, and almost every option, the electrical draw on the poor, stock 75amp alternator was killing it, if i was at a light, had the heat on, and hit the brakes, and the lights would go brown, real bad
so today, i got off my ***, went and pulled a 130 amp alternator from a 96 Sable, and had to do some grinding to the bracket to make it fit, the wiring was a bit tricky since i have different wiring than a stang, but it was straight forward
the results KICK ***, i can have everything possible on in the car, and my lights dont dim, and the alternator doesnt get nearly as hot
id suggest it to anyone
Old 09-12-2005, 09:12 PM   #2
Re: just did the 3g alt conversion
Hm...I'll think about that mod...might make a difference...
just joking guys...I know I have a 130 amp...just trying to see how many people take me serious
Old 09-12-2005, 10:24 PM   #3
01mineralgrey6's Avatar
sweet
-Tony
'99 cobra 'vert
Old 09-12-2005, 10:25 PM   #4
I liek gramer
WhiteStang99's Avatar
Sounds cool. How long did it take?
Old 09-12-2005, 10:40 PM   #5
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
congrats on your victory
I_luv_HP&trq is offline   Reply With Quote
Old 09-13-2005, 09:57 AM   #6
Tbird232ci's Avatar
Brad, you almost got me
the swap didnt take too long really, i had to grind down the mounting bracket, but what too a while was finding a suitable tool, and the air tools i have were out of the question because our compression was taking a dump
the wiring in the car is unique compaired to the mustang, but the wiring took me maybe 45 minutes, grinding the bracket down and all that took me maybe 45, and probably another half hour just putting everything together and neatening up the wires
so maybe 2 hours or so
Old 09-13-2005, 06:36 PM   #7
my friend did this on his car as well, definatly something worth doing.
Old 09-13-2005, 10:48 PM   #8
Tbird232ci's Avatar
yes, its definatly worth it
i drove around tonight, my electic fans were on, i was on the brakes, turned the a/c on (only the blower works), and was playing with my windows, and the lights barely flickered
it rocks
Old 09-14-2005, 12:24 AM   #9
What size alt came on a 96 V6 Stang?
Old 09-14-2005, 09:37 AM   #10
Tbird232ci's Avatar
a 130amp
a lot of guys actually use the alternators from the pre 99 V6 stangs, since they use the same mounting points
ALT Question outlawfrog 1996-2004 Mustang GT 3 11-11-2009 06:11 AM
V8 conversion! 1980rustang General Mustang Discussion 1 10-07-2009 12:24 PM
v8 conversion help, please. blown347ranger 1979-1995 Mustang GT 2 12-16-2007 01:29 PM
ALT charge TBone Pre-2005 V6 Mustang 12 07-10-2005 01:19 PM
V-8 Conversion... txstang95 1996-2004 Mustang GT 11 02-21-2005 09:32 AM
09:26 PM
