Computer Question - Mustang Evolution
Old 10-18-2005, 05:23 PM   #1
Computer Question
I am looking at a friends computer. The monitor onboard graphics hook up does not seem to be working. The monitor does not display anything and the cpu beeps. I am assuming the onboard display has went to crap.
I am recommending a PCI vid card... i would rather test one first before they buy though... i can get one cheap for like 26 bucks off new egg though. Anything else i should look at? Ive already reset the CMOS jumper.
Old 10-18-2005, 05:27 PM   #2
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
Re: Computer Question
my old computer had this same exact problem...id just turn it off. wait about 20min . turn it back on and it'd be set to go , good luck
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 10-18-2005, 05:39 PM   #3
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Sounds like a no-POST condition. I'll bet the problem is more than the onboard graphics.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 10-18-2005, 06:44 PM   #4
hmmm where is the next place to check/or to do
Old 10-18-2005, 06:58 PM   #5
Danger Dude's Avatar
Beeps are either Memory, Processor, Video card. If the board is bad you would normally not get any beeps unless the Video card slot is bad or the memory is bad
Old 10-19-2005, 10:02 AM   #6
Right. And the number of beeps will tell you roughly what the issue is. I don't remember them all right now, but there are sources on this interweb thingy that I used to figure it out. I would check them out and see what they say about the beeping you are getting.
Old 10-19-2005, 11:01 AM   #7
Herbstang's Avatar
Beep Code Descriptions
1 short DRAM refresh failure
2 short Parity circuit failure
3 short Base 64K RAM failure
4 short System timer failure
5 short Process failure
6 short Keyboard controller Gate A20 error
7 short Virtual mode exception error
8 short Display memory Read/Write test failure
9 short ROM BIOS checksum failure
10 short CMOS shutdown Read/Write error
11 short Cache Memory error
1 long, 3 short Conventional/Extended memory failure
1 long, 8 short Display/Retrace test failed
http://www.computerhope.com/beep.htm
Old 10-19-2005, 11:05 AM   #8
it beeps twice
Old 10-19-2005, 12:00 PM   #9
Herbstang's Avatar
I'd just go with the PCI video card may not be the correct way of doing thing But it's the simple solution
Old 10-19-2005, 02:57 PM   #10
i hope it is the video
Old 10-19-2005, 05:18 PM   #11
MarkuzLS1's Avatar
Don't hold your breath.
Do you have a processor and/or ram that will work in that mobo?
I like turtles.
Old 10-19-2005, 06:13 PM   #12
i might have ram but not sure
Old 10-20-2005, 01:45 PM   #13
Herbstang's Avatar
What make & model is the pc ?? What type ram ??
Old 10-20-2005, 01:47 PM   #14
i assume pc 2700 ram... its a cheap cpu so nothing amazing, i have no idea what cpu it is cuz i cant boot it to see and i dont watn to pull it off the board lol
Computer question.. wiarumas The Bar 6 12-03-2005 08:28 AM
question for you computer guys Dark02Pony The Bar 11 05-27-2005 08:02 PM
Computer problem....for all you computer gurus.. Rick0636 The Bar 59 02-19-2005 10:42 PM
Computer Question Brent The Bar 21 12-08-2003 07:26 PM
computer question Ken The Bar 4 12-02-2003 06:34 AM
11:50 PM
