i gotta question about gas - Mustang Evolution
Old 11-03-2005, 07:31 PM   #1
whats the best gas on the market now?
Kyle is offline   Reply With Quote
Old 11-03-2005, 07:32 PM   #2
I liek gramer
WhiteStang99's Avatar
Re: i gotta question about gas
cheap.
Old 11-03-2005, 07:33 PM   #3
Originally Posted by WhiteStang99
cheap.
no **** that, i cant run cheap ****............i really need to know based upon testing and **** what the best gas is........i need 93 and i need to find the cleanest, best 93 octane out there
Old 11-03-2005, 07:35 PM   #4
I liek gramer
I think Corey did some research on that or something. I know he did on oil filters... I'm thinking gas too.
Old 11-03-2005, 08:09 PM   #5
Danger Dude's Avatar
Here is the deal on gas. All the stations in a area use the same storage tanks. The only differenc is the additives put in. The only exceptions are people who live near the refineries and they have some choices but you have to know what stations are getting what centers. Now to determine who has the best additives and is the most consistant. There are 2 Amoco ultimate and Sunoco premium
Old 11-03-2005, 08:21 PM   #6
MonteCitan's Avatar
I use either sunoco, mobil or texaco..
If I use any other brand (get stuck without one local..) the car runs crappy (the Buick..) and I think that's a clear indication of fuel quality because..
1) factory supercharged
2) If it detects spark knock, it cuts timing like WHOAH to compensate
3) Which proves that if the gas isn't up to par.. the car won't run as well..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 11-03-2005, 10:26 PM   #7
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
I like the 76 near me because it has 100 oct at the pump and 110-114 in the back. I like adding some of that lucas additive stuff to my gas too. took away my pinging so i didn't have to change my tune with piss gas.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 11-04-2005, 06:30 AM   #8
OK you have to understand something about gas. Being that in most cities it comes from the same place no matter the name on the station. But to clear things up. Some stations use the same gas from the same truck for all 3 grades and add additives such as Toulene to bump up the octane. Some stations will order specific grades for their stations. What I liked about Amoco is the ultimate is clear and they had a little window in the handle to see it is clear. Regular gas is typically yellow/orange in color. So if the gas you are pumping is premium but it is yellowish it is a additive to regular gas. If it is clear it started life as a premium gas.
Now saying this I am not sure if there is a real world difference but I like my premium gas to be clear. My take is if the fuel distribution centers have a separate tanks for refined premium, I would think it would be more consistant at the proper octane than some smuck guesstimating the proper amout of additives in the fuel.
The other thing is watered down gas. Most ground storage tanks have water. This is not a big problem because gas floats on water. Stations use dip sticks to determine where the water level might be. This is also the reason to use newer stations. Nobody intentionally waters down gas it just happens to be already in the tanks.
One last think never store a car or any motor vehicle with ethanol gas in the tank because Alcohol absorbes water out of the atmosphere.
Old 11-04-2005, 07:05 AM   #9
I'm the same way corey, most of the time, before filling up my car I check the gas to see what color it is.
Old 11-04-2005, 09:25 AM   #10
Zim
You want to **** me?
Zim's Avatar
i just put the cheap stuff in mine... i dont have to use premium anymore
I like toys
Old 11-04-2005, 09:27 AM   #11
Yep those 5.0 will run on the crappiest gas found!!!!
Old 11-04-2005, 06:33 PM   #12
do they still do it? i have heard that 76, amoco, and conoco are the better ones. but the only one around here is an amoco, which is a few miles away
Old 11-04-2005, 11:13 PM   #13
Monkey's Avatar
Good thing the methanol in my aux tank is spraying to richen the gas and if water gets in there, oh well. it just cools the intake charge
Also, remember. 93 = 93 no matter where you are. Yes, some is refined as premium and some as normal, but it has to meet state laws regarding its octane count. If a gas station advertises 93 octane, it HAS to be 93. Like Corey said, it's just in the additives, which most of the time, don't really help or hurt you. I think they're all there for marketing. Sure they might help.... some, but I doubt it's good enough to make me only goto Shell or Texaco or something.
I usually goto QuickTrip. Gas is a couple cents cheaper and they guarentee their gasoline.
Old 11-04-2005, 11:44 PM   #14
Thomas91169's Avatar
im a arco/am-pm slut.
i used arco's 92 when i had the dsm. now i just use 91 with the stangs tune. works just fine, i was going WOT uphill and no pinging at all.
arco/ampm uses BP gasoline i believe.
-Thomas-
Old 11-04-2005, 11:48 PM   #15
Conoco or Exxon since they are right next to my house
gas question 95blackgt 1979-1995 Mustang GT 19 01-17-2011 06:12 PM
When you gotta go...you gotta go *Kind of WW* PureVenom Pictures and Videos 16 11-11-2006 04:05 AM
gas milage question fast64 Pre-2005 V6 Mustang 6 08-04-2004 06:16 PM
11:59 AM
