Paging Brandon (Monkey) *DUW* - Mustang Evolution
Old 09-05-2003, 08:43 AM   #1
tire's Avatar
Send a message via AIM to tire
Brandon,
I really need your help bud...
I need exact measurement of the lower-->upper ports. distances, size of ports, everything show in the picture. I'll send you a few bucks for a caliper if you don't have one. This is for that roots blower project that 'theoretically' should work. I'd really appreciate it if you'd measure it before you sell them!
-austin
tire is offline   Reply With Quote
Old 09-05-2003, 11:08 AM   #2
Monkey's Avatar
ill go by and pick up a micrometer today at lowes on my daily errand run. ill have the measurements by the end of the day for you austin
Old 09-05-2003, 01:45 PM   #3
tire's Avatar
You rock, I'll even let you have that jack stand back if you want.
btw I read an article about Cosby speaking at Baylor, like you mentioned the other day. Oh well, maybe some other time. I am always busy it seems when someone cool comes by A&M.
Old 09-05-2003, 05:20 PM   #4
Monkey's Avatar
ok, i took the ones going up and down to mean from bolt hole to bolt hole. I took the side one to be from bolt hole to widest part of lower intake. and the last one.. b/w the two runner bolt holes closest to each other. see my pic
the distance b/w all the bolt holes are the same at 4.140625" or 4 9/64 (~105mm)
distance from hole to edge is 2.4375" or 2 28/64 (62mm)
distance b/w sides is 2.796875 or 2 51/64" (71mm)
hope that is close enough for you, and the right measurements. if not, let me know
Old 09-06-2003, 03:30 AM   #5
tire's Avatar
Yup, turns out, it was perfect. Thanks amigo! Did you have the measuring tool? I'd be glad to paypal you a few bucks for it otherwise.
Old 09-06-2003, 12:00 PM   #6
Monkey's Avatar
nah, it was only like $25, so you dont need to paypal me anything.
Old 09-06-2003, 12:09 PM   #7
tire's Avatar
uh, why don't you want compensation
Old 09-06-2003, 02:32 PM   #8
Monkey's Avatar
ok, then you can send money to Biobuddha@msn.com
« hmmm | New Member »
Paging MATT @ Crossroadzdirect.com Autobadges.com The Bar 0 05-02-2004 01:04 PM
Happy Birthday Monkey (Brandon) Danger Dude The Bar 16 01-08-2004 10:56 PM
brandon tire The Bar 8 11-26-2003 02:59 PM
04:00 AM
