Well its winter time CHANGE your coolant - Mustang Evolution
Old 11-21-2005, 03:08 PM   #1
Just a reminder.... you should change it before winter gets here. I change mine every november~ its easy and cheap, while you are at it check your belts and other such items. You would be amazed what crap i see in my coolant afte only a year (especially for guys with aluminum heads/blocks)
Old 11-21-2005, 03:12 PM   #2
Bane-'s Avatar
Re: Well its winter time CHANGE your coolant
way ahead of ya, changed mine in my truck about a month ago. and the car...well it dont even have a radiator let alone motor
Old 11-21-2005, 03:13 PM   #3
No.
Fluid swap planned for spring when port work gets done and I change out some stock stuff. So there
Old 11-21-2005, 03:15 PM   #4
Im bad, never changed mine yet & Ive had my car 3.5 years! I used to change it on my 5.0 all the time. Never tried it on my car yet. Are the plugs gernerally in the same spot?
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 11-21-2005, 03:18 PM   #5
fast64's Avatar
I dont think I have gone a full year without doing something that requires draining my coolant and/or taking off the radiator. But my new 29" radiator is coming soon, so I need to do some cutting to make it fit, lol.
GO BRAVES
Old 11-21-2005, 04:32 PM   #6
jimmy_beaner's Avatar
Region: Iowa
I just changed mine late summer.... no more changing it until next fall.
Old 11-21-2005, 05:22 PM   #7
im doing mine tomorrow then im set for winter
Old 11-22-2005, 07:12 AM   #8
so this is going to seem like a retarded question... but where exactly is the plug on the 99? is it under the actual radiator, or is it in the plastic thingy that hold the coolant?
1999 3.8 V6 Electric Green Mustang
5 speed
Mods: MAC Dual Catback Exhaust, MAC Shorty Headers, CAI, Sequential Taillights, 03 17" Cobra Rims
My Garage
electricstang is offline   Reply With Quote
Old 11-22-2005, 07:15 AM   #9
Region: Iowa
there's a plug on the far front passenger corner, on the bottom of the car. It's a little plastic plug, and I believe it's white... Warning, when you unscrew it, fluid will come out... and then don't forget to remove your other caps, they'll hold negative pressure on the system
Old 11-22-2005, 07:15 AM   #10
Zim
You want to **** me?
Zim's Avatar
should be on the passenger side of the radiator... on the actual SIDE of the radiator. Little white hex looking plug
I like toys
Old 11-22-2005, 08:58 PM   #11
I changed mine today very easy... drain the old and clean out the overflow bottle then fill up the radiator and put the cap on, fill up the overflow bottle and turn the car on... wait... watch.. and fill as needed for a few cylcles... thats it.. under 20 bucks.
Old 11-22-2005, 09:02 PM   #12
Thomas91169's Avatar
screw that, i change mine come summer. living in cali, its never going to get cold enough to freeze.
-Thomas-
Not winter yet but... mustang03ally General Mustang Discussion 15 08-11-2010 08:30 PM
Time to put it in the garage for the winter. Renegade 800 Pre-2005 V6 Mustang 8 01-07-2009 12:50 PM
Time to Change the SIG wrecked2001 Pictures and Videos 7 03-22-2007 01:59 AM
Change you coolant regularly SpectorV Pre-2005 V6 Mustang 4 11-22-2004 11:54 AM
Coolant Change 99v6TxStang Pre-2005 V6 Mustang 6 11-10-2004 06:10 PM
11:45 AM
