so....my stuff's effed up...sorta - Mustang Evolution
Old 02-10-2006, 11:25 PM   #1
Send a message via AIM to tedness
my suspension has been odd since i got my so-called 'alignment' after putting it on, but i've found some new problems.
when i lock my steering wheel to either direction, i hear rubbing and squealing from tire against strut. however, in theory the steering rack should have a limit as to how far it can turn one way and should never hit the strut unless using a really really off-set/wide wheel.
now i am going for an alignment in the morning, and we'll see if that fixes it.
because the last alignment he didn't even loosen the caster/camber plates and basically 'forced aligned' it.
my little rant. cuz it pisses me off, even tho i've had it like this for months. just too lazy to deal with it. worse case scenario ill need a new steering rack and a-arms. if so, time for delrin
update once alignment is done and maybe pix of the damage to the strut.
sparknotes:
suspension/alignment is really screwy and it may require an overhaul.
tedness is offline   Reply With Quote
Old 02-11-2006, 11:05 AM   #2
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: so....my stuff's effed up...sorta
that sucks
gl dude..
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 02-11-2006, 12:07 PM   #3
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
sparknotes:
you probably should have talked to the shop owner\manager as soon as the problems became apparent. could have saved a ****load of $. now you may have to have your struts, springs and c/c plates replaced. suspension should NEVER be "force aligned" ..i'd kick a ****ing fit if a shop did that to my car
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 02-11-2006, 05:26 PM   #4
wiarumas's Avatar
good luck man.. hopefully its not too damaging to the wallet.
Old 02-11-2006, 11:07 PM   #5
so went in, and turns out the alignment rack where i wanted to go was f*ed. but i can wait, since it's a free alignment from friends.
gah frustrating.
Exaust clip sorta... and pics Vash Pre-2005 V6 Mustang 9 04-21-2006 03:01 PM
Fixed my brakes...sorta Tbird232ci 1979-1995 Mustang GT 4 02-17-2006 09:05 AM
Well...a kinda sorta kill Tbird232ci The Bar 4 09-19-2005 05:28 AM
4.2 swap sorta oaktonarcher Pre-2005 V6 Mustang 23 10-07-2004 08:04 PM
start probleme sorta oaktonarcher Pre-2005 V6 Mustang 2 01-28-2004 10:15 AM
07:53 PM
