For all of you possibly needing C/C plates, but want a cheaper alternative - Mustang Evolution
Old 04-03-2006, 04:46 PM   #1
Zim
You want to **** me?
Zim's Avatar
Thumbs up For all of you possibly needing C/C plates, but want a cheaper alternative
I didnt know where to put this, as it can be useful for an 79+ mustang, so I just threw it here. But anyway...
Just looking through my H&R catalogue and saw that they make Camber correction kits for 37.50 for the pair. Theyre a couple bolts that replace the top strut bolt where it connects to the control arm. One side of the bolt has an area that bulges out from the bolt shaft and can correct camber from 0-3*... thats a pretty significant amount of camber correction for under 40 bucks right there, and the installation would be very easy. If anyones interested, the part number that youll need for them is:
Part # TC116
Suggested retail: 37.50
I even took it upon myself to scan the info from the magazine so you can read a little more on it.
ID:	12567   Click image for larger version
I like toys
Old 04-03-2006, 04:54 PM   #2
Re: For all of you possibly needing C/C plates, but want a cheaper alternative
Would this correct someones camber like mine that is slammed?
Old 04-03-2006, 04:56 PM   #3
Zim
Zim's Avatar
From what it looks like, yeah.
Id assume youd install them to give you the full extra 3 degrees of camber, then just have your stock plates adjusted, and they should be able to get it right for ya.
I like toys
Old 04-03-2006, 04:59 PM   #4
it works but the best way is cc plates.
Old 04-03-2006, 05:12 PM   #5
bbunt302's Avatar
Hmm... I wonder if it could be used along with C/C plates for more adjustment...
It seems like alignment shops have a hard time getting mine exactly where I want it even with C/C plates. I won't even get in to how hard of a time they have with the adjustable tie-rod ends.
Scary stuff.
Old 04-03-2006, 05:18 PM   #6
I am going to give this a shot
Old 04-04-2006, 12:05 PM   #7
12second5.0's Avatar
Send a message via AIM to 12second5.0
Most likely..........I've been doing this trick for years...........Just go to a hardware store and buy some grade 8 bolts.........Alot cheaper than a 40 dollar kit.........
12second5.0 is offline   Reply With Quote
Old 04-04-2006, 12:07 PM   #8
They don't know how to adjust bump steer..............Find a place that specializes in alignments.
Old 04-04-2006, 01:09 PM   #9
bbunt302's Avatar
Actually, they couldn't even figure out how to adjust the toe on it. I finally took it somewhere and got it aligned but they said that they "couldn't straighten the steering wheel". This was an actual shop that specializes in alignments too. It's just that the alignment shops we have around here suck.
I know how to straighten the steering wheel myself (while keeping the same toe setting), but I just haven't felt like messing with it. I need to make some measuring devices and just start doing my own alignments.
Scary stuff.
Old 04-05-2006, 09:50 AM   #10
stang-rookie's Avatar
Even cheaper...if they work
http://www.speedconcepts.net/product...roducts_id=492
stang-rookie is offline   Reply With Quote
Needing a new firewall adjuster SpectorV Pre-2005 V6 Mustang 2 10-13-2005 12:56 PM
anyone needing taillight blackouts? 232stang01 The Bar 8 04-08-2005 11:16 PM
Stang needing to be put down PureVenom The Bar 19 03-19-2005 11:22 AM
Directed 1100D amp.. cheaper! Brent Mustang Parts for Sale and Wanted 7 12-13-2004 08:52 AM
Moving to Cincinnati Ohio, Needing some info!! kaper232 The Bar 8 11-06-2004 11:28 PM
05:56 AM
