what would be the best engine to swap if my 3.8 blows - Mustang Evolution
Old 09-22-2003, 08:26 PM   #1
MusclesFromBrussels's Avatar
Send a message via AIM to MusclesFromBrussels
302 5.0 (my personal fav)
98 4.6
99 plus 4.6
MusclesFromBrussels is offline   Reply With Quote
Old 09-23-2003, 02:46 AM   #2
Thomas91169's Avatar
yo speaking of engine swap will the 99+ 4.6V8 engines directly bolt on to the manual tranny on a 99+ v6 stang? if so they always have 99+ V8's on ebay for 1000 or cheaper with low mileage. just do a vortech s-trim or a roush blower and fully forged internals and nos(maybe) and have a nice little 12 sec car under 6 grand.
-Thomas-
Old 09-23-2003, 05:22 AM   #3
fast64's Avatar
302!!!!!!!!
GO BRAVES
Old 09-23-2003, 08:38 AM   #4
mmmmm 302!!! no but really what is the easiest to swap as far as everything u need to get it running.
Old 09-23-2003, 09:54 AM   #5
01mineralgrey6's Avatar
5.4
-Tony
'99 cobra 'vert
Old 09-23-2003, 10:00 AM   #6
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
5.0
Rellik is offline   Reply With Quote
Old 09-23-2003, 12:13 PM   #7
Send a message via AIM to synister232
**** that... drop in a 351W
Mike P
http://www.mustangmods.com/data/174/synister_sig03.jpg
1997 Ford Mustang - K&N, MAC U/D Pulleys, Dual 2.5in DynoMAX mufflers, Indiglo Horse, Indiglo Gauges, MTX 300W amp, 2 12"s, and misc interior
synister232 is offline   Reply With Quote
Old 09-23-2003, 02:19 PM   #8
fast64's Avatar
Originally Posted by synister232
#### that... drop in a 351W
hell yeah I am dumping the 302 for one soon.
GO BRAVES
Old 09-23-2003, 06:07 PM   #9
Rick0636's Avatar
http://www.modularfords.com/forums/ For any of you who doubt the potential of the modular Ford V8s, go hang out on this website for a while and check it out, I think you will have your minds changed. I am a longtime fan of the Ford smallblocks, and I think the 289 was one of the toughest and best engines ever built, but I love my 4.6L too! In a 96+ body a modular engine will bolt in a lot easier than a 5.0 will, and the 99+ engines are the best there is with about 35+ more horsepower from improved heads.
Old 09-23-2003, 07:58 PM   #10
um...rick...last time i checked 289 is a 4.6....but whatever
Old 09-23-2003, 08:05 PM   #11
I think he ment 302 but just had 4.6 on his mind
Old 09-23-2003, 08:48 PM   #12
Rick0636's Avatar
No, I meant 289, that was what a 302 was before they stroked it and made it weaker and gave it a little more power. A 4.6 is a 281 cu in, NOT a 289. Ford small blocks, 221, 260, 289, 302, 351W, these are all the same block, just bored, stoked etc to get larger displacements. and yes, they were all V8 engines.
Old 09-23-2003, 08:57 PM   #13
Rick0636's Avatar
You want the best engine possible for your 64 1/2, build a balanced and blueprinted, forged as much as possible 289 high performance for it, it would make that 302 look sad indeed. Put a good high lift and duration cam in it, port and polish everything possible. Edlebrock torquer II intake, 750 cfm Holley double pumper, tuned headers and exhaust, you should be hitting around 600-700 hp with a good mallory ignition system.
Old 09-23-2003, 09:23 PM   #14
MOPAR 318 WOO HOO
Old 09-23-2003, 09:24 PM   #15
Black95GT's Avatar
Send a message via AIM to Black95GT
351
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 09-23-2003, 09:58 PM   #16
Rick0636's Avatar
The 318 Mopar small block is in the same sort of family as the Ford 289, 302, 351W, I can't remember the smaller sizes, but the 318, then the 340, then the 360, are all also the same block, I am sure we all know the Chevy small blocks, 265, 283, 327, 350, 400 small block, again, all the same block.
Old 09-23-2003, 10:04 PM   #17
Rick0636's Avatar
The 351W, or Windsor, at least in my opinion, and also that of a lot of other people, is not that good an engine, its inherintly weak in that Ford has already pretty much bored and stroked it to its limit, it can be built to run well, but when this is done they tend not to last long. The 351C or Cleveland engine is or was a much better engine, it was a big block with the same displacement and indeed they were sold sometimes interchangably, you might not even know which one you were getting unless you knew engines well. The Cleveland had much more potential and was a stronger block.
Old 09-29-2003, 05:21 AM   #18
fast64's Avatar
dude, I am going 351w stroked to 427,
GO BRAVES
Old 09-30-2003, 10:52 AM   #19
Rick0636's Avatar
Yeah, I have heard of it, they are used in a lot of AC Cobra kit cars, as for durability, I wouldn't bet on them lasting very long, I am sure they are fast as long as they do last though. :
Old 10-01-2003, 09:25 PM   #20
i need to rebuild my 289 hi po, yes i really have one, k code too.
Old 10-02-2003, 08:35 AM   #21
Rick0636's Avatar
There was a tale way back, I don't doubt it was true, that Ford built one, had it on a bench dyno, balanced, blueprinted, with all the best goodies, got almost 1000 hp out of it.
Old 10-02-2003, 08:35 AM   #22
Rick0636's Avatar
Engine swap help? monstermustang 1996-2004 Mustang GT 3 09-09-2009 04:56 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
Engine Swap SilverStang96 Pre-2005 V6 Mustang 3 09-23-2004 01:56 PM
10:19 AM
