easy way to bend sheet metal 90 degrees without special tools? - Mustang Evolution
Old 05-10-2006, 02:20 PM   #1
fast64's Avatar
I need to bend some sheet metal 90* for my radiator support, but don't have access to a brake and don't want to pay out the *** for a metal shop to do it. The best solution I have come up with is using a grinder to make a little notch where I want to bend, then just bend it by hand around the side of my garage until its the right angle. Any other suggestions?
BTW, I am back home and pumped about the stang, expect to see lots of major updates on the body work in the following weeks!
GO BRAVES
Old 05-10-2006, 02:23 PM   #2
Zim
You want to **** me?
Zim's Avatar
Re: easy way to bend sheet metal 90 degrees without special tools?
You have a torch?? Heat that bastard up.... a hot metal is a flexible metal :thumbs2:
I like toys
Old 05-10-2006, 02:26 PM   #3
fast64's Avatar
that was my other idea, lol.
GO BRAVES
Old 05-10-2006, 02:27 PM   #4
Zim
Zim's Avatar
Thats what id do... head it up and slowly bend it.
I like toys
Old 05-10-2006, 02:44 PM   #5
I bet that's what you do....
Old 05-10-2006, 02:46 PM   #6
Zim
Zim's Avatar
typo.d
I like toys
Old 05-10-2006, 03:25 PM   #7
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
if u really dont want to spend the money use a zippo and heat it over night
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 05-10-2006, 05:32 PM   #8
Brent and I will have to come over some weekend and help wrench on that thing this summer.
Old 05-10-2006, 08:29 PM   #9
fast64's Avatar
sounds like a plan, my goal for this summer is too get the body work DONE, completely, maybe even paint if I am lucky.
GO BRAVES
Old 05-10-2006, 08:33 PM   #10
fast64's Avatar
a guy on the local forums has a brake at work and he will do it for me
GO BRAVES
Old 05-11-2006, 06:34 AM   #11
Bane-'s Avatar
could of made ur own brake, couple 2x4 or 2x6's that are longer then the metal, screw them together ( but not through the metal ) and bend it over then hammer it to have a sharp 90
Old 05-11-2006, 06:38 AM   #12
Bane-'s Avatar
oh and dont forget a razor knife to score the back of it
Old 05-11-2006, 08:20 AM   #13
Herbstang's Avatar
torch,bench vise & some muscle Put that crack torch to some other use
Old 05-11-2006, 09:22 AM   #14
bbunt302's Avatar
All you need is the metal and brawn.
Scary stuff.
Does this Dyno sheet look a little off to you? Horse Pre-2005 V6 Mustang 9 05-06-2010 06:40 PM
auto dyno sheet? blackonblack Pre-2005 V6 Mustang 21 01-15-2010 03:53 PM
w00t 60 degrees! wiarumas The Bar 21 03-30-2005 09:33 PM
My dyno sheet 97Stallion Pictures and Videos 2 10-18-2004 08:39 PM
Split-port sheet-metal intake ericstanley Pre-2005 V6 Mustang 1 05-12-2004 04:45 PM
12:30 PM
