Well guys....... I just screwed up - Mustang Evolution
Old 10-05-2003, 12:33 AM   #1
.:DarkEntity:.'s Avatar
Send a message via AIM to .:DarkEntity:.
I just ****ing mishifted, and ****ed something up.... I berely limped my way home.
I mis-shifted into 2nd, bounching off my revlimiter - and something broke. I think I heard a pop... Right now my car sounds like a motorcycle, like a ****ing harley - literally. When RPMs go below 1,500 (in neutral, or idle) the motor just slows down, and the car dies. When driving, it's berely pulling, and I smell exhaust. I think I smelled some burning oil in it too, it smells like a damn go-cart exhaust. The motor shakes.
Ain't that a *****?
http://www.mustangmods.com/data/13888/legacysig3.jpg
.:DarkEntity:. is offline   Reply With Quote
Old 10-05-2003, 12:59 AM   #2
Guess you'll be getting an automatic next?
Sorry. That sucks man.
Laser02 is offline   Reply With Quote
Old 10-05-2003, 02:54 AM   #3
yeah, sorry alex.. sounds like you'll be buying a new engine.
2000 Chevrolet Tahoe LS
5.3L VORTEC (not V-TEC) V8
4-Speed Automatic 4x4
Garaged:
1990 Ford Mustang GT
5.0L V8
4-Speed Automatic Overdrive
ItWouldAppearSo is offline   Reply With Quote
Old 10-05-2003, 03:27 AM   #4
Send a message via AIM to WH3.8FURY
that much damage from a miss shift? the most that happens to me is a grinding sound
WH3.8FURY is offline   Reply With Quote
Old 10-05-2003, 04:31 AM   #5
Ken
Ken's Avatar
Region: New Hampshire
well, at least you are experienced at the J-spec swap
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
Old 10-05-2003, 07:03 AM   #6
fast64's Avatar
that sucks dude, got a warranty on the new engine?
GO BRAVES
Old 10-05-2003, 10:25 AM   #7
Nope, no warranty... I mis-shifted many times before, but I guess the 9lb flywheel really contributed this time. My RPMs climb really fast. I didn't even know what happened at 1st, I'm was just rolling without powersteering, with my car off, and the 'check engine' light on, into this parkinglot. Started it up again, and was just like "Oh.. ****.."
I talked to some people, they said in a good case - I blew out some gaskets, in the worst - bent some valves. Either way, both suck. Looks like I got a loooot of work on my hands.
Old 10-05-2003, 01:04 PM   #8
it sounds like you bent valves, i dont think you blew any gaskets
Garaged:
5.0L V8
Old 10-06-2003, 10:13 AM   #9
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
My guess is that he did a little from column A, anda little from column B.
In Either case, Valves or gaskets, you're gonna have to replace gaskets anyway... cuz you have to replace gaskets to get to the valves anyway.
Sucks Alex... next time... stay away from that rev limiter :no:
Rellik is offline   Reply With Quote
Old 10-06-2003, 10:17 AM   #10
that sucks, good luck fixing it all, and keep me posting with what you did, or whats the real problem.
Old 10-06-2003, 05:25 PM   #11
Well, me and this smart mechanic guy are about to go, and check it out in the daytime.......
I'll let you guys know what we find
*corss your fingers*
Old 10-06-2003, 06:58 PM   #12
fast64's Avatar
mah fingers are crossed
GO BRAVES
Old 10-08-2003, 02:26 PM   #13
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Good luck dude, that blows.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 10-08-2003, 02:28 PM   #14
its getting past the "daytime" what did u guys find?
Old 10-08-2003, 04:22 PM   #15
Zim
You want to **** me?
Zim's Avatar
soooo.... youre not selling the mazda right away?? heh
I like toys
Old 10-10-2003, 09:47 PM   #16
Ok..... update:
Me and this super-smart machanic dude just finished taking my **** apart. We drained all the oil, and coolant (there was no cooland present in antifreeze, nor the other way around) took off the manifold, opened up the rear head, and now trying to get to the rear.. uhh.. I think it's called exhaust manifold in english. The only thing that stopped us, was - we lost the damn 12mm socket for the wrench, so I'll have to buy one tomorrow morning and continue. We're 90% sure that none of the valves were damaged. We narrowed down the problem to either: (best) burnt out, and busted rear exhaust manifold seal, or (worst) crack in the rear somewhere - in which case I'll have to find an engine lift, pull the whole ****er out, and fix it. Regardless, it looks like the car is going to live - the guy who's working with me (and actually telling me WTF to do.. ) is like a genious engineer, and a certified professor of some sort of advanced mechanics. Tomorrow once I get ahold of another 12mm socket, we will know for sure what the problem is. Ok... that looks like that's all that happened today..
Alex
Old 10-10-2003, 10:43 PM   #17
Monkey's Avatar
glad its not a bad valve
Old 10-10-2003, 11:34 PM   #18
Also: I figured out why the hell was I running so much slower than I should have been with this engine... I guess we were slacking off when we dropped the motor in - what I found durring this pull-apart session was: a lot of vacuum hoses, and even the valve cover WAS NOT ON TIGHT. That means - I was losing compression, and had all sorts of pressure leaks all over that place. That really explains why I was running a lot slower than one of my friends who has the same motor as me, with the same mods. All this time I thought it was my ****ing shifting, and launches - that wasn't it. Looks like this time, we're gonna finally do everything RIGHT, and I'll be running like I should be... :thumbsup: Can't wait
Old 10-11-2003, 12:13 AM   #19
Monkey's Avatar
blessing in disguise
Old 10-13-2003, 09:01 AM   #20
Region: Iowa
I said it once and I'll say it again, good luck. 8)
Old 10-13-2003, 10:23 AM   #21
thats cool u figured it out. Good luck with everytthing.
Old 10-15-2003, 08:01 PM   #22
Another update.....
Looks like I'M ****ED
Old 10-15-2003, 08:05 PM   #23
what now?
Old 10-16-2003, 05:08 AM   #24
Ken
Ken's Avatar
Come on.. the suspense
Did you alread unload the MX-6?
Old 10-16-2003, 08:12 AM   #25
ya whats gong on?
Old 10-17-2003, 02:18 AM   #26
damage (either one, two, or more):
A) damaged exhaust gasket
B) damaged heads
C) seals are crap
D) slipping clutch plate?!?! WTF!!!!
E) or all of the above
ON A PERSONAL NOTE: I WOULD LIKE TO FIND A PERSON WHO DESIGNED THE FORD PROBE/MAZDA MX-6 AND PUT ALL THE MIGHT OF MY FOOT, TO KICKING HIM IN THE NUTS.... MORE THAN ONCE!
Exhaust gasket, damn mother-****ing-impossible to get too... I spend a whole day.. (YES, A WHOLE DAY) trying to take off the damn timing belt cover, so I can take out the head and look at it.. AND NO, I STILL HAVN'T! Why? Because there is a ****ing pulley holding the ***** in place - which has 4 nuts on it, which are IMPOSSIBLE to take off, since the pulley keeps freely spinning as you're trying to put your might on unscrewing either one of the 4 nuts/bolts on it... Under it is the underdrive pulley (unrthodox) - I have NO IDEA how the **** they put it on there... Even when I put the gear, the pulley was also spinning, as I was trying to unscrew the damn nut the was holding it in place - which brought me to another conclusion that the clutch plates were - CRAP and were not holding it in place! Which brings out this delema: my clutch was not slipping - at all, so how the hell is this possible??? So, I concluded this: the only way I would be able to do ANYTHING from this point on, is to pull out the whole motor. I can not even begin to explain how PISSED I am.
Old 10-17-2003, 08:37 AM   #27
ouch, get air tools or rent them, you'll get that pulley off.
Oh you guys are all so screwed *WW* Zim The Bar 55 02-23-2007 01:01 PM
I got screwed....:( crazeflier07 Mustang Parts for Sale and Wanted 13 01-28-2007 06:24 PM
I get screwed over again... Tbird232ci The Bar 0 10-02-2005 09:50 PM
the FBI screwed up Zim The Bar 3 05-29-2004 01:11 PM
This boy almost was screwed over Brent The Bar 7 05-29-2004 01:06 PM
03:52 AM
