MYT engines - Mustang Evolution
Old 06-21-2006, 01:22 PM   #1
Ken
Ken's Avatar
Region: New Hampshire
MYT engines
Angel Labs :: Home
1. The Mighty Engine ™ (“ME”) design is very small and simple. The prototype has a 14 inch diameter and is 14 inches long. It weighs 150lbs. There are only 26 moving parts, 31 parts total. These are simple, physical facts. The first prototype uses diesel or biodiesel for fuel. (The ME design accommodates dramatic reductions in size depending on the application of the engine.) Through two revolutions of its crankshaft, the ME firing cycle is equivalent to a 32 cylinder reciprocating engine, that is, it fires 32 times. As a result, its displacement is equivalent to an 848 cubic inch reciprocating engine, despite its compactness. This displacement comparison is derived as follows: (3.1416*(3)(3)*3.75)/4*32 = 848 cubic inches, with a 3” bore and 3.75” stroke, four stroke cycle and thirty two firings. The design is also modular. Additional units can be connected to increase power. The ME is actually a large (extremely efficiently organized) displacement internal combustion engine; therefore its high horsepower output. Moreover, with the high number of cylinders firing in close order, a high number of pulses are generated for high torque, but without the friction and parasitic losses discussed below. (ME efficiency and the ability to use biofuels reduces our dependency on foreign oil.)
At 150lbs, the basic ME design needs only to produce 3,000 hp from 848 cubic inches to produce a 20 to 1 power to weight ratio.
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
Old 06-21-2006, 01:23 PM   #2
Ken
Ken's Avatar
Re: MYT engines
It requires a SC/TC to achieve the 3000hp. N/A it's only 850hp
Angel Labs llc :: Resources
Old 06-21-2006, 05:06 PM   #3
bbunt302's Avatar
Re: MYT engines
Holy ****ing ****.
Scary stuff.
Old 06-22-2006, 03:03 PM   #4
Kiljosh's Avatar
Re: MYT engines
hmm lol :chin:
buttt it still uses gas and oil to lubricate it and I have a feeling the gasoline age is dwindling off....
Old 06-22-2006, 03:13 PM   #5
jimmy_beaner's Avatar
Region: Iowa
Re: MYT engines
lol, imagine if someone dropped that into a Mustang engine bay, and popped open the hood... there's this little tiny engine in there, and then you go RAPE the Ford GT. Imagine that power, with the weight savings. I wonder what kind of gas mileage it gets.
Old 06-22-2006, 04:41 PM   #6
Re: MYT engines
Originally Posted by Kiljosh
hmm lol :chin:
thats what they said in the 70s.. I don't think it is.
Engines... Firewolf Pre-2005 V6 Mustang 12 10-09-2009 11:07 PM
Crate Engines SVTCOBRA General Mustang Discussion 9 06-09-2009 11:19 PM
Are these engines identical? green96gt 1996-2004 Mustang GT 5 01-05-2005 02:52 PM
2 v6 engines 2000 Dunkman Mustang Parts for Sale and Wanted 4 09-22-2004 11:08 PM
06:07 PM
